Y yrdesign Verified User Joined Aug 1, 2019 Messages 28 Sep 28, 2019 #1 directadmin.conf ---I add language=zh Restart directadmin.. No effect, still English
Richard G Verified User Joined Jul 6, 2008 Messages 14,888 Location Maastricht Sep 28, 2019 #2 Jut to be sure, did you also create the necessary .po file? https://help.directadmin.com/item.php?id=704
Y yrdesign Verified User Joined Aug 1, 2019 Messages 28 Sep 28, 2019 #3 Richard G said: Jut to be sure, did you also create the necessary .po file? https://help.directadmin.com/item.php?id=704 Click to expand... yes! I confirm that I added and translated the file login-zh.po
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 8,427 Location LT, EU Sep 28, 2019 #4 Do you have zh.po as well? Does it work when you select the language from dropdown?
Y yrdesign Verified User Joined Aug 1, 2019 Messages 28 Sep 28, 2019 #5 hi login page has drop-down menu. change of language works! but I want to set the default language!
Y yrdesign Verified User Joined Aug 1, 2019 Messages 28 Sep 28, 2019 #6 smtalk said: Do you have zh.po as well? Does it work when you select the language from dropdown? Click to expand... hi login page has drop-down menu. change of language works! but I want to set the default language!
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 8,427 Location LT, EU Sep 28, 2019 #7 Please let us know the output of: Code: /usr/local/directadmin/directadmin c | grep lang
D dbbrito Verified User Joined Jan 10, 2020 Messages 17 Jan 21, 2025 #8 Hello, I have the same problem, my login screen is only in English, my language is pt_BR, the command /usr/local/directadmin/directadmin c | grep lang only shows: internal_lang=/usr/local/directadmin/data/skins/enhanced/lang language=en language_list= How to change the login screen to pt_BR ? Thanks
