Managing DA reseller thru WHMCS?
raghav
Using whmcs 7.6
I got a DA reseller account and tried testing it thru whmcs. But every time I try "test server connection", it returns a failed error. ( full msg : "The request youve made cannot be executed because it does not exist in your authority level")
Screenshot : https://ibb.co/N7XH5Hv
Any one had this error? Is there any fix for this?
Can we use WHMCS to handle DA reseller account?
Using whmcs 7.6
Yes you can ...I use resellers to spread the customers over different shared IPs
here how I add an reseller account to WHMCS 7,7
Hostname I use main server hostname
Ip given to that reseller as share
DirectAdmin
User
Pass
Also Check if your server (where your whmcs is has 2222 port open for outgoing connections
It works
I also have a problem with a admin / reseller account that is I can't manage accounts like create, suspend, terminate, change package, and other functions via whmcs 7.7.1
Here’s some results:
test connection -> success
run the module on whmcs get report "Module Command Success
Service Created Successfully "
but the account and domain are not available in DirectAdmin
please advise regarding this problem.
Thank you
Activate module logging in WHMCS and check the results in it
Here’s module logs results:
Date: 03/09/2019 00:21 - Module: directadmin - Action: cmd_api_account_user
Request
https://164.68.x.x:2222/CMD_API_ACC...di.sg&package=da-1gb&ip=164.68.x.x&notify=no&
Response
Array
[0] => <!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8;"/>
<meta name="viewport" content="width=device-width, initial-scale=1"/>
<title>
164.68.x.x | Login
</title>
<link rel="shortcut icon" href="/images/favicon.png" type="image/x-icon" />
<meta name="robots" content="noindex,nofollow" />
<script>
var tokens = {
LOST_PASSWORD: "no" === "yes",
TIME: {
current: 1567470098 * 1000,
offset: 86400 * 1000,
AUTH_METHOD: "CMD_LOGIN",
QUESTION: "|QUESTION_JSON|",
LOGIN_LANGUAGES: "default=en;en=English;",
</script>
<link href="/assets/css/login.css" rel="stylesheet"></head>
<body>
<div id="login"></div>
<script type="text/javascript" src="/assets/login.js"></script></body>
</html>
Interpreted Response
Array
[<!DOCTYPE html>
<html>
<head>
<meta http-equiv] => "Content-Type" content
Request
https://164.68.x.x:2087/CMD_API_ACCOUNT_USER?action=create&add=Submit&username=epadicp2&email=zall%40e-padi.com&passwd=%40fT3Kx1%5DQG39cmS&passwd2=%40fT3Kx1%5DQG39cmS&domain=epadi.sg&package=da-1gb&ip=164.68.x.x&notify=no&
Any Resolution?
Did you resolve this issue or no? as i am also having same issue.
Request
