LETS ENCRYPT questions about a unknown CRL status and 2 times one with POISON message
ikkeben
Netherlands Germany
Example for @zEirEr Poralix but i think all or almost all LE domains has this.?
https://crt.sh/?q=poralix.com
You can see after MAy 2018 in that test you seee everytime 2 dates ( sometimes on same date to) for the same. with different ID so "always" first attempt failing?
crt.sh ID Logged At ⇧ Not Before Not After Issuer Name
1737135889 2019-08-03 2019-08-01 2019-10-30 C=US, O=Let's Encrypt, CN=Let's Encrypt Authority X3
1729927222 2019-08-01 2019-08-01 2019-10-30 C=US, O=Let's Encrypt, CN=Let's Encrypt Authority X3
The first (id1729927222 2019-08-01) has message with
CT Precertificate Poison: critical
0000 - 05 00
All have:
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Key Encipherment
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
All Have a Orange warning STatus CRL UNKNOWN?
Mechanism Provider Status Revocation Date Last Observed in CRL Last Checked (Error)
CRL The CA Unknown n/a
Meaning and is it possible to have those 3 things not so the Poison and the CRL unknown in Orange warning?
This is only for LE certs so why and is mabye something wrong or could be better?
Thanks for your questions. Currently I have nothing to add as a comment yet. Probably somebody else has anything to say.
I hope so someone knowing why LEts Encrypt has this since 04 /05 2018. ? ( thanks using your domain as example. ;) )
EDIT:
ONE answer could be for the ORANGE warning:
CRL Distribution Points:
The CRL Distribution Points extension provides the location of the corresponding Certificate Revocation List (CRL) for the SSL certificate.
So there isn't a revocation yet, and ok for that.??
Some explanations you can find here i haven't enough knowledge to say is ok or not OK!
https://knowledge.digicert.com/solution/SO18140.html
So the ones with the warning text
in it, is why i started this topic!
LETSENCRYPT.ORG has this to why?
https://crt.sh/?q=letsencrypt.org in this ID https://crt.sh/?id=1674775931
0000 - 05 00
