DirectAdmin 1.59.0 has been released
DirectAdmin Support
Administrator
Staff member
We're very pleased to announce the release of DirectAdmin 1.59.0.
There are some exciting new features, as well as important bug fixes.
The full list can be found here:
https://www.directadmin.com/versions.php
New Features:
Bugfixes:
End-Of-Life:
Please let us know if you have any issues.
You can update through:
Admin Level -> Licenses/Updates -> Update DirectAdmin
thanks but also include the IO Usage,Resources usage, live reports like Cpanel had in user panel however cant you build the process monitor filters like we can see the process according to our requirements ? however after changing the skin from default one it redirect to html page which show error 404 not found,also make file manager easier like clipboard options can be changed to simple copy move and paste on the right bar however build some for hiding some folder which are not neccessory for users like cpanel had like .htaccess and some other this it will be really helpful for the customers who was addicted to Cpanel
CloudLinux got resource usage statistics. DirectAdmin does not have it.
New features are perfect. Definetly it will help administrators more. I also have suggestion;
In order to keep our servers clean and protect a bit more from intentionally/unintentionally spammers, the current email limits need to be improved.
It would be perfect to set per hour email limit to an account AND an email address.
John or any staffs and moderators who reading this, the first thing we want is a proper feature request system where we can request for a new feature, vote for it and track the weight and process.
Tools like https://www.useresponse.com/ would help us here.
I don't see any reason or benefit for a separate feature request system, because we already has what we need in this forum: "Feedback & Feature Requests": https://forum.directadmin.com/forumdisplay.php?f=8 - you can even add a poll to your request. I would not like DirectAdmin developers to spend valuable time on a separate system for feature request.
I am facing a problem with new update.
One click email login is not correctly. I always get Invalid Token after clicking "Sign in to Webmail"
Anybody else facing this issue?
Thanks for the update!
I tried following the phpMyadmin SSO guide, but gets a "IP mismatch" error thrown at me when I try to click the login button on a database. Any idea how to fix this?
yes we have this issue too
try reinstall roundcube / phpmyadmin but still error invalid token
I don't have that issue. You also enabled it in directadmin.conf?
cd /usr/local/directadmin/
./directadmin set one_click_pma_login 1
service directadmin restart
cd custombuild
./build phpmyadmin
Maybe you need something like that for mail too, we don't use mail login like this.
cd custombuild
./build phpmyadmin
Actually i was do it before Richard but a results still same :)
another thing after the update to 1.59.0, is on "Brute Force Monitor" the number of failed attempts has switch to 1 or 0.12 instead of the actual number of failed login attempts.
Can you also look it up? It remains that way even after updating to 1.59.1..
Since updating to the newer Directadmin 1.59.0 which uses curl instead of ncftp this is happening:
ftp_upload.php exit code: 67
ftp_upload.php output: curl: (67) Access denied: 530
curl return code: 67
<3:31:25>
This is odd because the backup still succeeded afterwards and there was a smaller backup running before it which was transferred at 3:33:59 which succeeded successfully with the same password.
Or does this happen because curl can't make concurrent logins or something?
Anyway I never have seen access denied notices on ncftpput before. What could cause this?
