Exim compile enabled by default in CustomBuild 2.0
DirectAdmin Support
Administrator
Staff member
Exim is now compiled by default for new DirectAdmin installs in CustomBuild 2.0.
It was previously left to rpms/packages for install, but now that we're confident the compiler rarely has issues with it, we're able to enable it by default.
We'll eventually remove the exim rpm/deb packages for new OS installer build, since CB2 handles all of that (should anything be missing).
Hello John,
As far as I know system filter on CentOS is installed from the rpm package. So custombuild script will take care of it? Will it overwrite the file with every build/update of exim, exim.conf? Or other?
[root@server etc]# yum provides /etc/system_filter.exim
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: it.centos.contactlab.it
 * epel: mirror.infonline.de
 * extras: it.centos.contactlab.it
 * updates: it.centos.contactlab.it
da_exim-4.89.1-1.x86_64 : Mail Transfer Agent
Repo        : installed
Matched from:
Filename    : /etc/system_filter.exim
[root@server etc]#
CustomBuild updates it if eximconf=yes is set in the options.conf file. I'd suggest setting "chattr +i" for it, if you have any customizations done to it and exim_conf=yes set in the options.conf file. Thank you!
I wonder how many users will loose their customized /etc/system_filter.exim with a new update, as we all are used to have it unchanged by directadmin. probably you have another solution?
Another solution would be:
mkdir -p /usr/local/directadmin/custombuild/custom/exim
cp -p /etc/system_filter.exim /usr/local/directadmin/custombuild/custom/exim/
Hello Martynas,
I did it and rebuilded exim but stil cannot receive messages with eml attachments (in Italy PEC messages).
Here is the file /usr/local/directadmin/custombuild/custom/exim/system_filter.exim:
# Exim filter
## Version: 0.17e
#	$Id: system_filter.exim,v 1.11 2001/09/19 11:27:56 nigel Exp $
## Exim system filter to refuse potentially harmful payloads in
## mail messages
## (c) 2000-2001 Nigel Metheringham <[email protected]>
##     This program is free software; you can redistribute it and/or modify
##    it under the terms of the GNU General Public License as published by
##    the Free Software Foundation; either version 2 of the License, or
##    (at your option) any later version.
##    This program is distributed in the hope that it will be useful,
##    but WITHOUT ANY WARRANTY; without even the implied warranty of
##    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
##    GNU General Public License for more details.
##    You should have received a copy of the GNU General Public License
##    along with this program; if not, write to the Free Software
##    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
## -A copy of the GNU General Public License is distributed with exim itself
## If you haven't worked with exim filters before, read
## the install notes at the end of this file.
## The install notes are not a replacement for the exim documentation
# Only run any of this stuff on the first pass through the
# filter - this is an optomisation for messages that get
# queued and have several delivery attempts
# we express this in reverse so we can just bail out
# on inappropriate messages
if not first_delivery
then
  finish
endif
# Check for MS buffer overruns as per BUGTRAQ.
# http://www.securityfocus.com/frames/?content=/templates/article.html%3Fid%3D61
# This could happen in error messages, hence its placing
# here...
# We substract the first n characters of the date header
# and test if its the same as the date header... which
# is a lousy way of checking if the date is longer than
# n chars long
if ${length_80:$header_date:} is not $header_date:
then
  if $return_path is ""
  then
    seen finish
  endif
  fail text "This message has been rejected because it has\n\
	     an overlength date field which can be used\n\
	     to subvert Microsoft mail programs\n\
             The following URL has further information\n\
	     http://www.securityfocus.com/frames/?content=/templates/article.html%3Fid%3D61"
  seen finish
endif
# These messages are now being sent with a <> envelope sender, but
# blocking all error messages that pattern match prevents
# bounces getting back.... so we fudge it somewhat and check for known
# header signatures.  Other bounces are allowed through.
if $header_from: contains "@sexyfun.net"
then
  then
    seen finish
  endif
  fail text "This message has been rejected since it has\n\
	     the signature of a known virus in the header."
  seen finish
endif
if error_message and $header_from: contains "Mailer-Daemon@"
then
  # looks like a real error message - just ignore it
  finish
endif
# Look for single part MIME messages with suspicious name extensions
# Check Content-Type header using quoted filename [content_type_quoted_fn_match]
if $header_content-type: matches "(?:file)?name=\"([^\"]+\\\\.(?:ad[ep]|ba[st]|chm|cmd|com|cpl|crt|exe|hlp|hta|in[fs]|isp|jse?|lnk|md[be]|ms[cipt]|pcd|pif|reg|sc[mrt]|shs|url|vb[se]?|ws[fhc]))\""
then
  then
    seen finish
  endif
	     potentially executable content\n\
	     \t$1\n\
	     This form of attachment has been used by\n\
             recent viruses or other malware.\n\
	     If you meant to send this file then please\n\
	     package it up as a zip file and resend it."
  seen finish
endif
# same again using unquoted filename [content_type_unquoted_fn_match]
if $header_content-type: matches "(?:file)?name=(\\\\S+\\\\.(?:ad[ep]|ba[st]|chm|cmd|com|cpl|crt|exe|hlp|hta|in[fs]|isp|jse?|lnk|md[be]|ms[cipt]|pcd|pif|reg|sc[mrt]|shs|url|vb[se]?|ws[fhc]))"
then
  then
    seen finish
  endif
	     \t$1\n\
  seen finish
endif
# Attempt to catch embedded VBS attachments
# in emails.   These were used as the basis for
# the ILOVEYOU virus and its variants - many many varients
# Quoted filename - [body_quoted_fn_match]
if $message_body matches "(?:Content-(?:Type:(?>\\\\s*)[\\\\w-]+/[\\\\w-]+|Disposition:(?>\\\\s*)attachment);(?>\\\\s*)(?:file)?name=|begin(?>\\\\s+)[0-7]{3,4}(?>\\\\s+))\"([^\"]+\\\\.(?:ad[ep]|ba[st]|chm|cmd|com|cpl|crt|exe|hlp|hta|in[fs]|isp|jse?|lnk|md[be]|ms[cipt]|pcd|pif|reg|sc[mrt]|shs|url|vb[se]?|ws[fhc]))\"[\\\\s;]"
then
  then
    seen finish
  endif
	     a potentially executable attachment\n\
	     \t$1\n\
  seen finish
endif
# same again using unquoted filename [body_unquoted_fn_match]
if $message_body matches "(?:Content-(?:Type:(?>\\\\s*)[\\\\w-]+/[\\\\w-]+|Disposition:(?>\\\\s*)attachment);(?>\\\\s*)(?:file)?name=|begin(?>\\\\s+)[0-7]{3,4}(?>\\\\s+))(\\\\S+\\\\.(?:ad[ep]|ba[st]|chm|cmd|com|cpl|crt|exe|hlp|hta|in[fs]|isp|jse?|lnk|md[be]|ms[cipt]|pcd|pif|reg|sc[mrt]|shs|url|vb[se]?|ws[fhc]))[\\\\s;]"
then
  then
    seen finish
  endif
	     \t$1\n\
  seen finish
endif
# Fudge to catch Klez virus (mal formed mime details, unquoted filename with spaces)
if $message_body matches "Content-Type:(?>\\\\s*)[\\\\w-]+/[\\\\w-]+;\\\\s*(?:name)=([^\" ]+ [^\"]*\\\\.(?:ad[ep]|ba[st]|chm|cmd|com|cpl|crt|exe|hlp|hta|in[fs]|isp|jse?|lnk|md[be]|ms[cipt]|pcd|pif|reg|sc[mrt]|shs|url|vb[se]?|ws[fhc]))[\\\\s;]"
then
  then
    seen finish
  endif
	     a unquoted filename with a space, and\n\
             \t$1\n\
  seen finish
endif
#### Version history
# 0.01 5 May 2000
#	Initial release
# 0.02 8 May 2000
#	Widened list of content-types accepted, added WSF extension
# 0.03 8 May 2000
#	Embedded the install notes in for those that don't do manuals
# 0.04 9 May 2000
#	Check global content-type header.  Efficiency mods to REs
# 0.05 9 May 2000
#	More minor efficiency mods, doc changes
# 0.06 20 June 2000
#	Added extension handling - thx to Douglas Gray Stephens & Jeff Carnahan
# 0.07 19 July 2000
#	Latest MS Outhouse bug catching
# 0.08 19 July 2000
#	Changed trigger length to 80 chars, fixed some spelling
# 0.09 29 September 2000
#	More extensions... its getting so we should just allow 2 or 3 through
# 0.10 18 January 2001
#	Removed exclusion for error messages - this is a little nasty
#	since it has other side effects, hence we do still exclude
#	on unix like error messages
# 0.11 20 March, 2001
#	Added CMD extension, tidied docs slightly, added RCS tag
#	** Missed changing version number at top of file :-(
# 0.12 10 May, 2001
#	Added HTA extension
# 0.13 22 May, 2001
#	Reformatted regexps and code to build them so that they are
#	shorter than the limits on pre exim 3.20 filters.  This will
#	make them significantly less efficient, but I am getting so
#	many queries about this that requiring 3.2x appears unsupportable.
# 0.14 15 August,2001
#	Added .lnk extension - most requested item :-)
#	Reformatted everything so its now built from a set of short
#	library files, cutting down on manual duplication.
#	Changed \w in filename detection to . - dodges locale problems
#	Explicit application of GPL after queries on license status
# 0.15 17 August, 2001
#	Changed the . in filename detect to \S (stops it going mad)
# 0.16 19 September, 2001
#	Pile of new extensions including the eml in current use
# 0.17 19 September, 2001
#	Syntax fix
# 0.17a Thu 21-Feb-2002; Douglas Gray Stephens
#        Modify for SLB (adding null return path test)
# 0.17b Wed 01-May-2002; Douglas Gray Stephens
#        Block mal formed mime messages that have a space in the name
# 0.17c Wed 15-May-2002; Douglas Gray Stephens
#        Block mal formed mime messages that have a space and period
#        in the name.
#	 Also block .vb extensions
# 0.17d Thu 16-May-2002; Douglas Gray Stephens
#        Update the notes as Exim 4 uses system_filter_* rather
#        than message_filter_*
#        (after feedback from  David Broome <[email protected]>)
# 0.17e Fri 19-Jul-2002; Douglas Gray Stephens
#        Block SCM (ScreenCam Movie) files
#### Install Notes
# Exim filters run the exim filter language - a very primitive
# scripting language - in place of a user .forward file, or on
# a per system basis (on all messages passing through).
# The filtering capability is documented in the main set of manuals
# a copy of which can be found on the exim web site
#	http://www.exim.org/
# To install, copy the filter file (with appropriate permissions)
# to /etc/exim/system_filter.exim and add to your exim config file
# [location is installation depedant - typicaly /etc/exim/config ]
# in the first section the line:-
#   Exim 3
#	message_filter = /etc/exim/system_filter.exim
#	message_body_visible = 5000
#   Exim 4
#	system_filter = /etc/exim/system_filter.exim
# You may also want to set the message_filter_user & message_filter_group
# (in Exim 4 these are system_filter_user & system_filter_group)
# options, but they default to the standard exim user and so can
# be left untouched.  The other message_filter_* (or system_filter_*
# for Exim 4) options are only needed if you modify this to do other
# functions such as deliveries.
# The main exim documentation is quite thorough and so I see no need
# to expand it here...
# Any message that matches the filter will then be bounced.
# If you wish you can change the error message by editing it
# in the section above - however be careful you don't break it.
# After install exim should be restarted - a kill -HUP to the
# daemon will do this.
#### LIMITATIONS
# This filter tries to parse MIME with a regexp... that doesn't
# work too well.  It will also only see the amount of the body
# specified in message_body_visible
#### BASIS
# The regexp that is used to pickup MIME/uuencoded body parts with
# quoted filenames is replicated below (in perl format).
# You need to remember that exim converts newlines to spaces in
# the message_body variable.
#	  (?:Content-					# start of content header
#	  (?:Type: (?>\s*)				# rest of c/t header
#	    [\w-]+/[\w-]+				# content-type (any)
#	    |Disposition: (?>\s*)			# content-disposition hdr
#	    attachment)					# content-disposition
#	  ;(?>\s*)					# ; space or newline
#	  (?:file)?name=				# filename=/name=
#	  |begin (?>\s+) [0-7]{3,4} (?>\s+)) 		# begin octal-mode
#	  (\"[^\"]+\.					# quoted filename.
#		(?:ad[ep]				# list of extns
#		|ba[st]
#		|chm
#		|cmd
#		|com
#		|cpl
#		|crt
#		|exe
#		|hlp
#		|hta
#		|in[fs]
#		|isp
#		|jse?
#		|lnk
#		|md[be]
#		|ms[cipt]
#		|pcd
#		|pif
#		|reg
#		|scm
#		|scr
#		|sct
#		|shs
#		|url
#		|vb[se]?
#		|ws[fhc])
#	  \"						# end quote
#	  )						# end of filename capture
#	  [\s;]						# trailing ;/space/newline
### [End]
I have
#Mail Settings
exim=yes
eximconf=yes
eximconf_release=4.5
blockcracking=yes
easy_spam_fighter=yes
spamd=spamassassin
sa_update=daily
dovecot=yes
dovecot_conf=yes
pigeonhole=no
I Wish all a happy 2019
Linux Malware Detect started screaming that the Exim version is vulnarable.
So i checked where Exim came from.
First i did ./build versions and nothing came up in regards to exem.
then i did a rpm -qa |grep exim and this came up:
however this is not a centos package...
after some searching I am convinced this is a directadmin package.
even stranger: the rpm says: da_exim-4.89.1
but when telneting to port 25 it says version 4.91
then i found this page but its not clear to me how to proceed the update.
do i uninstall the rpm package and then run ./build exim?
or should i uninstall the rpm package afterwards?
also, if directadmin installed the exim package.. then why is it not showing up with ./build versions?
