Marks Verified User Joined Jul 13, 2019 Messages 131 Sep 4, 2019 #1 How to install FFMPEG on directadmin?
D DanielP Verified User Joined Jun 28, 2019 Messages 222 Sep 4, 2019 #2 it is part of os install it as a package for centos then add rpm to cagefs if you use cloud linux
Marks Verified User Joined Jul 13, 2019 Messages 131 Sep 4, 2019 #3 DanielP said: it is part of os install it as a package for centos then add rpm to cagefs if you use cloud linux Click to expand... I don't use cloudlinux, I use CentOS 7.4
D DanielP Verified User Joined Jun 28, 2019 Messages 222 Sep 4, 2019 #4 install for os then you should build php with support of ffmpeg similar to how I added imap to php by editing the build file https://forum.directadmin.com/showthread.php?t=37357&p=297798#post297798 but I do not know what exact should be needed you got to test it by yourself and adapr from that guide for centos 6 https://www.rosehosting.com/blog/install-ffmpeg-php-on-a-centos-6-with-directadmin/ it is similar (check posts under mine first link for adding it permanent to your build)
