PHP Version Selector
itcms
Athens
I am trying to find PHP Version Selector but I cant find
Please can you tell me where I can find it ?
I have check as admin, as user , and as re seller
I have installed 2 php 7.3 and 5.6
BR
Antonis
May I know the PHP Version Selector is it only support enhanced skin but not others ?
@tonycwng it works on any skin, you just need to have at least 2 php versions installed.
Thanks, Zhenyapan. But I find if I use Evolution Skin, the PHP Version Selector disappear. If it should be work, maybe the function relocate to somewhere else ?
