Missing directadmin.conf
sorabit
I have problem missing directadmin.conf after crash and i can't login into admin
Helo,
I solve the problem with add manualy directadmin.conf.
But i found new problem got error when click to database menu.
Unable to read : Filename is null
Error connecting to MySQL: Plugin sha256_password could not be loaded: /usr/lib64/mysql/plugin/sha256_password.so: cannot open shared object file: No such file or directory
For possible those who will find the thread when searching the same issue, a default directadmin.conf can be found in /usr/local/directadmin/data/templates/directadmin.conf, so you will need to copy it to /usr/local/directadmin/conf/directadmin.conf and adjust per your needs.
As for the SQL issue, I would suggest that you try and re-install MySQL/MariaDB with custombuild.
Hi zEitEr,
Thank you for your reply.
Finally i solve the problem. it is not because mysql service installed, it happens because missing these config in directadmin.conf
mysqlconf=/usr/local/directadmin/conf/mysql.conf
damycnf=/usr/local/directadmin/conf/my.cnf
Hi zEitEr,
This seems very stranger. Never had this problem before.
