eva2000
- Jul 1, 2019
With DirectAdmin's source compiled routines and CustomBuild, are there any recording of the time the compilation takes to run natively accessible in generated DirectAdmin log files ?
For example when building ImagicK
is the any native logging of the total time the build took to complete that I can inspect?
Or should be just doing ?
Looking to benchmark before versus after compilation optimisations I plan to configure for DirectAdmin usage as there's definite rooms for improving compilation speed in DirectAdmin
./build set imagick yes
./build imagick
time ./build imagick
