rspamd on centos8 has no repo.
Marwen
germany
Hi..
There are no rspamd rpm or repo for centos 8 at the moment.
If i try the centos 7 repo i get the message
Problem: conflicting requests
- nothing provides libcrypto.so.10()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libcrypto.so.10(OPENSSL_1.0.1_EC)(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libcrypto.so.10(libcrypto.so.10)(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libssl.so.10()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libssl.so.10(libssl.so.10)(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libopenblas.so.0()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libicudata.so.50()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libicuuc.so.50()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libicui18n.so.50()(64bit) needed by rspamd-1.9.4-3.x86_64
- nothing provides libevent-2.0.so.5()(64bit) needed by rspamd-1.9.4-3.x86_64
so i revert back to spamassassin for the moment.
Here is a reply from the author of rspamd:
Many packages that are essential for Rspamd build are missing, e.g. Ragel. So I think that CentOS 8 will not be supported unless it comes to some mature state.
So let's see how it goes then.
And please if you read this thread take a minute to add your vote here https://github.com/rspamd/rspamd/issues/3060 The more of us shows an interest, the more chances to get a quicker release of rspamd for CentOS 8 we have.
Good job, thanks. I've already installed rspamd 2.0 on CentOS 8:
wget https://rspamd.com/rpm/centos-8/rspamd-experimental.repo -O /etc/yum.repos.d/rspamd.repo
./build set spamd rspamd
./build rspamd
that's it.
Changing statistics to work with sqlite (optional):
touch /etc/rspamd/local.d/statistic.conf
open the file in an editor and populate with the following content:
# Rspamd statistic setup# Pre-built files could be loaded from:
# http://rspamd.com/rspamd_statistics/bayes.spam.sqlite
#  - and -
# http://rspamd.com/rspamd_statistics/bayes.ham.sqlite
classifier "bayes" {
  tokenizer {
    name = "osb";
  cache {
    path = "${DBDIR}/learn_cache.sqlite";
  min_tokens = 11;
  backend = "sqlite3";
  languages_enabled = true;
  min_learns = 200;
  statfile {
    symbol = "BAYES_HAM";
    path = "${DBDIR}/bayes.ham.sqlite";
    spam = false;
  statfile {
    symbol = "BAYES_SPAM";
    path = "${DBDIR}/bayes.spam.sqlite";
    spam = true;
  learn_condition =<<EOD
return function(task, is_spam, is_unlearn)
  local learn_type = task:get_request_header('Learn-Type')
  if not (learn_type and tostring(learn_type) == 'bulk') then
    local prob = task:get_mempool():get_variable('bayes_prob', 'double')
    if prob then
      local in_class = false
      local cl
      if is_spam then
        cl = 'spam'
        in_class = prob >= 0.95
      else
        cl = 'ham'
        in_class = prob <= 0.05
      end
      if in_class then
        return false,string.format('already in class %s; probability %.2f%%',
          cl, math.abs((prob - 0.5) * 200.0))
      end
    end
  end
  return true
end
EOD
restart rspamd.
Install rspamd plugin (optional) => https://forum.directadmin.com/showthread.php?t=57856
A repository of Rspamd experimental is now added into CustomBuild, I see it in 2.0.0 (rev: 2227):
                if [ ! -s /etc/yum.repos.d/rspamd.repo ]; then
                        RSPAMD_REPO_URL=https://rspamd.com/rpm-stable/centos-${OS_CENTOS_VER}/rspamd.repo
                        if [ "${OS_CENTOS_VER}" = "8" ]; then
                                RSPAMD_REPO_URL=https://rspamd.com/rpm/centos-8/rspamd-experimental.repo
                        fi
                        if ! curl --silent --fail ${RSPAMD_REPO_URL}; then
                                do_exit 1 "Cannot download rspamd repo file ${RSPAMD_REPO_URL}."
                        fi
                        curl --fail ${RSPAMD_REPO_URL} > /etc/yum.repos.d/rspamd.repo
                        rpm --import https://rspamd.com/rpm-stable/gpg.key
                fi
With this modification there is no more need to install experimental repository manually.
Hi All.
After update Rspamd web interface from 0.1.1 to 0.1.2 the Plugin is not more showing in "Extra Features" section.
OS: Centos 8 and also centos 7
