DewlanceVPS
- Oct 3, 2016
Evolution theme look so good, I really appropriate work of developer/designer and also thanks to DA team for building control panel like DA.
Currently If your internet speed is slow and you click on any link, It will look like nothing is happening. You will click on it again unless it load contents.
Can you make light weight theme of Evolution theme with subtheme(Traditional).
- Less JS/jQuery/Ajax files.
- No preloader.
- Clickable links (Simple link, Not Ajax/jQuery loader link)
- Separate Main UI icons svg file so it can be easy to edit icons. (There is thousands of icons in icons.svg file but it would be really great if menu icons which display in DA Admin/Reseller/User panel will be separated from icons.svg to different SVG file.)
Thanks.
- No preloader.
Thanks.
