Debian 10
jet1972
Debian 10 will be released in this week (6th of July, 2019). Time to create Debian 10 forum.
"DirectAdmin will now be installed on: debian 10.0
Is this correct? (must match license) (y,n) : n
Please change the value in your license, or install the correct operating system"
There is still no Debian 10 in the supported OS list..
and if I choose Yes to the previous question:
ERROR 404: Not Found.
*** Unable to download files.sh
tried: http://files.directadmin.com/services/debian_10.0_64/files.sh
It rolls back to debian 9:
[root@server ~]# [B]grep buster setup.sh  -A 10
[/B]        if [ "$OS_VER" = "buster/sid" ]; then
                echo "This appears to be Debian version $OS_VER.";
                echo "This version is essentially Debian 10, which is not released yet, so the install might not work";
                echo "See this page for more information:";
                echo "    http://www.debian.org/releases/";
                echo "";
                sleep 10;
                #exit 1;
                OS_VER=9.0
                echo "... but continuing anyway.";
                sleep 1;
[root@server ~]#
Did you try the latest setup.sh?
You might choose debian 9 for the license.
                echo "";
                sleep 10;
                #exit 1;
                OS_VER=9.0
                sleep 1;
[root@server ~]#
Yes. I downloaded the latest setup-file.
It seems there is a bug in the script:
If I change it to
if [ "$OS_VER" = "10.0" ]; then
then it works.
On Debian the Setup should parse file /etc/os-release to set the release name and OS correctly?
Now it parses /etc/debian_version which only contains the version number and not release name at all.
Executing database schema update.
ERROR: SQLSTATE[HY000] [2002] No such file or directoryError 500: Error connecting to database: SQLSTATE[HY000] [2002] No such file or direct ory
ensure_my_cnf: cannot find /usr/local/directadmin/conf/mysql.conf
chown: invalid user: 'diradmin:diradmin'
phpMyAdmin requires mysqld. Cannot find /usr/local/mysql/bin/mysql
--2019-07-12 14:59:49-- http://files18.directadmin.com/serv...4/exim.conf-SpamBlockerTechnology-v4.5.14.txt
Resolving files18.directadmin.com (files18.directadmin.com)... 37.72.98.6
Connecting to files18.directadmin.com (files18.directadmin.com)|37.72.98.6|:80... connected.
Length: 32137 (31K) [text/plain]
Saving to: '/etc/exim.conf.cb20'
/etc/exim.conf.cb20 100%[================================================================>] 31.38K --.-KB/s in 0.08s
2019-07-12 14:59:49 (418 KB/s) - '/etc/exim.conf.cb20' saved [32137/32137]
--2019-07-12 14:59:49-- http://files18.directadmin.com/services/custombuild/system_filter.exim
Length: 10489 (10K) [text/plain]
Saving to: '/etc/system_filter.exim'
/etc/system_filter.exim 100%[================================================================>] 10.24K --.-KB/s in 0.01s
2019-07-12 14:59:49 (699 KB/s) - '/etc/system_filter.exim' saved [10489/10489]
--2019-07-12 14:59:49-- http://files18.directadmin.com/services/SpamBlocker/4.5.14/exim.strings.conf
Length: 2076 (2.0K) [text/plain]
Saving to: '/etc/exim.strings.conf.cb20'
/etc/exim.strings.conf.cb20 100%[================================================================>] 2.03K --.-KB/s in 0.002s
2019-07-12 14:59:49 (1.25 MB/s) - '/etc/exim.strings.conf.cb20' saved [2076/2076]
--2019-07-12 14:59:49-- http://files18.directadmin.com/services/SpamBlocker/4.5.14/exim.variables.conf.default
Length: 924 [text/plain]
Saving to: '/etc/exim.variables.conf.cb20'
/etc/exim.variables.conf.cb20 100%[================================================================>] 924 --.-KB/s in 0s
2019-07-12 14:59:50 (73.8 MB/s) - '/etc/exim.variables.conf.cb20' saved [924/924]
--2019-07-12 14:59:50-- http://files18.directadmin.com/services/exim.pl.24
Length: 17716 (17K) [application/x-perl]
Saving to: '/etc/exim.pl.cb20'
/etc/exim.pl.cb20 100%[================================================================>] 17.30K --.-KB/s in 0.05s
2019-07-12 14:59:51 (350 KB/s) - '/etc/exim.pl.cb20' saved [17716/17716]
Restarting exim.
Downloading letsencrypt.sh...
--2019-07-12 14:59:51-- http://files18.directadmin.com/services/custombuild/all/letsencrypt/letsencrypt.sh.1.1.23
Length: 30577 (30K) [application/x-troff-man]
Saving to: '/usr/local/directadmin/custombuild/letsencrypt.sh'
/usr/local/directadmin/custombuild/ 100%[================================================================>] 29.86K --.-KB/s in 0.08s
2019-07-12 14:59:51 (391 KB/s) - '/usr/local/directadmin/custombuild/letsencrypt.sh' saved [30577/30577]
Let's encrypt client 1.1.23 has been installed.
* All parts have been installed *
Type: systemctl restart httpd.service
## REPORT_START
Welcome to DirectAdmin version 1.57.5!
You are now about to run the install program. If DirectAdmin is already
installed, it may destroy previous data.
Here is the information given:
Admin user: admin
Admin email: [email protected]
Server IP: x.x.x.x
Server IP Netmask: 255.255.255.0
Server Hostname: srv.domain.com
Name Servers:
ns1.domain.com
ns2.domain.com
options.conf exists, not installing the httpd.conf. Relying on custombuild.
Backup of /etc/proftpd.conf to /etc/proftpd.conf.back successful
Install of /usr/local/directadmin/data/templates/proftpd.conf to /etc/proftpd.conf successful
Install of /usr/local/directadmin/data/templates/directadmin.conf to /usr/local/directadmin/conf/directadmin.conf successful
*** Unable to read directadmin.conf. Check permissions and make sure that it exists. Cannot find the diradmin user. Make sure the diradmin user exists in your system.<br>
This error also comes up when the wrong OS is selected in the license. These binaries were compiled for: Debian 9.0 64-bit<br>
## INSTALL_FAILED
Yeah.. we are going to have to wait for Directadmin to update the installer / test with Debian 10. I tried and couldn't get it to work either.
Hi....Debian 10 Buster installed, upgraded from MX Linux based on Stretch. Finally, absolutely everything works out of the box in Debian, no tinkering or workarounds are needed. Debian really has become stable in recent years.
