MariaDB 5.5.60 update to 5.5.61 issue
staff_nowa
Vilnius
I run ./build mariadb and received error
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/usr/local/mysql/data/mysql.sock' (2)
mv: ‘mariadb-5.5.61-linux-glibc_214-x86_64.tar.gz’ and ‘/usr/local/mariadb-5.5.61-linux-glibc_214-x86_64.tar.gz’ are the same file
And now cannot return to the same version
180917 10:05:01 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/data
180917 10:05:01 [Note] /usr/local/mysql/bin/mysqld (mysqld 5.5.60-MariaDB) starting as process 26873 ...
180917 10:05:01 InnoDB: The InnoDB memory heap is disabled
180917 10:05:01 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180917 10:05:01 InnoDB: Compressed tables use zlib 1.2.3
180917 10:05:01 InnoDB: Using Linux native AIO
180917 10:05:01 InnoDB: Initializing buffer pool, size = 128.0M
180917 10:05:01 InnoDB: Completed initialization of buffer pool
180917 10:05:01 InnoDB: highest supported file format is Barracuda.
180917 10:05:01 InnoDB: Waiting for the background threads to start
180917 10:05:02 Percona XtraDB (http://www.percona.com) 5.5.59-MariaDB-38.11 started; log sequence number 11513921
180917 10:05:02 [Note] Plugin 'FEEDBACK' is disabled.
180917 10:05:02 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
180917 10:05:02 [Note] Server socket created on IP: '0.0.0.0'.
180917 10:05:02 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'host' is read only
180917 10:05:02 mysqld_safe mysqld from pid file /usr/local/mysql/data/mysqld.pid ended
180917 10:05:06 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/data
180917 10:05:06 [Note] /usr/local/mysql/bin/mysqld (mysqld 5.5.60-MariaDB) starting as process 27235 ...
180917 10:05:06 InnoDB: The InnoDB memory heap is disabled
180917 10:05:06 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180917 10:05:06 InnoDB: Compressed tables use zlib 1.2.3
180917 10:05:06 InnoDB: Using Linux native AIO
180917 10:05:06 InnoDB: Initializing buffer pool, size = 128.0M
180917 10:05:06 InnoDB: Completed initialization of buffer pool
180917 10:05:06 InnoDB: highest supported file format is Barracuda.
180917 10:05:06 InnoDB: Waiting for the background threads to start
180917 10:05:07 Percona XtraDB (http://www.percona.com) 5.5.59-MariaDB-38.11 started; log sequence number 11513921
180917 10:05:07 [Note] Plugin 'FEEDBACK' is disabled.
180917 10:05:07 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
180917 10:05:07 [Note] Server socket created on IP: '0.0.0.0'.
180917 10:05:07 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'host' is read only
180917 10:05:07 mysqld_safe mysqld from pid file /usr/local/mysql/data/mysqld.pid ended
my.cnf
[mysqld]
local-infile=0
innodb_file_per_table
[client]
socket=/usr/local/mysql/data/mysql.sock
How possible solve issue now :(
It's a Debian related issue.
Change/add datadir= in /etc/my.cnf from /home/mysql/ and move databases to /var/lib/mysql/:
datadir                        = /var/lib/mysql/
and MariaDB 10.0.36 should start fine.
If you don't know how to do it, contact me for a paid service.
Issue still have
FATAL ERROR: Upgrade failed
Restarting MySQL.
180917 11:00:14 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
180917 11:00:14 [Note] InnoDB: Using mutexes to ref count buffer pool pages
180917 11:00:14 [Note] InnoDB: The InnoDB memory heap is disabled
180917 11:00:14 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
180917 11:00:14 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
180917 11:00:14 [Note] InnoDB: Compressed tables use zlib 1.2.3
180917 11:00:14 [Note] InnoDB: Using Linux native AIO
180917 11:00:14 [Note] InnoDB: Using CPU crc32 instructions
180917 11:00:14 [Note] InnoDB: Initializing buffer pool, size = 128.0M
180917 11:00:14 [Note] InnoDB: Completed initialization of buffer pool
180917 11:00:14 [Note] InnoDB: Highest supported file format is Barracuda.
180917 11:00:14 [Note] InnoDB: Starting crash recovery from checkpoint LSN=49463
180917 11:00:14 [Note] InnoDB: Restoring possible half-written data pages from the doublewrite buffer...
180917 11:00:14 [Note] InnoDB: Starting final batch to recover 11 pages from redo log
180917 11:00:15 [Note] InnoDB: 128 rollback segment(s) are active.
180917 11:00:15 [Note] InnoDB: Waiting for purge to start
180917 11:00:15 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.39-83.1 started; log sequence number 1600607
180917 11:00:15 [Note] Plugin 'FEEDBACK' is disabled.
180917 11:00:15 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
180917 11:00:15 [ERROR] Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist
180917 11:00:15 [Note] Server socket created on IP: '::'.
180917 11:00:15 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.user' doesn't exist
180917 11:00:15 mysqld_safe mysqld from pid file /usr/local/mysql/data/mysqld.pid ended
180917 11:00:19 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/data
180917 11:00:19 [Note] /usr/local/mysql/bin/mysqld (mysqld 10.0.36-MariaDB) starting as process 18022 ...
180917 11:00:19 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
180917 11:00:19 [Note] InnoDB: Using mutexes to ref count buffer pool pages
180917 11:00:19 [Note] InnoDB: The InnoDB memory heap is disabled
180917 11:00:19 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
180917 11:00:19 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
180917 11:00:19 [Note] InnoDB: Compressed tables use zlib 1.2.3
180917 11:00:19 [Note] InnoDB: Using Linux native AIO
180917 11:00:19 [Note] InnoDB: Using CPU crc32 instructions
180917 11:00:19 [Note] InnoDB: Initializing buffer pool, size = 128.0M
180917 11:00:19 [Note] InnoDB: Completed initialization of buffer pool
180917 11:00:19 [Note] InnoDB: Highest supported file format is Barracuda.
180917 11:00:19 [Note] InnoDB: Starting crash recovery from checkpoint LSN=49463
180917 11:00:19 [Note] InnoDB: Restoring possible half-written data pages from the doublewrite buffer...
180917 11:00:19 [Note] InnoDB: Starting final batch to recover 11 pages from redo log
180917 11:00:20 [Note] InnoDB: 128 rollback segment(s) are active.
180917 11:00:20 [Note] InnoDB: Waiting for purge to start
180917 11:00:20 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.39-83.1 started; log sequence number 1600607
180917 11:00:20 [Note] Plugin 'FEEDBACK' is disabled.
180917 11:00:20 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
180917 11:00:20 [ERROR] Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist
180917 11:00:20 [Note] Server socket created on IP: '::'.
180917 11:00:20 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.user' doesn't exist
180917 11:00:20 mysqld_safe mysqld from pid file /usr/local/mysql/data/mysqld.pid ended
Service temporary started and kill again.
Issue solved copy mysql tables from another working server.
Thank you for your help
I checked another my server
mysql_backup_gzip=no
mysql_backup_dir=/usr/local/directadmin/custombuild/mysql_backups
dovecot=yes
dovecot_conf=yes
pigeonhole=no
exim=no
eximconf=no
eximconf_release=4.5
blockcracking=no
easy_spam_fighter=no
phpmyadmin=yes
phpmyadmin_ver=4
squirrelmail=no
roundcube=yes
webapps_inbox_prefix=yes
awstats=no
webalizer=yes
autoconf=yes
automake=yes
libtool=yes
curl=yes
new_pcre=no
autover=no
clean_old_tarballs=yes
clean_old_webapps=yes
cleanapache=yes
custombuild=2.0
cron=no
cron_frequency=weekly
[email protected]
notifications=yes
da_autoupdate=no
updates=no
webapps_updates=yes
php_ini=no
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
spamd=
@zEitEr,
Is this problem only a problem if you didn't have a custom /home partition? (so /home is on /)
It should not really matter whether or not /home is mounted as a separate partition.
Thank you! The strange thing is that we have no problems with all MariaDB versions and /home/mysql. So there must be a logical explanation that you have problems and we do not. We use Debian 8 Jessie and Debian 9 Stretch. This should be another problem, but what :D
Hello zEitEr,
We have a normal /home/mysql directory and the permissions 711 for /home. (755 for /home/mysql)
