realitsolution
1.user account limit for reseller package: currently there is no user account limit options, just domain limit options available. So any reseller can now create unlimited user. I got a link: https://help.directadmin.com/item.php?id=442
But this is global limitation. But we need package based user account limitation. For example for Basic package I want, reseller can create maximum 10 user account, for Standard package reseller can create maximum 20 user account. And they can set add domain limit on their package as they want as their own package
2.Reseller email change: I could not found any option If I want to change reseller user email.
3. Account modify and change user main domain from admin panel and reseller panel.
4. You current DA theme is very slow to load. All of our customers have no good internet connections. So maximum complain I got from my customer on the slow loading issue.
Do you have any plan to make simple template without JS loading that will fast and grid based?
5. ACL: the features that I want to show my user and reseller account panel. Currently I can mange of hide option using theme custo9mize feature. But it not hide from all themes. For example on reseller user panel showing LVE manager or Config server firewall that I don’t want to show in their panel. ACL can help to manage and showing all features that I want to show or not.
6. Mail Client Login information: currently have “Download Outlook Configuration”. But is it possible to show or display mail client login information on webmail. For example: mail server, SMTP/POP/IMAP port no for secure, non secure connection etc.
Some times client need no conjure different mail client or configure SMTP with their website.
7. DNS management on Reseller panel: Reseller could not manage their user’s dns directly from their reseller panel.
File Manager Features:
8. File edit problem: After click “edit file” it takes too much time to load edit enter face. The file edit in same window, so we could not edit multiple files in one time. It need to edit in multiple files in multiple windows.
9. All files compress system is too much complex. After add to clipboard and then we can make compress file. Can you make it simple like just select multiple file and folder and create zip or compress files?
10. Trash system: can you give us trash features on file manager? Because some how if anyone delete any files by mistake then he can restore the file from trash or can permanently remove from trash.
Custom Build Features:
11. . Build software: this is complex to understand whois software has already installed and whois are not. If separate it that already installed then the software will only update option or rebuild option and whois are not installed then only build option. Or separate it as your system.
