How to enable CORS on Apache + Nginx ?
shivahost
I have this error:
Access to Font at 'https://originaldomain/fonts/*.woff' from origin 'https://www.testdomain.net' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'https://www.testdomain.net' is therefore not allowed access.
Please help me
Add the following to .htaccess on the domain that is hosting the fonts (this will allow any domains to load the fonts):
<FilesMatch "\.(js|jpg|css|eot|otf|svg|ttf||woff|woff2)$">
<IfModule mod_headers.c>
Header set Access-Control-Allow-Origin "*"
</IfModule>
</FilesMatch>
(Remove the extensions you do not want to allow from the code above.) Edit: This is for Apache, I have no idea about Nginx as I don't use it.
</IfModule>
</FilesMatch>
It is not working , I think because of nginx!
Try to empty all cache in your browser, then restart your browser and check again. If not, you would need to modify the .htaccess code to work on Nginx.
I searched a lot, but there is no success yet, So I opened this topic to find the answer.
I tried many htaccess or httpd.conf codes + empty cache + restart nginx and apache but no success...
All I can say is that my code work on Apache, only time it will not work is if the site is password protected. So unless your site is password protected, then it must be Nginx that is the problem.
I know Nginx serving static files , I tried some codes on nginx conf or vhost file too but no success!
anyone can help?
For me the solution was to add
location ~* \.(eot|ttf|woff|woff2)$ {
    add_header Access-Control-Allow-Origin *;
to the nginx.conf file of the domain. On administrator level -> custom-httpd configurations
