eva2000
- Jul 1, 2019
The technical support isn't the only thing.
Also you can then use Beta's (acces)if needed for faster solving something.!
We needed support once SMTALK solved against a litle payment while no direct license.
I see so non-direct DirectAdmin licenses from web hosts don't get beta access ?
Wonderful! I really appreciate the work you have put into this.
Also great for starters. Keep up the good work. Cheers!
Cheers thanks
