One-Click login is not enabled in the directadmin.conf
DanielP
There is maybe new phpmyadmin button on to right corner when you click on a database , when it is clicked it gives One-Click login is not enabled in the directadmin.conf
did I miss the release of the feature I tough it is only for emails in 1.58.2 release
It appeared without been set anything I set it to 1 and rebuild :) it now leads to normal phpmyadmin screen :) So I'm ready for the finish :)
I enabled in directadmin.conf and then gave a service directadmin restart and the error continues.
If you notice after that error is changed
Update custom build then build phpmyadmin again it will lead to phpmyadmin login screen and you will be ready for the moment they completed it
