DewlanceVPS
- Oct 3, 2016
Automatically issue trial license & easy installation method instead of lot of manual
I have 2 request:
1. Please Automatically issue trial license upon first login to newly installed DirectAdmin, It would be easy for deployment and migrating from one cP to DA or DA to DA.
Sometimes hosting providers really need to use Trial license for migrating data, etc., like cpanel provide automatic 15 days trial period.
- With automatic trial license we will be able to instantly deploy server, no need to create ticket.
- Migrate data from crashed or old server to newly created server without waiting for trial license.
2.
Add GUI installation after running command like cPanel provide easy installation method.
- I mean less manual work, Run one line command, It will install panel and provide login URL.
- Visit to URL and proceed further configuration like choosing some most required configuration.
- If possible use different method to enter IP, choose OS, etc from DA panel. (I mean no longer required to Choose OS while placing order and then choose same OS, IP, etc while installing DA. Add auto-detect OS option while installing)
-- I like Installation method of HostBillApp or SupportPal - After running command, When you login it display pending task to configure. It will display unless you click dismiss or complete all pending task like adding nameserver, choosing php version, apache setup, etc.,
I have 2 request:
2.
