install DA on an centos 8 server.
Marwen
germany
hello.
I have just tried a DA-installation, but get the message
libssl.so.10
libcrypto.so.10
libcrypt.so.10
are missing
symlinks from the .so to so.10 unfortunately do not work.
You can't install DirectAdmin on CentOS 8 before support for it is added. You then need to change your license to CentOS 8.
https://help.directadmin.com/item.php?id=354
CentOS 8:
yum install wget gcc gcc-c++ flex bison make bind bind-libs bind-utils openssl openssl-devel perl quota libaio \
libcom_err-devel libcurl-devel gd zlib-devel zip unzip libcap-devel cronie bzip2 cyrus-sasl-devel perl-ExtUtils-Embed \
autoconf automake libtool which patch mailx bzip2-devel lsof glibc-headers kernel-devel expat-devel \
psmisc net-tools systemd-devel libdb-devel perl-DBI perl-libwww-perl xfsprogs rsyslog logrotate crontabs file kernel-headers
CentOS 8:
allready installed before i try the installation.
Got a DirectAdmin on CentOS 8 now:
[root@server ~]# uname -a
Linux serverXXX.poralix.net 4.18.0-80.7.1.el8_0.x86_64 #1 SMP Sat Aug 3 15:14:00 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@server ~]# /usr/local/directadmin/directadmin v
Version: DirectAdmin v.1.59.1
[root@server ~]#
with
Installed version of DirectAdmin: 1.59.1
Installed version of Let's Encrypt client: 1.1.30
Installed version of OpenLiteSpeed: 1.6.1
Installed version of ProFTPD: 1.3.6
Installed version of libpng: 1.6.37
Installed version of libwebp: 1.0.2
Installed version of libspf2: 1.2.10
Installed version of libjpeg: 9c
Installed version of ICU4C: 64.1
Installed version of libsodium: 1.0.18
Installed version of libxml2: 2.9.9
Installed version of libxslt: 1.1.33
Installed version of iconv: 1.15
Installed version of PCRE: 8.43
Installed version of PCRE2: 10.33
Installed version of curl: 7.66.0
Installed version of FreeType: 2.10.1
Installed version of dovecot: 2.3.7.2
Installed version of dovecot.conf: 0.4
Installed version of Exim: 4.92.3
Installed version of exim.conf: 4.5.18
Installed version of BlockCracking: 1.10
Installed version of Easy Spam Fighter: 1.27
Installed version of SpamAssassin: 3.4.2
Installed version of MariaDB: 10.4.8
Installed version of PHP 5.6: 5.6.40
Installed version of PHP 7.1: 7.1.32
Installed version of PHP 7.2: 7.2.23
Installed version of PHP 7.3: 7.3.10
Installed version of RoundCube webmail: 1.3.10
Installed version of phpMyAdmin: 4.9.1-all-languages
Installed version of ionCube: 10.3.8
It has been a challenge to get all the things installed and configured :D
Still some missing rpm and perl packages.... for example:
# yum install rkhunter
Last metadata expiration check: 0:33:04 ago on Mon 30 Sep 2019 03:02:44 PM +07.
No match for argument: rkhunter
Error: Unable to find a match
and *-devel packages in repositories (?).
rkhunter is now in EPEL playground repo ;)
yum -q list rkhunter --enablerepo=PowerTools,epel,epel-testing,epel-playground,remi,remi-safe
Available        Packages
rkhunter.noarch  1.4.6-5.epel8.playground  epel-playground
FYI, CentOS 8 moved -devel packages to new PowerTools repository so they might be in there ;)
available -devel packages in PowerTools repo right now
yum -q list available --disablerepo=* --enablerepo=PowerTools
Available                                 Packages
CUnit-devel.x86_64                        2.1.3-17.el8                        PowerTools
GConf2-devel.x86_64                       3.2.6-22.el8                        PowerTools
LibRaw-devel.x86_64                       0.19.1-1.el8                        PowerTools
ModemManager-devel.x86_64                 1.8.0-1.el8                         PowerTools
ModemManager-glib-devel.x86_64            1.8.0-1.el8                         PowerTools
NetworkManager-libnm-devel.x86_64         1:1.14.0-14.el8                     PowerTools
OpenEXR-devel.x86_64                      2.2.0-11.el8                        PowerTools
OpenIPMI-devel.x86_64                     2.0.25-4.el8                        PowerTools
PackageKit-glib-devel.x86_64              1.1.12-2.el8                        PowerTools
SDL2.x86_64                               2.0.8-7.el8                         PowerTools
SDL2-devel.x86_64                         2.0.8-7.el8                         PowerTools
SDL2-static.x86_64                        2.0.8-7.el8                         PowerTools
SuperLU.x86_64                            5.2.0-7.el8                         PowerTools
SuperLU-devel.x86_64                      5.2.0-7.el8                         PowerTools
Xaw3d-devel.x86_64                        1.6.2-14.el8                        PowerTools
accountsservice-devel.x86_64              0.6.50-6.el8                        PowerTools
asciidoc-doc.noarch                       8.6.10-0.5.20180627gitf7c2274.el8   PowerTools
aspell-devel.x86_64                       12:0.60.6.1-21.el8                  PowerTools
atkmm-devel.x86_64                        2.24.2-6.el8                        PowerTools
atkmm-doc.noarch                          2.24.2-6.el8                        PowerTools
augeas-devel.x86_64                       1.10.1-8.el8                        PowerTools
autoconf-archive.noarch                   2018.03.13-1.el8                    PowerTools
autoconf213.noarch                        2.13-39.el8                         PowerTools
autogen.x86_64                            5.18.12-7.el8                       PowerTools
autotrace.x86_64                          0.31.1-52.el8                       PowerTools
avahi-compat-howl.x86_64                  0.7-19.el8                          PowerTools
avahi-compat-howl-devel.x86_64            0.7-19.el8                          PowerTools
avahi-compat-libdns_sd.x86_64             0.7-19.el8                          PowerTools
avahi-compat-libdns_sd-devel.x86_64       0.7-19.el8                          PowerTools
avahi-devel.x86_64                        0.7-19.el8                          PowerTools
babl-devel.x86_64                         0.1.52-1.el8                        PowerTools
babl-devel-docs.noarch                    0.1.52-1.el8                        PowerTools
bcc-doc.noarch                            0.7.0-5.el8                         PowerTools
bison-devel.x86_64                        3.0.4-10.el8                        PowerTools
blas-devel.x86_64                         3.8.0-8.el8                         PowerTools
bluez-libs-devel.x86_64                   5.50-1.el8                          PowerTools
boost-build.noarch                        1.66.0-6.el8                        PowerTools
boost-doc.noarch                          1.66.0-6.el8                        PowerTools
boost-examples.noarch                     1.66.0-6.el8                        PowerTools
boost-graph-mpich.x86_64                  1.66.0-6.el8                        PowerTools
boost-graph-openmpi.x86_64                1.66.0-6.el8                        PowerTools
boost-jam.x86_64                          1.66.0-6.el8                        PowerTools
boost-mpich.x86_64                        1.66.0-6.el8                        PowerTools
boost-mpich-devel.x86_64                  1.66.0-6.el8                        PowerTools
boost-mpich-python3.x86_64                1.66.0-6.el8                        PowerTools
boost-numpy3.x86_64                       1.66.0-6.el8                        PowerTools
boost-openmpi.x86_64                      1.66.0-6.el8                        PowerTools
boost-openmpi-devel.x86_64                1.66.0-6.el8                        PowerTools
boost-openmpi-python3.x86_64              1.66.0-6.el8                        PowerTools
boost-python3.x86_64                      1.66.0-6.el8                        PowerTools
boost-python3-devel.x86_64                1.66.0-6.el8                        PowerTools
boost-static.x86_64                       1.66.0-6.el8                        PowerTools
brasero-devel.x86_64                      3.12.2-4.el8                        PowerTools
brlapi-devel.x86_64                       0.6.7-28.el8                        PowerTools
brotli-devel.x86_64                       1.0.6-1.el8                         PowerTools
cairomm-devel.x86_64                      1.12.0-7.el8                        PowerTools
cairomm-doc.noarch                        1.12.0-7.el8                        PowerTools
cdparanoia-devel.x86_64                   10.2-27.el8                         PowerTools
celt051-devel.x86_64                      0.5.1.3-15.el8                      PowerTools
clucene-core-devel.x86_64                 2.3.3.4-31.20130812.e8e3d20git.el8  PowerTools
clutter-devel.x86_64                      1.26.2-6.el8                        PowerTools
clutter-doc.x86_64                        1.26.2-6.el8                        PowerTools
clutter-gst3-devel.x86_64                 3.0.26-1.el8                        PowerTools
clutter-gtk-devel.x86_64                  1.8.4-3.el8                         PowerTools
codemodel.noarch                          2.6-24.el8                          PowerTools
cogl-devel.x86_64                         1.22.2-10.el8                       PowerTools
cogl-doc.noarch                           1.22.2-10.el8                       PowerTools
colord-devel.x86_64                       1.4.2-1.el8                         PowerTools
colord-devel-docs.noarch                  1.4.2-1.el8                         PowerTools
colord-gtk-devel.x86_64                   0.1.26-8.el8                        PowerTools
compat-guile18.x86_64                     1.8.8-22.el8                        PowerTools
compat-guile18-devel.x86_64               1.8.8-22.el8                        PowerTools
cppcheck.x86_64                           1.83-1.el8                          PowerTools
cppunit.x86_64                            1.14.0-4.el8                        PowerTools
cppunit-devel.x86_64                      1.14.0-4.el8                        PowerTools
cppunit-doc.x86_64                        1.14.0-4.el8                        PowerTools
cracklib-devel.x86_64                     2.9.6-15.el8                        PowerTools
crash-devel.x86_64                        7.2.3-18.el8                        PowerTools
ctags-etags.x86_64                        5.8-22.el8                          PowerTools
cups-filters-devel.x86_64                 1.20.0-14.el8                       PowerTools
daxctl-devel.x86_64                       62-2.el8                            PowerTools
dblatex.noarch                            0.3.10-8.el8                        PowerTools
dbus-c++.x86_64                           0.9.0-17.el8                        PowerTools
dbus-c++-devel.x86_64                     0.9.0-17.el8                        PowerTools
dbus-c++-glib.x86_64                      0.9.0-17.el8                        PowerTools
dconf-devel.x86_64                        0.28.0-3.el8                        PowerTools
dejagnu.noarch                            1:1.6.1-2.el8                       PowerTools
devhelp-devel.x86_64                      1:3.28.1-5.el8                      PowerTools
device-mapper-devel.x86_64                8:1.02.155-6.el8                    PowerTools
device-mapper-event-devel.x86_64          8:1.02.155-6.el8                    PowerTools
device-mapper-multipath-devel.x86_64      0.7.8-7.el8                         PowerTools
docbook-style-dsssl.noarch                1.79-25.el8                         PowerTools
docbook-utils.noarch                      0.6.14-44.el8                       PowerTools
docbook2X.x86_64                          0.8.8-29.el8                        PowerTools
docbook5-schemas.noarch                   5.0-17.el8                          PowerTools
dotconf-devel.x86_64                      1.3-18.el8                          PowerTools
dovecot-devel.x86_64                      1:2.2.36-5.el8                      PowerTools
doxygen.x86_64                            1:1.8.14-9.el8                      PowerTools
doxygen-doxywizard.x86_64                 1:1.8.14-9.el8                      PowerTools
doxygen-latex.x86_64                      1:1.8.14-9.el8                      PowerTools
drpm-devel.x86_64                         0.3.0-14.el8                        PowerTools
dtc.x86_64                                1.4.6-1.el8                         PowerTools
dyninst-devel.x86_64                      9.3.2-12.el8                        PowerTools
dyninst-doc.x86_64                        9.3.2-12.el8                        PowerTools
dyninst-static.x86_64                     9.3.2-12.el8                        PowerTools
dyninst-testsuite.x86_64                  9.3.2-12.el8                        PowerTools
eglexternalplatform-devel.noarch          1.1-0.1.20180916git7c8f8e2.el8      PowerTools
eigen3-devel.noarch                       3.3.4-6.el8                         PowerTools
elfutils-devel-static.x86_64              0.174-6.el8                         PowerTools
elfutils-libelf-devel-static.x86_64       0.174-6.el8                         PowerTools
elinks.x86_64                             0.12-0.58.pre6.el8                  PowerTools
enca.x86_64                               1.19-1.el8                          PowerTools
enca-devel.x86_64                         1.19-1.el8                          PowerTools
enchant-devel.x86_64                      1:1.6.0-21.el8                      PowerTools
enchant2-devel.x86_64                     2.2.3-2.el8                         PowerTools
evolution-data-server-doc.noarch          3.28.5-9.el8                        PowerTools
evolution-data-server-perl.x86_64         3.28.5-9.el8                        PowerTools
evolution-data-server-tests.x86_64        3.28.5-9.el8                        PowerTools
evolution-devel.x86_64                    3.28.5-6.el8                        PowerTools
execstack.x86_64                          0.5.0-15.el8                        PowerTools
exempi-devel.x86_64                       2.4.5-2.el8                         PowerTools
exiv2-devel.x86_64                        0.26-10.el8                         PowerTools
exiv2-doc.noarch                          0.26-10.el8                         PowerTools
fftw-doc.noarch                           3.3.5-11.el8                        PowerTools
file-devel.x86_64                         5.33-8.el8                          PowerTools
fipscheck-devel.x86_64                    1.5.0-4.el8                         PowerTools
flac.x86_64                               1.3.2-9.el8                         PowerTools
flac-devel.x86_64                         1.3.2-9.el8                         PowerTools
flex-devel.x86_64                         2.6.1-9.el8                         PowerTools
flite.x86_64                              1.3-31.el8                          PowerTools
flite-devel.x86_64                        1.3-31.el8                          PowerTools
fltk-devel.x86_64                         1.3.4-5.el8                         PowerTools
fontawesome-fonts-web.noarch              4.7.0-4.el8                         PowerTools
fontconfig-devel-doc.noarch               2.13.1-3.el8                        PowerTools
fontforge.x86_64                          20170731-8.el8.0.2                  PowerTools
fontpackages-devel.noarch                 1.44-22.el8                         PowerTools
freeipmi-devel.x86_64                     1.6.1-1.el8                         PowerTools
freerdp-devel.x86_64                      2:2.0.0-46.rc4.el8                  PowerTools
frei0r-devel.x86_64                       1.6.1-6.el8                         PowerTools
fuse-sshfs.x86_64                         2.8-5.el8                           PowerTools
gamin-devel.x86_64                        0.1.10-31.el8                       PowerTools
gc-devel.x86_64                           7.6.4-3.el8                         PowerTools
gcc-plugin-devel.x86_64                   8.2.1-3.5.el8                       PowerTools
gdk-pixbuf2-xlib.x86_64                   2.36.12-2.el8                       PowerTools
gdk-pixbuf2-xlib-devel.x86_64             2.36.12-2.el8                       PowerTools
gegl04-devel.x86_64                       0.4.4-6.el8                         PowerTools
geoclue2-devel.x86_64                     2.4.10-1.el8                        PowerTools
gflags.x86_64                             2.1.2-6.el8                         PowerTools
gflags-devel.x86_64                       2.1.2-6.el8                         PowerTools
ghostscript-doc.noarch                    9.25-2.el8_0.1                      PowerTools
ghostscript-tools-dvipdf.x86_64           9.25-2.el8_0.1                      PowerTools
ghostscript-tools-fonts.x86_64            9.25-2.el8_0.1                      PowerTools
ghostscript-tools-printing.x86_64         9.25-2.el8_0.1                      PowerTools
ghostscript-x11.x86_64                    9.25-2.el8_0.1                      PowerTools
giflib-devel.x86_64                       5.1.4-3.el8                         PowerTools
gjs-devel.x86_64                          1.52.5-2.el8                        PowerTools
glade-devel.x86_64                        3.22.1-1.el8                        PowerTools
glew-devel.x86_64                         2.0.0-6.el8                         PowerTools
glib2-doc.noarch                          2.56.4-1.el8                        PowerTools
glib2-static.x86_64                       2.56.4-1.el8                        PowerTools
glibc-static.x86_64                       2.28-42.el8.1                       PowerTools
glibmm24-devel.x86_64                     2.56.0-1.el8                        PowerTools
glibmm24-doc.noarch                       2.56.0-1.el8                        PowerTools
glm-devel.noarch                          0.9.8.5-2.el8                       PowerTools
glm-doc.noarch                            0.9.8.5-2.el8                       PowerTools
glog.x86_64                               0.3.5-3.el8                         PowerTools
glog-devel.x86_64                         0.3.5-3.el8                         PowerTools
glusterfs-api-devel.x86_64                3.12.2-40.2.el8                     PowerTools
glusterfs-devel.x86_64                    3.12.2-40.2.el8                     PowerTools
gmock.x86_64                              1.8.0-5.el8                         PowerTools
gmock-devel.x86_64                        1.8.0-5.el8                         PowerTools
gnome-bluetooth-libs-devel.x86_64         1:3.28.2-2.el8                      PowerTools
gnome-common.noarch                       3.18.0-5.el8                        PowerTools
gnome-menus-devel.x86_64                  3.13.3-10.el8                       PowerTools
gnu-efi.x86_64                            1:3.0.8-2.el8                       PowerTools
gnu-efi-devel.x86_64                      1:3.0.8-2.el8                       PowerTools
gnuplot-doc.noarch                        5.2.4-1.el8                         PowerTools
go-compilers-golang-compiler.x86_64       1-20.el8                            PowerTools
gobject-introspection-devel.x86_64        1.56.1-1.el8                        PowerTools
google-noto-sans-cjk-jp-fonts.noarch      20170602-9.el8                      PowerTools
google-roboto-slab-fonts.noarch           1.100263-0.7.20150923git.el8        PowerTools
gperf.x86_64                              3.1-5.el8                           PowerTools
gpgme-devel.x86_64                        1.10.0-6.el8.0.1                    PowerTools
gpgmepp-devel.x86_64                      1.10.0-6.el8.0.1                    PowerTools
graphviz-devel.x86_64                     2.40.1-39.el8                       PowerTools
graphviz-doc.x86_64                       2.40.1-39.el8                       PowerTools
graphviz-gd.x86_64                        2.40.1-39.el8                       PowerTools
grilo-devel.x86_64                        0.3.6-2.el8                         PowerTools
groff.x86_64                              1.22.3-18.el8                       PowerTools
gsm-devel.x86_64                          1.0.17-5.el8                        PowerTools
gspell-devel.x86_64                       1.8.1-1.el8                         PowerTools
gspell-doc.noarch                         1.8.1-1.el8                         PowerTools
gssdp-devel.x86_64                        1.0.2-6.el8                         PowerTools
gssdp-docs.noarch                         1.0.2-6.el8                         PowerTools
gstreamer1-plugins-bad-free-devel.x86_64  1.14.0-5.el8                        PowerTools
gtest.x86_64                              1.8.0-5.el8                         PowerTools
gtest-devel.x86_64                        1.8.0-5.el8                         PowerTools
gtk-doc.x86_64                            1.28-1.el8                          PowerTools
gtkmm24-devel.x86_64                      2.24.5-5.el8                        PowerTools
gtkmm24-docs.noarch                       2.24.5-5.el8                        PowerTools
gtkmm30-devel.x86_64                      3.22.2-2.el8                        PowerTools
gtkmm30-doc.noarch                        3.22.2-2.el8                        PowerTools
gtksourceview3-devel.x86_64               3.24.9-1.el8                        PowerTools
gtkspell-devel.x86_64                     2.0.16-15.el8                       PowerTools
gtkspell3-devel.x86_64                    3.0.9-5.el8                         PowerTools
guile-devel.x86_64                        5:2.0.14-7.el8                      PowerTools
gupnp-devel.x86_64                        1.0.3-2.el8                         PowerTools
gupnp-igd-devel.x86_64                    0.2.5-4.el8                         PowerTools
help2man.noarch                           1.47.6-1.el8                        PowerTools
hesiod-devel.x86_64                       3.2.1-11.el8                        PowerTools
hwloc-devel.x86_64                        1.11.9-2.el8                        PowerTools
hyphen-devel.x86_64                       2.8.8-9.el8                         PowerTools
ibus-devel.x86_64                         1.5.19-4.el8                        PowerTools
ibus-devel-docs.noarch                    1.5.19-4.el8                        PowerTools
ilmbase-devel.x86_64                      2.2.0-11.el8                        PowerTools
ima-evm-utils-devel.x86_64                1.1-4.el8                           PowerTools
imake.x86_64                              1.0.7-11.el8                        PowerTools
infiniband-diags-compat.x86_64            2.1.0-1.el8                         PowerTools
infiniband-diags-devel.x86_64             2.1.0-1.el8                         PowerTools
infiniband-diags-devel-static.x86_64      2.1.0-1.el8                         PowerTools
iproute-devel.x86_64                      4.18.0-11.el8                       PowerTools
irssi-devel.x86_64                        1.1.1-2.el8                         PowerTools
isl-devel.x86_64                          0.16.1-6.el8                        PowerTools
iso-codes-devel.noarch                    3.79-2.el8                          PowerTools
istack-commons.noarch                     2.21-9.el8                          PowerTools
jasper-devel.x86_64                       2.0.14-4.el8                        PowerTools
jbigkit-devel.x86_64                      2.1-14.el8                          PowerTools
jimtcl-devel.x86_64                       0.77-5.el8                          PowerTools
jna.x86_64                                4.5.1-4.el8                         PowerTools
js-uglify.noarch                          2.8.29-1.el8                        PowerTools
json-c-devel.x86_64                       0.13.1-0.2.el8                      PowerTools
json-c-doc.noarch                         0.13.1-0.2.el8                      PowerTools
kernel-tools-libs-devel.x86_64            4.18.0-80.7.1.el8_0                 PowerTools
keybinder3-devel.x86_64                   0.3.2-4.el8                         PowerTools
keybinder3-doc.noarch                     0.3.2-4.el8                         PowerTools
kmod-devel.x86_64                         25-11.el8_0.2                       PowerTools
ladspa.x86_64                             1.13-20.el8                         PowerTools
ladspa-devel.x86_64                       1.13-20.el8                         PowerTools
lame-devel.x86_64                         3.100-6.el8                         PowerTools
lapack-devel.x86_64                       3.8.0-8.el8                         PowerTools
lapack-static.x86_64                      3.8.0-8.el8                         PowerTools
latex2html.noarch                         2018.2-2.el8                        PowerTools
lcms2-devel.x86_64                        2.9-2.el8                           PowerTools
ldns-devel.x86_64                         1.7.0-20.el8                        PowerTools
lensfun.x86_64                            0.3.2-14.el8                        PowerTools
lensfun-devel.x86_64                      0.3.2-14.el8                        PowerTools
leptonica.x86_64                          1.76.0-2.el8                        PowerTools
leptonica-devel.x86_64                    1.76.0-2.el8                        PowerTools
libEMF.x86_64                             1.0.9-5.el8                         PowerTools
libEMF-devel.x86_64                       1.0.9-5.el8                         PowerTools
libGLEW.x86_64                            2.0.0-6.el8                         PowerTools
libIDL.x86_64                             0.8.14-15.el8                       PowerTools
libIDL-devel.x86_64                       0.8.14-15.el8                       PowerTools
libXNVCtrl-devel.x86_64                   352.21-9.el8                        PowerTools
libXdmcp-devel.x86_64                     1.1.2-11.el8                        PowerTools
libXfont2-devel.x86_64                    2.0.3-2.el8                         PowerTools
libXres-devel.x86_64                      1.2.0-4.el8                         PowerTools
libaec.x86_64                             1.0.2-3.el8                         PowerTools
libaec-devel.x86_64                       1.0.2-3.el8                         PowerTools
libao-devel.x86_64                        1.2.0-10.el8                        PowerTools
libappindicator-gtk3-devel.x86_64         12.10.0-19.el8                      PowerTools
libappstream-glib-devel.x86_64            0.7.14-3.el8                        PowerTools
libarchive-devel.x86_64                   3.3.2-3.el8                         PowerTools
libassuan-devel.x86_64                    2.5.1-3.el8                         PowerTools
libasyncns-devel.x86_64                   0.8-14.el8                          PowerTools
libatasmart-devel.x86_64                  0.19-14.el8                         PowerTools
libatomic_ops-devel.x86_64                7.6.2-3.el8                         PowerTools
libbasicobjects-devel.x86_64              0.1.1-39.el8                        PowerTools
libburn-devel.x86_64                      1.4.8-3.el8                         PowerTools
libcacard-devel.x86_64                    3:2.6.1-1.el8                       PowerTools
libcdio-devel.x86_64                      2.0.0-2.el8                         PowerTools
libcdio-paranoia-devel.x86_64             10.2+0.94+2-3.el8                   PowerTools
libcephfs-devel.x86_64                    1:12.2.7-9.el8                      PowerTools
libcephfs2.x86_64                         1:12.2.7-9.el8                      PowerTools
libchamplain.x86_64                       0.12.16-2.el8                       PowerTools
libchamplain-devel.x86_64                 0.12.16-2.el8                       PowerTools
libchamplain-gtk.x86_64                   0.12.16-2.el8                       PowerTools
libcmocka.x86_64                          1.1.2-1.el8                         PowerTools
libcmocka-devel.x86_64                    1.1.2-1.el8                         PowerTools
libcollection-devel.x86_64                0.7.0-39.el8                        PowerTools
libconfig-devel.x86_64                    1.5-9.el8                           PowerTools
libcroco-devel.x86_64                     0.6.12-4.el8                        PowerTools
libdaemon-devel.x86_64                    0.14-15.el8                         PowerTools
libdap.x86_64                             3.19.1-2.el8                        PowerTools
libdap-devel.x86_64                       3.19.1-2.el8                        PowerTools
libdatrie-devel.x86_64                    0.2.9-7.el8                         PowerTools
libdb-cxx.x86_64                          5.3.28-36.el8                       PowerTools
libdb-cxx-devel.x86_64                    5.3.28-36.el8                       PowerTools
libdb-devel-doc.noarch                    5.3.28-36.el8                       PowerTools
libdb-sql.x86_64                          5.3.28-36.el8                       PowerTools
libdb-sql-devel.x86_64                    5.3.28-36.el8                       PowerTools
libdbusmenu-devel.x86_64                  16.04.0-12.el8                      PowerTools
libdbusmenu-doc.noarch                    16.04.0-12.el8                      PowerTools
libdbusmenu-gtk3-devel.x86_64             16.04.0-12.el8                      PowerTools
libdnet-devel.x86_64                      1.12-26.el8                         PowerTools
libdv-devel.x86_64                        1.0.0-27.el8                        PowerTools
libdvdread-devel.x86_64                   5.0.3-9.el8                         PowerTools
libdwarf-devel.x86_64                     20180129-4.el8                      PowerTools
libdwarf-static.x86_64                    20180129-4.el8                      PowerTools
libdwarf-tools.x86_64                     20180129-4.el8                      PowerTools
libedit-devel.x86_64                      3.1-23.20170329cvs.el8              PowerTools
libeot.x86_64                             0.01-9.el8                          PowerTools
libetonyek-devel.x86_64                   0.1.8-1.el8                         PowerTools
libevdev-devel.x86_64                     1.5.9-5.el8                         PowerTools
libexif-devel.x86_64                      0.6.21-16.el8                       PowerTools
libfabric-devel.x86_64                    1.6.2-1.el8                         PowerTools
libfdt.x86_64                             1.4.6-1.el8                         PowerTools
libfdt-devel.x86_64                       1.4.6-1.el8                         PowerTools
libfontenc-devel.x86_64                   1.1.3-8.el8                         PowerTools
libgee-devel.x86_64                       0.20.1-1.el8                        PowerTools
libgexiv2-devel.x86_64                    0.10.8-2.el8                        PowerTools
libgit2-devel.x86_64                      0.26.6-3.el8                        PowerTools
libgit2-glib-devel.x86_64                 0.26.4-2.el8                        PowerTools
libgnomekbd-devel.x86_64                  3.26.0-4.el8                        PowerTools
libgphoto2-devel.x86_64                   2.5.16-3.el8                        PowerTools
libgpod-devel.x86_64                      0.8.3-23.el8                        PowerTools
libgpod-doc.x86_64                        0.8.3-23.el8                        PowerTools
libgsf-devel.x86_64                       1.14.41-5.el8                       PowerTools
libgtop2-devel.x86_64                     2.38.0-3.el8                        PowerTools
libgudev-devel.x86_64                     232-4.el8                           PowerTools
libgusb-devel.x86_64                      0.3.0-1.el8                         PowerTools
libgxps-devel.x86_64                      0.3.0-5.el8                         PowerTools
libidn-devel.x86_64                       1.34-5.el8                          PowerTools
libidn2-devel.x86_64                      2.0.5-1.el8                         PowerTools
libiec61883-devel.x86_64                  1.2.0-18.el8                        PowerTools
libimobiledevice-devel.x86_64             1.2.0-16.el8                        PowerTools
libindicator-gtk3-devel.x86_64            12.10.1-14.el8                      PowerTools
libini_config-devel.x86_64                1.3.1-39.el8                        PowerTools
libinput-devel.x86_64                     1.12.3-3.el8                        PowerTools
libisoburn-devel.x86_64                   1.4.8-4.el8                         PowerTools
libisofs-devel.x86_64                     1.4.8-3.el8                         PowerTools
libknet1.x86_64                           1.4-3.el8                           PowerTools
libknet1-devel.x86_64                     1.4-3.el8                           PowerTools
libksba-devel.x86_64                      1.3.5-7.el8                         PowerTools
liblangtag-devel.x86_64                   0.6.2-5.el8                         PowerTools
liblangtag-doc.noarch                     0.6.2-5.el8                         PowerTools
liblangtag-gobject.x86_64                 0.6.2-5.el8                         PowerTools
liblockfile-devel.x86_64                  1.14-1.el8                          PowerTools
libmad-devel.x86_64                       0.15.1b-24.el8                      PowerTools
libmaxminddb-devel.x86_64                 1.2.0-6.el8                         PowerTools
libmemcached-devel.x86_64                 1.0.18-15.el8                       PowerTools
libmicrohttpd-devel.x86_64                1:0.9.59-2.el8                      PowerTools
libmicrohttpd-doc.noarch                  1:0.9.59-2.el8                      PowerTools
libmnl-devel.x86_64                       1.0.4-6.el8                         PowerTools
libmodulemd-devel.x86_64                  2.0.0-5.el8                         PowerTools
libmount-devel.x86_64                     2.32.1-8.el8                        PowerTools
libmpc-devel.x86_64                       1.0.2-9.el8                         PowerTools
libmpcdec-devel.x86_64                    1.2.6-20.el8                        PowerTools
libmspack-devel.x86_64                    0.7-0.1.alpha.el8.3                 PowerTools
libmtp-devel.x86_64                       1.1.14-3.el8                        PowerTools
libmusicbrainz5-devel.x86_64              5.1.0-10.el8                        PowerTools
libnet-devel.x86_64                       1.1.6-15.el8                        PowerTools
libnetfilter_conntrack-devel.x86_64       1.0.6-5.el8                         PowerTools
libnetfilter_queue-devel.x86_64           1.0.2-11.el8                        PowerTools
libnfnetlink-devel.x86_64                 1.0.1-13.el8                        PowerTools
libnfsidmap-devel.x86_64                  1:2.3.3-14.el8_0                    PowerTools
libnghttp2-devel.x86_64                   1.33.0-1.el8                        PowerTools
libnice-devel.x86_64                      0.1.14-7.20180504git34d6044.el8     PowerTools
libnma-devel.x86_64                       1.8.10-5.el8                        PowerTools
libnsl2-devel.x86_64                      1.2.0-2.20180605git4a062cf.el8      PowerTools
libodfgen-devel.x86_64                    0.1.6-11.el8                        PowerTools
libogg-devel.x86_64                       2:1.3.2-10.el8                      PowerTools
libogg-devel-docs.noarch                  2:1.3.2-10.el8                      PowerTools
liboggz.x86_64                            1.1.1-14.el8                        PowerTools
libopenraw-devel.x86_64                   0.1.2-4.el8                         PowerTools
libopenraw-gnome.x86_64                   0.1.2-4.el8                         PowerTools
libopenraw-gnome-devel.x86_64             0.1.2-4.el8                         PowerTools
libpaper-devel.x86_64                     1.1.24-22.el8                       PowerTools
libpath_utils-devel.x86_64                0.2.1-39.el8                        PowerTools
libpcap-devel.x86_64                      14:1.9.0-1.el8                      PowerTools
libpciaccess-devel.x86_64                 0.14-1.el8                          PowerTools
libpeas-devel.x86_64                      1.22.0-6.el8                        PowerTools
libpfm-static.x86_64                      4.10.1-1.el8                        PowerTools
libplist-devel.x86_64                     2.0.0-10.el8                        PowerTools
libpmem-debug.x86_64                      1.5-2.el8                           PowerTools
libpmemblk-debug.x86_64                   1.5-2.el8                           PowerTools
libpmemlog-debug.x86_64                   1.5-2.el8                           PowerTools
libpmemobj-debug.x86_64                   1.5-2.el8                           PowerTools
libpmempool-debug.x86_64                  1.5-2.el8                           PowerTools
libproxy-devel.x86_64                     0.4.15-5.2.el8                      PowerTools
libpsm2-devel.x86_64                      10.3.58-2.el8                       PowerTools
libpurple-devel.x86_64                    2.13.0-4.el8                        PowerTools
libpwquality-devel.x86_64                 1.4.0-9.el8                         PowerTools
libqhull.x86_64                           2015.2-5.el8                        PowerTools
libqhull_p.x86_64                         2015.2-5.el8                        PowerTools
libqhull_r.x86_64                         2015.2-5.el8                        PowerTools
libquvi-devel.x86_64                      0.9.4-12.el8                        PowerTools
librabbitmq-devel.x86_64                  0.9.0-1.el8                         PowerTools
librados-devel.x86_64                     1:12.2.7-9.el8                      PowerTools
libradosstriper-devel.x86_64              1:12.2.7-9.el8                      PowerTools
libradosstriper1.x86_64                   1:12.2.7-9.el8                      PowerTools
libraw1394-devel.x86_64                   2.1.2-5.el8                         PowerTools
librbd-devel.x86_64                       1:12.2.7-9.el8                      PowerTools
librdkafka-devel.x86_64                   0.11.4-1.el8                        PowerTools
libref_array-devel.x86_64                 0.1.5-39.el8                        PowerTools
libreoffice-sdk.x86_64                    1:6.0.6.1-13.el8                    PowerTools
libreoffice-sdk-doc.x86_64                1:6.0.6.1-13.el8                    PowerTools
librevenge-devel.x86_64                   0.0.4-11.el8                        PowerTools
librpmem-debug.x86_64                     1.5-2.el8                           PowerTools
librx.x86_64                              1.5-31.el8                          PowerTools
librx-devel.x86_64                        1.5-31.el8                          PowerTools
libsamplerate-devel.x86_64                0.1.9-1.el8                         PowerTools
libsass.x86_64                            3.4.5-5.el8                         PowerTools
libsass-devel.x86_64                      3.4.5-5.el8                         PowerTools
libseccomp-devel.x86_64                   2.3.3-3.el8                         PowerTools
libsepol-static.x86_64                    2.8-2.el8                           PowerTools
libshout-devel.x86_64                     2.2.2-19.el8                        PowerTools
libsigc++20-devel.x86_64                  2.10.0-5.el8                        PowerTools
libsigc++20-doc.noarch                    2.10.0-5.el8                        PowerTools
libsigsegv-devel.x86_64                   2.11-5.el8                          PowerTools
libsmbclient-devel.x86_64                 4.9.1-8.el8                         PowerTools
libsndfile-devel.x86_64                   1.0.28-8.el8                        PowerTools
libspectre-devel.x86_64                   0.2.8-5.el8                         PowerTools
libsrtp-devel.x86_64                      1.5.4-8.el8                         PowerTools
libsss_nss_idmap-devel.x86_64             2.0.0-43.el8_0.3                    PowerTools
libstdc++-static.x86_64                   8.2.1-3.5.el8                       PowerTools
libstemmer-devel.x86_64                   0-10.585svn.el8                     PowerTools
libsysfs-devel.x86_64                     2.1.0-24.el8                        PowerTools
libthai-devel.x86_64                      0.1.27-2.el8                        PowerTools
libtheora-devel.x86_64                    1:1.1.1-21.el8                      PowerTools
libtiff-tools.x86_64                      4.0.9-13.el8                        PowerTools
libucil-devel.x86_64                      0.9.10-16.el8                       PowerTools
libunicap-devel.x86_64                    0.9.12-21.el8                       PowerTools
libuninameslist.x86_64                    20170701-4.el8                      PowerTools
libunistring-devel.x86_64                 0.9.9-3.el8                         PowerTools
libusb-devel.x86_64                       1:0.1.5-12.el8                      PowerTools
libusbmuxd-devel.x86_64                   1.0.10-9.el8                        PowerTools
libutempter-devel.x86_64                  1.1.6-14.el8                        PowerTools
libv4l-devel.x86_64                       1.14.2-3.el8                        PowerTools
libvarlink-devel.x86_64                   16-1.el8                            PowerTools
libvdpau-devel.x86_64                     1.1.1-7.el8                         PowerTools
libvisio-devel.x86_64                     0.1.6-2.el8                         PowerTools
libvisual-devel.x86_64                    1:0.4.0-24.el8                      PowerTools
libvmem-debug.x86_64                      1.5-2.el8                           PowerTools
libvmmalloc-debug.x86_64                  1.5-2.el8                           PowerTools
libvncserver-devel.x86_64                 0.9.11-9.el8                        PowerTools
libvorbis-devel.x86_64                    1:1.3.6-1.el8                       PowerTools
libvorbis-devel-docs.noarch               1:1.3.6-1.el8                       PowerTools
libvpx-devel.x86_64                       1.7.0-6.el8                         PowerTools
libwacom-devel.x86_64                     0.31-1.el8                          PowerTools
libwbclient-devel.x86_64                  4.9.1-8.el8                         PowerTools
libwmf-devel.x86_64                       0.2.9-4.el8                         PowerTools
libwnck3-devel.x86_64                     3.24.1-2.el8                        PowerTools
libwpd-devel.x86_64                       0.10.2-2.el8                        PowerTools
libwpd-doc.noarch                         0.10.2-2.el8                        PowerTools
libwpg-devel.x86_64                       0.3.2-1.el8                         PowerTools
libwpg-doc.noarch                         0.3.2-1.el8                         PowerTools
libwps-devel.x86_64                       0.4.9-1.el8                         PowerTools
libwps-doc.noarch                         0.4.9-1.el8                         PowerTools
libwsman-devel.x86_64                     2.6.5-5.el8                         PowerTools
libxcrypt-static.x86_64                   4.1.1-4.el8                         PowerTools
libxkbcommon-x11-devel.x86_64             0.8.2-1.el8                         PowerTools
libxkbfile-devel.x86_64                   1.0.9-9.el8                         PowerTools
libxklavier-devel.x86_64                  5.4-11.el8                          PowerTools
libyaml-devel.x86_64                      0.1.7-5.el8                         PowerTools
linuxdoc-tools.x86_64                     0.9.72-5.el8                        PowerTools
lockdev-devel.x86_64                      1.0.4-0.28.20111007git.el8          PowerTools
lttng-ust-devel.x86_64                    2.8.1-9.el8                         PowerTools
lua-devel.x86_64                          5.3.4-10.el8                        PowerTools
lua-filesystem.x86_64                     1.6.3-7.el8                         PowerTools
lua-lunit.noarch                          0.5-13.el8                          PowerTools
lua-posix.x86_64                          33.3.1-9.el8                        PowerTools
lvm2-devel.x86_64                         8:2.03.02-6.el8                     PowerTools
lynx.x86_64                               2.8.9-2.el8                         PowerTools
memkind-devel.x86_64                      1.7.0-3.el8                         PowerTools
mesa-libGLES-devel.x86_64                 18.3.1-5.el8_0                      PowerTools
mesa-libOSMesa-devel.x86_64               18.3.1-5.el8_0                      PowerTools
mesa-libgbm-devel.x86_64                  18.3.1-5.el8_0                      PowerTools
meson.noarch                              0.49.2-1.el8                        PowerTools
metis.x86_64                              5.1.0-17.el8                        PowerTools
metis-devel.x86_64                        5.1.0-17.el8                        PowerTools
mingw-binutils-generic.x86_64             2.30-1.el8                          PowerTools
mingw-filesystem-base.noarch              104-1.el8                           PowerTools
mingw32-binutils.x86_64                   2.30-1.el8                          PowerTools
mingw32-bzip2.noarch                      1.0.6-11.el8                        PowerTools
mingw32-bzip2-static.noarch               1.0.6-11.el8                        PowerTools
mingw32-cairo.noarch                      1.14.10-4.el8                       PowerTools
mingw32-cpp.x86_64                        7.2.0-2.el8                         PowerTools
mingw32-crt.noarch                        5.0.2-2.el8                         PowerTools
mingw32-expat.noarch                      2.2.4-3.el8                         PowerTools
mingw32-filesystem.noarch                 104-1.el8                           PowerTools
mingw32-fontconfig.noarch                 2.12.6-3.el8                        PowerTools
mingw32-freetype.noarch                   2.8-3.el8                           PowerTools
mingw32-freetype-static.noarch            2.8-3.el8                           PowerTools
mingw32-gcc.x86_64                        7.2.0-2.el8                         PowerTools
mingw32-gcc-c++.x86_64                    7.2.0-2.el8                         PowerTools
mingw32-gettext.noarch                    0.19.7-5.el8                        PowerTools
mingw32-gettext-static.noarch             0.19.7-5.el8                        PowerTools
mingw32-glib2.noarch                      2.56.1-2.el8                        PowerTools
mingw32-glib2-static.noarch               2.56.1-2.el8                        PowerTools
mingw32-gstreamer1.noarch                 1.14.1-2.el8                        PowerTools
mingw32-harfbuzz.noarch                   1.4.8-3.el8                         PowerTools
mingw32-harfbuzz-static.noarch            1.4.8-3.el8                         PowerTools
mingw32-headers.noarch                    5.0.2-2.el8                         PowerTools
mingw32-icu.noarch                        57.1-5.el8                          PowerTools
mingw32-libffi.noarch                     3.1-4.el8                           PowerTools
mingw32-libjpeg-turbo.noarch              1.5.1-5.el8                         PowerTools
mingw32-libjpeg-turbo-static.noarch       1.5.1-5.el8                         PowerTools
mingw32-libpng.noarch                     1.6.29-4.el8                        PowerTools
mingw32-libpng-static.noarch              1.6.29-4.el8                        PowerTools
mingw32-libtiff.noarch                    4.0.9-2.el8                         PowerTools
mingw32-libtiff-static.noarch             4.0.9-2.el8                         PowerTools
mingw32-openssl.noarch                    1.0.2k-1.el8                        PowerTools
mingw32-pcre.noarch                       8.38-4.el8                          PowerTools
mingw32-pcre-static.noarch                8.38-4.el8                          PowerTools
mingw32-pixman.noarch                     0.34.0-5.el8                        PowerTools
mingw32-pkg-config.x86_64                 0.28-11.el8                         PowerTools
mingw32-readline.noarch                   6.2-11.el8                          PowerTools
mingw32-sqlite.noarch                     3.22.0.0-3.el8                      PowerTools
mingw32-sqlite-static.noarch              3.22.0.0-3.el8                      PowerTools
mingw32-termcap.noarch                    1.3.1-23.el8                        PowerTools
mingw32-win-iconv.noarch                  0.0.6-9.el8                         PowerTools
mingw32-win-iconv-static.noarch           0.0.6-9.el8                         PowerTools
mingw32-winpthreads.noarch                5.0.2-2.el8                         PowerTools
mingw32-winpthreads-static.noarch         5.0.2-2.el8                         PowerTools
mingw32-zlib.noarch                       1.2.8-9.el8                         PowerTools
mingw32-zlib-static.noarch                1.2.8-9.el8                         PowerTools
mingw64-binutils.x86_64                   2.30-1.el8                          PowerTools
mingw64-bzip2.noarch                      1.0.6-11.el8                        PowerTools
mingw64-bzip2-static.noarch               1.0.6-11.el8                        PowerTools
mingw64-cairo.noarch                      1.14.10-4.el8                       PowerTools
mingw64-cpp.x86_64                        7.2.0-2.el8                         PowerTools
mingw64-crt.noarch                        5.0.2-2.el8                         PowerTools
mingw64-expat.noarch                      2.2.4-3.el8                         PowerTools
mingw64-filesystem.noarch                 104-1.el8                           PowerTools
mingw64-fontconfig.noarch                 2.12.6-3.el8                        PowerTools
mingw64-freetype.noarch                   2.8-3.el8                           PowerTools
mingw64-freetype-static.noarch            2.8-3.el8                           PowerTools
mingw64-gcc.x86_64                        7.2.0-2.el8                         PowerTools
mingw64-gcc-c++.x86_64                    7.2.0-2.el8                         PowerTools
mingw64-gettext.noarch                    0.19.7-5.el8                        PowerTools
mingw64-gettext-static.noarch             0.19.7-5.el8                        PowerTools
mingw64-glib2.noarch                      2.56.1-2.el8                        PowerTools
mingw64-glib2-static.noarch               2.56.1-2.el8                        PowerTools
mingw64-gstreamer1.noarch                 1.14.1-2.el8                        PowerTools
mingw64-harfbuzz.noarch                   1.4.8-3.el8                         PowerTools
mingw64-harfbuzz-static.noarch            1.4.8-3.el8                         PowerTools
mingw64-headers.noarch                    5.0.2-2.el8                         PowerTools
mingw64-icu.noarch                        57.1-5.el8                          PowerTools
mingw64-libffi.noarch                     3.1-4.el8                           PowerTools
mingw64-libjpeg-turbo.noarch              1.5.1-5.el8                         PowerTools
mingw64-libjpeg-turbo-static.noarch       1.5.1-5.el8                         PowerTools
mingw64-libpng.noarch                     1.6.29-4.el8                        PowerTools
mingw64-libpng-static.noarch              1.6.29-4.el8                        PowerTools
mingw64-libtiff.noarch                    4.0.9-2.el8                         PowerTools
mingw64-libtiff-static.noarch             4.0.9-2.el8                         PowerTools
mingw64-openssl.noarch                    1.0.2k-1.el8                        PowerTools
mingw64-pcre.noarch                       8.38-4.el8                          PowerTools
mingw64-pcre-static.noarch                8.38-4.el8                          PowerTools
mingw64-pixman.noarch                     0.34.0-5.el8                        PowerTools
mingw64-pkg-config.x86_64                 0.28-11.el8                         PowerTools
mingw64-readline.noarch                   6.2-11.el8                          PowerTools
mingw64-sqlite.noarch                     3.22.0.0-3.el8                      PowerTools
mingw64-sqlite-static.noarch              3.22.0.0-3.el8                      PowerTools
mingw64-termcap.noarch                    1.3.1-23.el8                        PowerTools
mingw64-win-iconv.noarch                  0.0.6-9.el8                         PowerTools
mingw64-win-iconv-static.noarch           0.0.6-9.el8                         PowerTools
mingw64-winpthreads.noarch                5.0.2-2.el8                         PowerTools
mingw64-winpthreads-static.noarch         5.0.2-2.el8                         PowerTools
mingw64-zlib.noarch                       1.2.8-9.el8                         PowerTools
mingw64-zlib-static.noarch                1.2.8-9.el8                         PowerTools
mozjs52-devel.x86_64                      52.9.0-1.el8                        PowerTools
mpg123-devel.x86_64                       1.25.10-2.el8                       PowerTools
mtdev-devel.x86_64                        1.1.5-12.el8                        PowerTools
munge-devel.x86_64                        0.5.13-1.el8                        PowerTools
mutter-devel.x86_64                       3.28.3-19.el8_0                     PowerTools
mythes-devel.x86_64                       1.2.4-9.el8                         PowerTools
nasm.x86_64                               2.13.03-2.el8                       PowerTools
nautilus-devel.x86_64                     3.28.1-5.el8                        PowerTools
ndctl-devel.x86_64                        62-2.el8                            PowerTools
neon-devel.x86_64                         0.30.2-6.el8                        PowerTools
netpbm-devel.x86_64                       10.82.00-6.el8                      PowerTools
netpbm-doc.x86_64                         10.82.00-6.el8                      PowerTools
nghttp2.x86_64                            1.33.0-1.el8                        PowerTools
ninja-build.x86_64                        1.8.2-1.el8                         PowerTools
nkf.x86_64                                1:2.1.4-8.el8                       PowerTools
ocaml.x86_64                              4.07.0-3.el8                        PowerTools
ocaml-camlp4.x86_64                       4.07.0-0.gitd32d9973.1.el8.3        PowerTools
ocaml-camlp4-devel.x86_64                 4.07.0-0.gitd32d9973.1.el8.3        PowerTools
ocaml-compiler-libs.x86_64                4.07.0-3.el8                        PowerTools
ocaml-cppo.x86_64                         1.6.4-4.el8                         PowerTools
ocaml-extlib.x86_64                       1.7.5-3.el8                         PowerTools
ocaml-extlib-devel.x86_64                 1.7.5-3.el8                         PowerTools
ocaml-findlib.x86_64                      1.8.0-4.el8                         PowerTools
ocaml-findlib-devel.x86_64                1.8.0-4.el8                         PowerTools
ocaml-labltk.x86_64                       8.06.4-7.el8                        PowerTools
ocaml-labltk-devel.x86_64                 8.06.4-7.el8                        PowerTools
ocaml-ocamlbuild.x86_64                   0.12.0-6.el8                        PowerTools
ocaml-ocamlbuild-devel.x86_64             0.12.0-6.el8                        PowerTools
ocaml-ocamldoc.x86_64                     4.07.0-3.el8                        PowerTools
ocaml-runtime.x86_64                      4.07.0-3.el8                        PowerTools
ocl-icd-devel.x86_64                      2.2.12-1.el8                        PowerTools
oniguruma-devel.x86_64                    6.8.2-1.el8                         PowerTools
openal-soft-devel.x86_64                  1.18.2-7.el8                        PowerTools
openblas-Rblas.x86_64                     0.3.3-2.el8                         PowerTools
openblas-devel.x86_64                     0.3.3-2.el8                         PowerTools
openblas-openmp.x86_64                    0.3.3-2.el8                         PowerTools
openblas-openmp64.x86_64                  0.3.3-2.el8                         PowerTools
openblas-openmp64_.x86_64                 0.3.3-2.el8                         PowerTools
openblas-serial64.x86_64                  0.3.3-2.el8                         PowerTools
openblas-serial64_.x86_64                 0.3.3-2.el8                         PowerTools
openblas-static.x86_64                    0.3.3-2.el8                         PowerTools
openblas-threads64.x86_64                 0.3.3-2.el8                         PowerTools
openblas-threads64_.x86_64                0.3.3-2.el8                         PowerTools
opencl-headers.noarch                     2.2-1.20180306gite986688.el8        PowerTools
opencryptoki-devel.x86_64                 3.10.0-3.el8                        PowerTools
opencv.x86_64                             3.4.1-9.el8                         PowerTools
opencv-devel.x86_64                       3.4.1-9.el8                         PowerTools
openjade.x86_64                           1.3.2-57.el8                        PowerTools
openjpeg2-devel.x86_64                    2.3.0-8.el8                         PowerTools
openldap-servers.x86_64                   2.4.46-9.el8                        PowerTools
openscap-engine-sce-devel.x86_64          1.3.0-7.el8                         PowerTools
opensm-devel.x86_64                       3.3.21-2.el8                        PowerTools
opensp.x86_64                             1.5.2-28.el8                        PowerTools
opensp-devel.x86_64                       1.5.2-28.el8                        PowerTools
opus-devel.x86_64                         1.3-0.4.beta.el8                    PowerTools
pandoc.x86_64                             2.0.6-4.el8                         PowerTools
pandoc-common.noarch                      2.0.6-4.el8                         PowerTools
pangomm-devel.x86_64                      2.40.1-5.el8                        PowerTools
pangomm-doc.noarch                        2.40.1-5.el8                        PowerTools
papi-testsuite.x86_64                     5.6.0-8.el8                         PowerTools
parted-devel.x86_64                       3.2-36.el8                          PowerTools
pcre-static.x86_64                        8.42-4.el8                          PowerTools
pcsc-lite-devel.x86_64                    1.8.23-3.el8                        PowerTools
perl-AnyEvent.x86_64                      7.14-6.el8                          PowerTools
perl-B-Hooks-EndOfScope.noarch            0.21-6.el8                          PowerTools
perl-Canary-Stability.noarch              2012-5.el8                          PowerTools
perl-Capture-Tiny.noarch                  0.46-4.el8                          PowerTools
perl-Class-Accessor.noarch                0.51-2.el8                          PowerTools
perl-Class-Data-Inheritable.noarch        0.08-27.el8                         PowerTools
perl-Class-Factory-Util.noarch            1.7-27.el8                          PowerTools
perl-Class-Method-Modifiers.noarch        2.12-8.el8                          PowerTools
perl-Class-Singleton.noarch               1.5-9.el8                           PowerTools
perl-Class-Tiny.noarch                    1.006-6.el8                         PowerTools
perl-Class-XSAccessor.x86_64              1.19-14.el8                         PowerTools
perl-Clone.x86_64                         0.39-5.el8                          PowerTools
perl-Config-AutoConf.noarch               0.315-2.el8                         PowerTools
perl-Data-UUID.x86_64                     1.221-10.el8                        PowerTools
perl-Date-ISO8601.noarch                  0.005-2.el8                         PowerTools
perl-DateTime.x86_64                      2:1.50-1.el8                        PowerTools
perl-DateTime-Format-Builder.noarch       0.8100-15.el8                       PowerTools
perl-DateTime-Format-HTTP.noarch          0.42-9.el8                          PowerTools
perl-DateTime-Format-ISO8601.noarch       0.08-17.el8                         PowerTools
perl-DateTime-Format-Mail.noarch          1:0.403-6.el8                       PowerTools
perl-DateTime-Format-Strptime.noarch      1:1.75-2.el8                        PowerTools
perl-DateTime-Locale.noarch               1.17-2.el8                          PowerTools
perl-DateTime-TimeZone.noarch             2.19-1.el8                          PowerTools
perl-DateTime-TimeZone-SystemV.noarch     0.010-3.el8                         PowerTools
perl-DateTime-TimeZone-Tzfile.noarch      0.011-3.el8                         PowerTools
perl-Devel-CallChecker.x86_64             0.008-3.el8                         PowerTools
perl-Devel-Caller.x86_64                  2.06-15.el8                         PowerTools
perl-Devel-CheckLib.noarch                1.11-5.el8                          PowerTools
perl-Devel-GlobalDestruction.noarch       0.14-5.el8                          PowerTools
perl-Devel-LexAlias.x86_64                0.05-16.el8                         PowerTools
perl-Devel-StackTrace.noarch              1:2.03-2.el8                        PowerTools
perl-Devel-Symdump.noarch                 1:2.18-5.el8                        PowerTools
perl-Digest-CRC.x86_64                    0.22.2-5.el8                        PowerTools
perl-Digest-SHA1.x86_64                   2.13-23.el8                         PowerTools
perl-Dist-CheckConflicts.noarch           0.11-11.el8                         PowerTools
perl-DynaLoader-Functions.noarch          0.003-2.el8                         PowerTools
perl-Eval-Closure.noarch                  0.14-5.el8                          PowerTools
perl-Exception-Class.noarch               1.44-2.el8                          PowerTools
perl-Exporter-Tiny.noarch                 1.000000-4.el8                      PowerTools
perl-File-BaseDir.noarch                  0.08-1.el8                          PowerTools
perl-File-Copy-Recursive.noarch           0.40-3.el8                          PowerTools
perl-File-DesktopEntry.noarch             0.22-7.el8                          PowerTools
perl-File-Find-Object.noarch              0.3.2-5.el8                         PowerTools
perl-File-Find-Rule.noarch                0.34-8.el8                          PowerTools
perl-File-MimeInfo.noarch                 0.28-7.el8                          PowerTools
perl-File-ReadBackwards.noarch            1.05-11.el8                         PowerTools
perl-File-Remove.noarch                   1.57-6.el8                          PowerTools
perl-File-chdir.noarch                    0.1011-5.el8                        PowerTools
perl-HTML-Tree.noarch                     1:5.07-2.el8                        PowerTools
perl-HTTP-Daemon.noarch                   6.01-23.el8                         PowerTools
perl-IO-All.noarch                        0.87-6.el8                          PowerTools
perl-IO-String.noarch                     1.08-31.el8                         PowerTools
perl-IO-Tty.x86_64                        1.12-11.el8                         PowerTools
perl-IO-stringy.noarch                    2.111-9.el8                         PowerTools
perl-IPC-Run.noarch                       0.99-1.el8                          PowerTools
perl-IPC-Run3.noarch                      0.048-12.el8                        PowerTools
perl-Import-Into.noarch                   1.002005-7.el8                      PowerTools
perl-Importer.noarch                      0.025-1.el8                         PowerTools
perl-JSON-XS.x86_64                       1:3.04-3.el8                        PowerTools
perl-List-MoreUtils.noarch                0.428-2.el8                         PowerTools
perl-List-MoreUtils-XS.x86_64             0.428-3.el8                         PowerTools
perl-Locale-gettext.x86_64                1.07-9.el8                          PowerTools
perl-MIME-Charset.noarch                  1.012.2-4.el8                       PowerTools
perl-MIME-Types.noarch                    2.17-3.el8                          PowerTools
perl-Module-Implementation.noarch         0.09-15.el8                         PowerTools
perl-Module-Install.noarch                1.19-2.el8                          PowerTools
perl-Module-Install-AuthorTests.noarch    0.002-16.el8                        PowerTools
perl-Module-Install-ReadmeFromPod.noarch  0.30-4.el8                          PowerTools
perl-Module-ScanDeps.noarch               1.24-3.el8                          PowerTools
perl-NKF.x86_64                           1:2.1.4-8.el8                       PowerTools
perl-Number-Compare.noarch                0.03-19.el8                         PowerTools
perl-Package-DeprecationManager.noarch    0.17-5.el8                          PowerTools
perl-Package-Stash.noarch                 0.37-9.el8                          PowerTools
perl-Package-Stash-XS.x86_64              0.28-17.el8                         PowerTools
perl-PadWalker.x86_64                     2.3-2.el8                           PowerTools
perl-Params-Classify.x86_64               0.015-2.el8                         PowerTools
perl-Params-Validate.x86_64               1.29-5.el8                          PowerTools
perl-Params-ValidationCompiler.noarch     0.27-1.el8                          PowerTools
perl-Path-Tiny.noarch                     0.104-5.el8                         PowerTools
perl-Perl-Destruct-Level.x86_64           0.02-20.el8                         PowerTools
perl-PerlIO-utf8_strict.x86_64            0.007-5.el8                         PowerTools
perl-Pod-Coverage.noarch                  0.23-14.el8                         PowerTools
perl-Pod-Markdown.noarch                  3.005-6.el8                         PowerTools
perl-Readonly.noarch                      2.05-5.el8                          PowerTools
perl-Ref-Util.noarch                      0.203-4.el8                         PowerTools
perl-Ref-Util-XS.x86_64                   0.117-2.el8                         PowerTools
perl-Role-Tiny.noarch                     2.000006-2.el8                      PowerTools
perl-SGMLSpm.noarch                       1.03ii-42.el8                       PowerTools
perl-SUPER.noarch                         1.20141117-10.el8                   PowerTools
perl-Scope-Guard.noarch                   0.21-7.el8                          PowerTools
perl-Specio.noarch                        0.42-2.el8                          PowerTools
perl-Sub-Exporter-Progressive.noarch      0.001013-5.el8                      PowerTools
perl-Sub-Identify.x86_64                  0.14-6.el8                          PowerTools
perl-Sub-Info.noarch                      0.002-5.el8                         PowerTools
perl-Sub-Name.x86_64                      0.21-7.el8                          PowerTools
perl-Sub-Uplevel.noarch                   1:0.2800-4.el8                      PowerTools
perl-Switch.noarch                        2.17-10.el8                         PowerTools
perl-Taint-Runtime.x86_64                 0.03-32.el8                         PowerTools
perl-Term-Size-Any.noarch                 0.002-23.el8                        PowerTools
perl-Term-Size-Perl.x86_64                0.031-1.el8                         PowerTools
perl-Term-Table.noarch                    0.012-2.el8                         PowerTools
perl-Test-Deep.noarch                     1.127-4.el8                         PowerTools
perl-Test-Differences.noarch              0.6400-8.el8                        PowerTools
perl-Test-Exception.noarch                0.43-7.el8                          PowerTools
perl-Test-Fatal.noarch                    0.014-9.el8                         PowerTools
perl-Test-LongString.noarch               0.17-10.el8                         PowerTools
perl-Test-NoWarnings.noarch               1.04-15.el8                         PowerTools
perl-Test-Pod.noarch                      1.51-8.el8                          PowerTools
perl-Test-Pod-Coverage.noarch             1.10-10.el8                         PowerTools
perl-Test-Requires.noarch                 0.10-10.el8                         PowerTools
perl-Test-Taint.x86_64                    1.06-19.el8                         PowerTools
perl-Test-Warn.noarch                     0.32-5.el8                          PowerTools
perl-Test-Warnings.noarch                 0.026-7.el8                         PowerTools
perl-Test2-Suite.noarch                   0.000111-1.el8                      PowerTools
perl-Text-CharWidth.x86_64                0.04-32.el8                         PowerTools
perl-Text-WrapI18N.noarch                 0.06-30.el8                         PowerTools
perl-Tie-IxHash.noarch                    1.23-13.el8                         PowerTools
perl-Tk.x86_64                            804.034-2.el8                       PowerTools
perl-Tk-devel.x86_64                      804.034-2.el8                       PowerTools
perl-Types-Serialiser.noarch              1.0-12.el8                          PowerTools
perl-Unicode-EastAsianWidth.noarch        1.33-13.el8                         PowerTools
perl-Unicode-LineBreak.x86_64             2017.004-6.el8                      PowerTools
perl-Unicode-UTF8.x86_64                  0.62-5.el8                          PowerTools
perl-Variable-Magic.x86_64                0.62-3.el8                          PowerTools
perl-XML-DOM.noarch                       1.46-5.el8                          PowerTools
perl-XML-RegExp.noarch                    0.04-14.el8                         PowerTools
perl-XML-Twig.noarch                      3.52-7.el8                          PowerTools
perl-YAML-LibYAML.x86_64                  1:0.70-1.el8                        PowerTools
perl-YAML-Syck.x86_64                     1.30-5.el8                          PowerTools
perl-YAML-Tiny.noarch                     1.73-2.el8                          PowerTools
perl-common-sense.x86_64                  3.7.4-8.el8                         PowerTools
perl-namespace-autoclean.noarch           0.28-10.el8                         PowerTools
perl-namespace-clean.noarch               0.27-7.el8                          PowerTools
perl-prefork.noarch                       1.04-26.el8                         PowerTools
perltidy.noarch                           20180220-1.el8                      PowerTools
pidgin-devel.x86_64                       2.13.0-4.el8                        PowerTools
plotutils.x86_64                          2.6-20.el8                          PowerTools
plotutils-devel.x86_64                    2.6-20.el8                          PowerTools
po4a.noarch                               0.52-4.el8                          PowerTools
poppler-cpp.x86_64                        0.66.0-10.el8                       PowerTools
poppler-cpp-devel.x86_64                  0.66.0-10.el8                       PowerTools
poppler-devel.x86_64                      0.66.0-10.el8                       PowerTools
poppler-glib-devel.x86_64                 0.66.0-10.el8                       PowerTools
poppler-qt5.x86_64                        0.66.0-10.el8                       PowerTools
poppler-qt5-devel.x86_64                  0.66.0-10.el8                       PowerTools
ppp-devel.x86_64                          2.4.7-25.el8                        PowerTools
pps-tools-devel.x86_64                    1.0.2-1.el8                         PowerTools
protobuf-c-compiler.x86_64                1.3.0-4.el8                         PowerTools
protobuf-c-devel.x86_64                   1.3.0-4.el8                         PowerTools
protobuf-compiler.x86_64                  3.5.0-7.el8                         PowerTools
protobuf-devel.x86_64                     3.5.0-7.el8                         PowerTools
pstoedit.x86_64                           3.70-9.el8                          PowerTools
ptscotch-mpich.x86_64                     6.0.5-1.el8                         PowerTools
ptscotch-mpich-devel.x86_64               6.0.5-1.el8                         PowerTools
ptscotch-mpich-devel-parmetis.x86_64      6.0.5-1.el8                         PowerTools
ptscotch-openmpi.x86_64                   6.0.5-1.el8                         PowerTools
ptscotch-openmpi-devel.x86_64             6.0.5-1.el8                         PowerTools
pygobject3-devel.x86_64                   3.28.3-1.el8                        PowerTools
python-cups-doc.x86_64                    1.9.72-21.el8.0.1                   PowerTools
python-sphinx-locale.noarch               1:1.7.6-1.el8                       PowerTools
python2-gluster.x86_64                    3.12.2-40.2.el8                     PowerTools
python2-iso8601.noarch                    0.1.11-9.el8                        PowerTools
python2-talloc.x86_64                     2.1.14-3.el8                        PowerTools
python3-Cython.x86_64                     0.28.1-3.el8                        PowerTools
python3-greenlet-devel.x86_64             0.4.13-3.el8                        PowerTools
python3-httplib2.noarch                   0.10.3-4.el8                        PowerTools
python3-hypothesis.noarch                 3.44.24-6.el8                       PowerTools
python3-imagesize.noarch                  1.0.0-2.el8                         PowerTools
python3-iso8601.noarch                    0.1.11-9.el8                        PowerTools
python3-lesscpy.noarch                    0.13.0-4.el8                        PowerTools
python3-libpfm.x86_64                     4.10.1-1.el8                        PowerTools
python3-markdown.noarch                   2.6.11-2.el8                        PowerTools
python3-mock.noarch                       2.0.0-11.el8                        PowerTools
python3-mpich.x86_64                      3.2.1-9.el8                         PowerTools
python3-openmpi.x86_64                    3.1.2-5.el8                         PowerTools
python3-packaging.noarch                  16.8-9.el8                          PowerTools
python3-pyxattr.x86_64                    0.5.3-18.el8                        PowerTools
python3-qt5-devel.x86_64                  5.11.2-3.el8                        PowerTools
python3-rrdtool.x86_64                    1.7.0-16.el8                        PowerTools
python3-scons.noarch                      3.0.1-8.el8                         PowerTools
python3-setuptools_scm.noarch             1.15.7-4.el8                        PowerTools
python3-sip-devel.x86_64                  4.19.12-3.el8                       PowerTools
python3-snowballstemmer.noarch            1.2.1-6.el8                         PowerTools
python3-sphinx.noarch                     1:1.7.6-1.el8                       PowerTools
python3-sphinx-theme-alabaster.noarch     0.7.9-7.el8                         PowerTools
python3-sphinx_rtd_theme.noarch           0.3.1-3.el8                         PowerTools
python3-sphinxcontrib-websupport.noarch   1.0.1-10.20180316git.el8            PowerTools
python3-sure.noarch                       1.4.0-6.el8                         PowerTools
python3-unittest2.noarch                  1.1.0-16.el8                        PowerTools
python3-whoosh.noarch                     2.7.4-9.el8                         PowerTools
qhull-devel.x86_64                        2015.2-5.el8                        PowerTools
qrencode-devel.x86_64                     3.4.4-5.el8                         PowerTools
qt5-devel.noarch                          5.11.1-2.el8                        PowerTools
qt5-qtbase-static.x86_64                  5.11.1-5.el8                        PowerTools
qt5-qtdeclarative-static.x86_64           5.11.1-3.el8                        PowerTools
qt5-qtquickcontrols2-devel.x86_64         5.11.1-2.el8                        PowerTools
qt5-qttools-static.x86_64                 5.11.1-5.el8                        PowerTools
qt5-qtwayland-devel.x86_64                5.11.1-2.el8                        PowerTools
raptor2-devel.x86_64                      2.0.15-13.el8                       PowerTools
rasqal-devel.x86_64                       0.9.33-6.el8                        PowerTools
re2c.x86_64                               0.14.3-2.el8                        PowerTools
recode-devel.x86_64                       3.6-47.el8                          PowerTools
redland-devel.x86_64                      1.0.17-14.el8                       PowerTools
rpcgen.x86_64                             1.3.1-4.el8                         PowerTools
rpcsvc-proto-devel.x86_64                 1.3.1-4.el8                         PowerTools
rrdtool-devel.x86_64                      1.7.0-16.el8                        PowerTools
rrdtool-doc.x86_64                        1.7.0-16.el8                        PowerTools
rrdtool-lua.x86_64                        1.7.0-16.el8                        PowerTools
rrdtool-ruby.x86_64                       1.7.0-16.el8                        PowerTools
rrdtool-tcl.x86_64                        1.7.0-16.el8                        PowerTools
rubygem-diff-lcs.noarch                   1.3-4.el8                           PowerTools
rubygem-rspec.noarch                      3.7.0-2.el8                         PowerTools
rubygem-rspec-core.noarch                 3.7.1-5.el8                         PowerTools
rubygem-rspec-expectations.noarch         3.7.0-4.el8                         PowerTools
rubygem-rspec-mocks.noarch                3.7.0-4.el8                         PowerTools
rubygem-rspec-support.noarch              3.7.1-2.el8                         PowerTools
sanlock-devel.x86_64                      3.6.0-5.el8                         PowerTools
sblim-cmpi-devel.x86_64                   2.0.3-15.el8                        PowerTools
sblim-sfcc-devel.x86_64                   2.2.8-9.el8                         PowerTools
scotch.x86_64                             6.0.5-1.el8                         PowerTools
scotch-devel.x86_64                       6.0.5-1.el8                         PowerTools
sendmail-milter-devel.x86_64              8.15.2-31.el8                       PowerTools
sg3_utils-devel.x86_64                    1.44-2.el8                          PowerTools
sharutils.x86_64                          4.15.2-11.el8                       PowerTools
sip.x86_64                                4.19.12-3.el8                       PowerTools
snappy-devel.x86_64                       1.1.7-5.el8                         PowerTools
socket_wrapper.x86_64                     1.1.9-2.el8                         PowerTools
sombok.x86_64                             2.4.0-6.el8                         PowerTools
sombok-devel.x86_64                       2.4.0-6.el8                         PowerTools
soundtouch-devel.x86_64                   2.0.0-2.el8                         PowerTools
sparsehash-devel.x86_64                   2.0.2-8.el8                         PowerTools
speech-dispatcher-devel.x86_64            0.8.8-6.el8                         PowerTools
speech-dispatcher-doc.noarch              0.8.8-6.el8                         PowerTools
speex-devel.x86_64                        1.2.0-1.el8                         PowerTools
speexdsp-devel.x86_64                     1.2-0.13.rc3.el8                    PowerTools
spice-server-devel.x86_64                 0.14.0-7.el8                        PowerTools
spirv-tools-libs.x86_64                   2018.4-1.el8                        PowerTools
suitesparse-devel.x86_64                  4.4.6-11.el8                        PowerTools
taglib-devel.x86_64                       1.11.1-8.el8                        PowerTools
texi2html.noarch                          5.0-8.el8                           PowerTools
texinfo.x86_64                            6.5-4.el8                           PowerTools
texinfo-tex.x86_64                        6.5-4.el8                           PowerTools
texlive-lib-devel.x86_64                  7:20180414-13.el8                   PowerTools
tinycdb.x86_64                            0.78-9.el8                          PowerTools
tinycdb-devel.x86_64                      0.78-9.el8                          PowerTools
tinyxml2.x86_64                           6.0.0-3.el8                         PowerTools
tinyxml2-devel.x86_64                     6.0.0-3.el8                         PowerTools
tix-devel.x86_64                          1:8.4.3-23.el8                      PowerTools
tog-pegasus-devel.x86_64                  2:2.14.1-44.el8                     PowerTools
tokyocabinet-devel.x86_64                 1.4.48-10.el8                       PowerTools
torque.x86_64                             4.2.10-17.el8                       PowerTools
torque-devel.x86_64                       4.2.10-17.el8                       PowerTools
tpm-tools-devel.x86_64                    1.3.9-4.el8                         PowerTools
tpm2-abrmd-devel.x86_64                   2.0.0-3.el8                         PowerTools
transfig.x86_64                           1:3.2.6a-4.el8                      PowerTools
trousers-devel.x86_64                     0.3.14-2.el8                        PowerTools
turbojpeg-devel.x86_64                    1.5.3-7.el8                         PowerTools
uglify-js.noarch                          2.8.29-1.el8                        PowerTools
uid_wrapper.x86_64                        1.2.4-2.el8                         PowerTools
upower-devel.x86_64                       0.99.7-3.el8                        PowerTools
upower-devel-docs.noarch                  0.99.7-3.el8                        PowerTools
urw-base35-fonts-devel.noarch             20170801-10.el8                     PowerTools
usbredir-devel.x86_64                     0.8.0-1.el8                         PowerTools
userspace-rcu-devel.x86_64                0.10.1-2.el8                        PowerTools
ustr.x86_64                               1.0.4-26.el8                        PowerTools
uthash-devel.noarch                       2.0.2-4.el8                         PowerTools
uuid-devel.x86_64                         1.6.2-42.el8                        PowerTools
vala.x86_64                               0.40.10-1.el8                       PowerTools
vala-devel.x86_64                         0.40.10-1.el8                       PowerTools
vte291-devel.x86_64                       0.52.2-2.el8                        PowerTools
wavpack-devel.x86_64                      5.1.0-9.el8                         PowerTools
web-assets-devel.noarch                   5-7.el8                             PowerTools
web-assets-filesystem.noarch              5-7.el8                             PowerTools
wireshark-devel.x86_64                    1:2.6.2-9.el8                       PowerTools
xcb-proto.noarch                          1.13-4.el8                          PowerTools
xcb-util-devel.x86_64                     0.4.0-10.el8                        PowerTools
xcb-util-image-devel.x86_64               0.4.0-9.el8                         PowerTools
xcb-util-keysyms-devel.x86_64             0.4.0-7.el8                         PowerTools
xcb-util-renderutil-devel.x86_64          0.3.9-10.el8                        PowerTools
xcb-util-wm-devel.x86_64                  0.4.1-12.el8                        PowerTools
xhtml1-dtds.noarch                        1.0-20020801.13.el8.4               PowerTools
xkeyboard-config-devel.noarch             2.24-3.el8                          PowerTools
xmlrpc-c-c++.x86_64                       1.51.0-5.el8                        PowerTools
xmlrpc-c-client++.x86_64                  1.51.0-5.el8                        PowerTools
xmlrpc-c-devel.x86_64                     1.51.0-5.el8                        PowerTools
xmlsec1-devel.x86_64                      1.2.25-4.el8                        PowerTools
xmlsec1-gcrypt.x86_64                     1.2.25-4.el8                        PowerTools
xmlsec1-gnutls.x86_64                     1.2.25-4.el8                        PowerTools
xmlsec1-gnutls-devel.x86_64               1.2.25-4.el8                        PowerTools
xmlsec1-openssl-devel.x86_64              1.2.25-4.el8                        PowerTools
xmltoman.noarch                           0.4-17.el8                          PowerTools
xorg-x11-apps.x86_64                      7.7-21.el8                          PowerTools
xorg-x11-drv-libinput-devel.x86_64        0.28.0-2.el8                        PowerTools
xorg-x11-drv-wacom-devel.x86_64           0.36.1-5.el8                        PowerTools
xorg-x11-server-devel.x86_64              1.20.3-5.2.el8_0                    PowerTools
xorg-x11-util-macros.noarch               1.19.0-8.el8                        PowerTools
xorg-x11-xkb-utils-devel.x86_64           7.7-27.el8                          PowerTools
xorg-x11-xtrans-devel.noarch              1.3.5-6.el8                         PowerTools
xz-lzma-compat.x86_64                     5.2.4-3.el8                         PowerTools
yajl-devel.x86_64                         2.1.0-10.el8                        PowerTools
yasm.x86_64                               1.3.0-7.el8                         PowerTools
yelp-devel.x86_64                         2:3.28.1-3.el8                      PowerTools
zlib-static.x86_64                        1.2.11-10.el8                       PowerTools
zziplib-devel.x86_64                      0.13.68-7.el8                       PowerTools
But yes some packages still missing i.e. opendkim isn't available in CentOS 8 or EPEL repos right now. We are waiting on 3rd party EPEL repos to catch up so I wouldn't be using CentOS 8 in production yet.
HTH
George
hello.
are missing
CentOS 8 now uses OpenSSL 1.1.1, but has an additional yum package compat-openssl10 for software that doesn't support OpenSSL 1.1.1 and adds backward support for OpenSSL 1.0.2 libraries
rpm -ql compat-openssl10
/etc/pki
/etc/pki/openssl10.cnf
/usr/lib/.build-id
/usr/lib/.build-id/19
/usr/lib/.build-id/19/64423760203c8f553f52231b37f4b0f94018af
/usr/lib/.build-id/52
/usr/lib/.build-id/52/2a0b727ea2d69a40ba9847d978f75a393cc2b6
/usr/lib64/.libcrypto.so.1.0.2o.hmac
/usr/lib64/.libcrypto.so.10.hmac
/usr/lib64/.libssl.so.1.0.2o.hmac
/usr/lib64/.libssl.so.10.hmac
/usr/lib64/libcrypto.so.1.0.2o
/usr/lib64/libcrypto.so.10
/usr/lib64/libssl.so.1.0.2o
/usr/lib64/libssl.so.10
/usr/share/doc/compat-openssl10
/usr/share/doc/compat-openssl10/FAQ
/usr/share/doc/compat-openssl10/NEWS
/usr/share/doc/compat-openssl10/README
/usr/share/doc/compat-openssl10/README.FIPS
/usr/share/doc/compat-openssl10/README.legacy-settings
/usr/share/licenses/compat-openssl10
/usr/share/licenses/compat-openssl10/LICENSE
yum info compat-openssl10
Last metadata expiration check: 0:07:12 ago on Tue 01 Oct 2019 07:48:58 AM AEST.
Installed Packages
Epoch        : 1
Version      : 1.0.2o
Release      : 3.el8
Arch         : x86_64
Source       : compat-openssl10-1.0.2o-3.el8.src.rpm
Repo         : @System
From repo    : AppStream
Summary      : Compatibility version of the OpenSSL library
URL          : http://www.openssl.org/
License      : OpenSSL
Description  : The OpenSSL toolkit provides support for secure communications between
             : machines. This version of OpenSSL package contains only the libraries
             : and is provided for compatibility with previous releases and software
             : that does not support compilation with OpenSSL-1.1.
not sure how DA is utilising libcrypt.so.10 etc but for CentOS 8 they can take advantage of compat-openssl10 yum package probably ?
HTH
George
Hello George,
Thank you. Such a good catch. Now I installed PHP+memcached without any issue.
yum install -y libmemcached libmemcached-devel memcached --enablerepo=PowerTools
and then compiled the memcached extension.
Yes, need to wait for epel repository to publish missing perl modules.
You're welcome Alex. Looks like will need some time for EPEL 8 repo to catch up as some missing packages are also waiting on other missing dependencies. So it's a cascading queue of folks waiting on other folks :)
Example opendkim tracker https://bugzilla.redhat.com/show_bug.cgi?id=1754540
But curious I just tried building my own CentOS 7 and CentOS 8 opendkim YUM and related packages. CentOS 7 was fine.
But CentOS 8 version has missing dependencies for the dependencies !
opendkim dependencies which don't exist on CentOS 8/EPEL 8
rpmbuild -ba opendkim.spec
error: Failed build dependencies:
        libbsd is needed by opendkim-2.11.0-0.9.el8.x86_64
        libbsd-devel is needed by opendkim-2.11.0-0.9.el8.x86_64
        libdb-devel is needed by opendkim-2.11.0-0.9.el8.x86_64
        opendbx-devel is needed by opendkim-2.11.0-0.9.el8.x86_64
        sendmail-devel is needed by opendkim-2.11.0-0.9.el8.x86_64
so you try building opendbx on CentOS 8 and yes more missing dependencies
rpmbuild -ba opendbx.spec
        docbook2X is needed by opendbx-1.4.6-21.el8.x86_64
        doxygen is needed by opendbx-1.4.6-21.el8.x86_64
        firebird-devel is needed by opendbx-1.4.6-21.el8.x86_64
        freetds-devel is needed by opendbx-1.4.6-21.el8.x86_64
        libpq-devel is needed by opendbx-1.4.6-21.el8.x86_64
        mysql-devel is needed by opendbx-1.4.6-21.el8.x86_64
so you try building firebird on CentOS 8 and yup more missing dependencies
rpmbuild -ba firebird.spec
        chrpath is needed by firebird-3.0.4.33054-4.el8.x86_64
        libedit-devel is needed by firebird-3.0.4.33054-4.el8.x86_64
        libicu-devel is needed by firebird-3.0.4.33054-4.el8.x86_64
        libstdc++-static is needed by firebird-3.0.4.33054-4.el8.x86_64
        libtommath-devel is needed by firebird-3.0.4.33054-4.el8.x86_64
        procmail is needed by firebird-3.0.4.33054-4.el8.x86_64
For EPEL 8 at least you can request missing packages. EPEL 8 issue tracker https://pagure.io/epel/
Issue tracker for EPEL (Extra Packages for Enterprise Linux)
The EPEL trac is meant for tracking work needed on packages in the various EPEL repositories. Items to be reported are problems with packages over-riding core RHEL/CentOS packages, packages needed to be branched to EPEL, clarifications on policy that need to be dealt with in weekly meetings, and agendas of weekly meetings. Problems NOT to be reported are bugs in packages. These need to be filed in ​Red Hat Bugzilla.
and I assume the same for EPEL 8 https://fedoraproject.org/wiki/EPEL/FAQ#Why_isn.27t_a_package_in_EPEL-7_when_it_is_in_EPEL-6.3F
Why isn't a package in EPEL-7 when it is in EPEL-6?
Packages are not automatically branched for each EPEL version. Each package must be branched by a packager for each particular release, and packagers may or may not be interested in EPEL-7 while they were interested in EPEL-6. If you are an EPEL-7 user and you want an EPEL-7 branch, it's a good idea to ask the existing EPEL or Fedora maintainer. This lets the current maintainer know that there are real users who would benefit from the package (instead of simply guessing at the size of the user base).
The preferred method of asking a maintainer for an EPEL-7 branch is to file a ticket in bugzilla against the "el6" version of your package. If there is no el6 version, use the Rawhide version instead.
If you want to check the current ownership of a package (perhaps to contact the owner directly), you can search pkgdb. You can also use zodbot on IRC to query pkgdb on your behalf:
Just installed a fresh Centos 8 Server with the latest DA version and did not had any problems.
Server is running besides the standard stuff also CSF, DKIM and Spamassasin.
Hello George,
may I ask you how you compiled it?
I got this error after /usr/local/php70/bin/pecl install memcached:
PHP Warning: PHP Startup: Unable to load dynamic library 'memcache.so' (tried: /usr/local/php73/lib/php/extensions/no-debug-non-zts-20180731/memcache.so
and
Warning: popen() has been disabled for security reasons in PEAR/Builder.php on line 467
PHP Warning: popen() has been disabled for security reasons in /usr/local/php73/lib/php/PEAR/Builder.php on line 467
ERROR: failed to run `phpize73'
[root@server ~]#
with
Great ofc you will share the iso with us ;) so we don't have to do the challenge :cool:
