- Feb 27, 2003
We're very pleased to announce the release of DirectAdmin 1.59.0.
There are some exciting new features, as well as important bug fixes.
The full list can be found here:
https://www.directadmin.com/versions.php
New Features:
Bugfixes:
End-Of-Life:
Please let us know if you have any issues.
You can update through:
New Features:
- SNI for https://clientdomain.com:2222, if the client has SSL setup.
- One-Time Login URL created via GUI
- Limit number of Users a Reseller can create
- Optional dynamic MySQL/MariaDB version detection
- FTP Backup uploads now use curl (no more ncftpput)
- Ability to mass-select Users to set to a package
- ZIP enabled by default for new installs.
- Optional: One-Click phpMyAdmin login
- Ability to set max valud for email quotas
Bugfixes:
- Only encode email headers if they contain 8-bit characters
- Search and destroy boxes with left-over mysql test data
- Delete database with huge user count can timeout
- Update access host removal to new methods
- Clear old RoundCube data on User deletion
- Confusion: User httpd.conf to show "PHP is OFF for this domain" when php is off
- OpenLiteSpeed: protected directories not added to https if private_html->public_html link was used.
- Compressed log rotation was only rotating for this month
- MX Templates option to also affect domain pointers
- Brute Force Monitor: 8x multiplier allowance for xmlrpc POST 200 response for "Scan for WordPress Attack"
End-Of-Life:
Admin Level -> Licenses/Updates -> Update DirectAdmin
