Can't delete a TXT record from DNS Management
glio
Because Let's Encrypt wild card auto renew function is never work for me, and I need to add txt record to finish my wild card verification to get a new ssl cert.
I have delete try to delete a tet record form DNS Management many times, and I was add a txt :
"_acme-challenge.domain.net" 1 TXT "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
however after I add this record, I can't delete this from "DNS Management"
Please help me and tell me how can I delete it?
P.S:I have root account
Many Thanks
What’s the error you get when trying to remove?
Thank you for you help, but I got no error with remove, it just like click and reload that page, but I was test it to add another txt and remove, after I click delete that new txt was remove, just can't delete the formart with"" like:
I think that is a format's bug, and this format was wrong, but I can't delete it
I seem system was added this kind of format and that was work:
_acme-challenge.domain.net. 1 TXT "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
attachment.php
You might try to remove the records from /var/named/domain.com.db file directly if you need a quick fix.
p.s. there is no need to hide right-value of a TXT record, it's public in DNS already. And even if you publish it here, it is almost to impossible to find out your domain name by this record.
Thanks, I was try it, but I will got Error: Could not write domain's db file in /var/named after I changed.
Thanks again
