Setup IMAP folders.
factor
USA
All:
This was born out of these 2 posts.
https://forum.directadmin.com/showthread.php?t=54713
and
http://forum.directadmin.com/showthread.php?t=58403
Its a general How to get IMAP folders working based on the general structure of
Inbox
Sent
Drafts
Junk
Trash
Archive
Some general Notes to start.
First adding anything to these two file locations doesn't do anything I see.
/usr/local/directadmin/custombuild/configure/dovecot/conf.d/
or
/usr/local/directadmin/custombuild/custom/dovecot/conf.d/
In general with the stock install of DA you get folders like
INBOX
INBOX.spam < We don't want this
Sent
Drafts
Junk
Trash
We want every mail client to get and use the same structure of folders. We want them to auto create and auto subscribe.
Like this.
Inbox
Sent
Drafts
Junk
Trash
Archive
To do this you need a feature and 90-special-folders.conf.. I took hours to hunt it down (since the directadmin.conf is not centrally documented)
It's here https://www.directadmin.com/features.php?id=1679
MAKE SURE YOU HAVE A BACKUP of all your sites and email. Before trying this.
new directadmin.conf option, internal default to:
spam_inbox_prefix=1 < this is the issue. If it's set to 1 or not in the directadmin.conf it defaults to 1 = INBOX.spam
if you set it to 0, all areas in DA will use "Junk" instead of INBOX.spam for paths. < Here it is we want "Junk".
Set spam_inbox_prefix=0 in directadmin.conf
/usr/local/directadmin/directadmin set spam_inbox_prefix 0
systemctl restart directadmin
./build set webapps_inbox_prefix no
./build roundcube
cd ..
# This will rebuild all of your CURRENT EMAIL FOLDERS...  YOU BACKED UP CORRECT????  Note: I didn't lose a thing.
echo "action=convert&value=imap_inbox_prefix" >> data/task.queue; ./dataskq d2000
echo "action=rewrite&value=filter" >> data/task.queue; ./dataskq d2000
Now you will have Junk created instead of INBOX.Spam. (Note: Junk is RFC compliant https://tools.ietf.org/html/rfc6154)
Then you have to go to
cd /etc/dovecot/conf.d
nano 90-special-folders.conf
Paste below in the blank file(this worked for me)
namespace inbox {
  type = private
  separator = .
  subscriptions = yes
  inbox = yes
namespace inbox {
  mailbox Drafts {
    auto = subscribe
    special_use = \Drafts
  mailbox Junk {
   auto = subscribe
   special_use = \Junk
mailbox Archive {
   auto = subscribe
   special_use = \Archive
mailbox Trash {
   auto = subscribe
   special_use = \Trash
mailbox Sent {
   auto = subscribe
   special_use = \Sent
You can confirm it took by doing
./build dovecot_conf
dovecot -n
Then copy /var/www/html/roundcube/config/config.inc.php to /usr/local/directadmin/custombuild/custom/roundcube/config.inc.php
might need to create Roundcube folder.
mkdir /usr/local/directadmin/custombuild/custom/roundcube/
cp /var/www/html/roundcube/config/config.inc.php /usr/local/directadmin/custombuild/custom/roundcube/config.inc.php
find the general section with entries below and set or add to as such:
$config['drafts_mbox'] = 'Drafts';
$config['junk_mbox'] = 'Junk';
$config['sent_mbox'] = 'Sent';
$config['trash_mbox'] = 'Trash';
$config['default_folders'] = array('INBOX', 'Drafts', 'Archive', 'Sent', 'Junk', 'Trash');
$config['create_default_folders'] = true;
$config['protect_default_folders'] = true;
then
./build roundcube
Now go test with an account. make sure you login.
This should give you the structure noted at the beginning.
Hope this helps. Report success or issues as needed.
A bit older post, but since Junk is RFC compliant and Inbox.spam is not, maybe you can create a feature request to drop inbox.spam which is an odd name anyway?
One can customize lots of things, but as this is RFC... why not loose the odd stuff and make it decent by default?
This is already supported: https://www.directadmin.com/features.php?id=1679
Yet, I'm not sure if the internal value of new installs is 0 to be RFC compliant. If not, we should really make this move.
Also added a feature request for DA to add Archive directory to new mailboxes by default, so for instance Roundcube can use it for archiving emails.
@factor
Hello dear friend please if you can take a look at my thread in detail issues. Thanks in advance!
@factor
I am looking now. I will try to see if I can add anything.
So did you do all of the parts of the Guide above?
The Standard folders from above will create the very first time the user logs in.
If they have other folders in their cp backup they would be there but might not be subscribed not sure havent really had issues so not sure.
check my latest answer on my thread I tested 30 times today I get the results.
