After some problems I got this script working, some comments to be aware if you have problems with the generated file:
The NS1 and NS2 needs to be globally defined, are used in the DNS functions but to generate the user.conf file too:
You can add this to the top of the file or after "#Generate user.conf"
		NS1="`/usr/local/directadmin/directadmin c | grep -m1 '^ns1=' | cut -d= -f2`"
NS2="`/usr/local/directadmin/directadmin c | grep -m1 '^ns2=' | cut -d= -f2`"
Another problem was this error
		Named::writeDB: error writing zone for domain.tld: email='' or ns1='' is empty. Ensure the zone is not corrupted.
If you the dns file generator section you will see
		        #Create DNS zone
        CONVERTED_DOMAIN_DNS="${DIRECTADMIN_BACKUPS}/${USERNAME}/backup/${CONVERTED_DOMAIN}/${CONVERTED_DOMAIN}.db"
        CPANEL_DNS_DATA=${DIRECTADMIN_BACKUPS}/${USERNAME}_cpanel_to_convert/dnszones/${CONVERTED_DOMAIN}.db
        if [ -s ${CPANEL_DNS_DATA} ]; then
        cp -f ${CPANEL_DNS_DATA} ${CONVERTED_DOMAIN_DNS}
        else
And with this the DNS zone is done, but the cpanel dns file isn't compatible with the directadmin backup script a needs to be fixed, my suggestion:
add below
This
		                sed -i '/domainkey/d' ${CONVERTED_DOMAIN_DNS}
                sed -i '/NS/d' ${CONVERTED_DOMAIN_DNS}
                sed -i '/SOA/d' ${CONVERTED_DOMAIN_DNS}
                sed -i "/\$TTL/a@       IN      SOA     ${NS1}.      hostmaster.${CONVERTED_DOMAIN}. (" ${CONVERTED_DOMAIN_DNS}
                echo "${CONVERTED_DOMAIN}.     14400   IN      NS      ${NS1}." >> ${CONVERTED_DOMAIN_DNS}
                echo "${CONVERTED_DOMAIN}.     14400   IN      NS      ${NS2}." >> ${CONVERTED_DOMAIN_DNS}
With comments:
The cpanel domainkey isnt compatible with directadmin, not need here:
We need to update the NS servers of the zone to our local, for this, the NS records of cpanel needs to be removed.
The cpanel SOA starts with the domain name, in directadmin needs to be @ or the import fail, for this we remove the line:
Add the new SOA line to the zone:
Add the new NS records to the zone:
I think more things can be done with this, but now the zone is compatible with directadmin
For alias/pointers domains you need to fix it too:
After this
		cp -f ${CPANEL_POINTER_DNS_DATA} ${CONVERTED_POINTER_DNS}
Add
		                sed -i '/domainkey/d' ${CONVERTED_POINTER_DNS}
                sed -i '/NS/d' ${CONVERTED_POINTER_DNS}
                sed -i '/SOA/d' ${CONVERTED_POINTER_DNS}
                sed -i "/\$TTL/a@       IN      SOA     ${NS1}.      hostmaster.${i}. (" ${CONVERTED_POINTER_DNS}
                echo "${i}.     14400   IN      NS      ${NS1}." >> ${CONVERTED_POINTER_DNS}
                echo "${i}.     14400   IN      NS      ${NS2}." >> ${CONVERTED_POINTER_DNS}
Another detail, the NS2 variable in the DNS Zone section is using the NS1 data:
		NS2="`/usr/local/directadmin/directadmin c | grep -m1 '^ns1=' | cut -d= -f2`"
Fix to
A question, when a cpanel backup dont have a DNS zone?
I think, the "else" section never will be executed because the cpmove file always have the main domain dns zone.
For the pointers is the same situation "if [ -s ${CPANEL_POINTER_DNS_DATA} ];" , if a pointer exist, you will have a DNS file from the cpmove, and based on this the "else" section never will be executed.
After all now the script is working
 thanks smtalk for your script.
Regards
Roberto
