IT_Architect
- Feb 27, 2006
phpMyAdmin logout leaves behind a URL that won't work to log in. The parameters need to be be removed manually before logging back in. It doesn't bother me, but I get questions from web developers that I would rather not have to answer. The big difference between the new server and old server is the new server uses php-fpm and the old one uses mod_php. It seems the php is gone before it gets a chance to update the URL on the browser tab for phpMyAdmin.
Do you guys have/had the same issue? If you don't any more, what did you do to fix it?
Thanks1
Thanks1
