Exim Failing To Build /usr/bin/ld: cannot find -lsrs_alt
youds
Lancashire, UK
Hi all,
Not very often I post as I find the forums are quite useful for informative information already but this one I can't seem to get a handle of.
Basically, its a fresh(ish) server and it can't run exim. At first it couldn't run Dovecot but a simple ./build dovecot fixed that. Here's what I have done so far:
collect2: error: ld returned 1 exit status
make[1]: *** [exim] Error 1
make[1]: Leaving directory `/usr/local/directadmin/custombuild/exim-4.92.3/build-Linux-x86_64'
make: *** [all] Error 2
  - $  service dovecot status
  - $  ./build exim d
  - $  cd ../scripts
  - $  cd /usr/local/directadmin/scripts
  - $  ./exim.sh
  - $  cd /usr/local/directadmin/custombuild
  - $  ./build update
  - $  ./build set exim yes
  - $  ./build set eximconf yes
  - $  ./build set eximconf_release 4.5
  - $  ./build set spamassassin yes
  - $  ./build update
  - $  ./build exim
  - $  ./build exim_conf
  - $  ./build exim
  - $  yum install gdbm-devel
  - $  yum install lgdbm
  - $  yum install lgdbmyum search gdbm
  - $  yum search gdbm
  - $  yum install gdbm*
  - $  ./build update
  - $  ./build set blockcracking yes
  - $  ./build set easy_spam_fighter yes
  - $  ./build set spamd spamassassin
  - $  ./build exim
  - $  ./build set dovecot_conf yes
   - $  ./build dovecot_conf
  - $  yum search lspf
  - $  yum search spf
  - $  yum install libspf*
  - $  yum install libspf2
  - $  yum install libspf2-devel
  - $  ./build exim
  - $  locate _alt
  - $  yum search srs_alt
  - $  yum search ld
  - $  yum install lldb
  - $   ./build exim
  - $  yum install db4-devel cyrus-sasl-devel perl-ExtUtils-Embed
  - $  ./build update
  - $  ./build exim
  - $  yum -y install libtool-libs
  - $  ./build exim
  - $  ./build libtool ./build libtool
   - $  ./build libtool
  - $  ./build exim
As you can see, I'm. having no luck on this at all! I have a list of posts I've read here:
https://forum.directadmin.com/showthread.php?t=23931
https://help.directadmin.com/item.php?id=576
https://forum.directadmin.com/showthread.php?t=49097
https://forum.directadmin.com/showthread.php?t=21651
Nut no luck. One has the same problem but the fix wasn't for me.
Here's the exit mainlog:
mainlog    paniclog   rejectlog
********HIDDEN********
2019-10-28 09:18:58 unexpected disconnection while reading SMTP command from ([********HIDDEN********] D=1s
2019-10-28 09:19:11 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=test10)
2019-10-28 09:19:24 ReverseDNS: No reverse DNS for mailserver at 41.202.207.128, +100 Spam score
2019-10-28 09:19:24 unexpected disconnection while reading SMTP command from ([********HIDDEN********] D=1s
2019-10-28 09:19:35 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=email)
2019-10-28 09:19:48 ReverseDNS: No reverse DNS for mailserver at 154.72.163.105, +100 Spam score
2019-10-28 09:19:49 unexpected disconnection while reading SMTP command from ([********HIDDEN********] D=1s
2019-10-28 09:20:28 ReverseDNS: No reverse DNS for mailserver at 41.202.207.128, +100 Spam score
2019-10-28 09:20:28 unexpected disconnection while reading SMTP command from ([********HIDDEN********] D=1s
2019-10-28 09:21:15 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=frank)
2019-10-28 09:22:06 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=newsletter)
2019-10-28 09:23:49 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=bank)
2019-10-28 09:25:41 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=webmail)
2019-10-28 09:26:38 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=jordan)
2019-10-28 09:26:58 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=test01)
2019-10-28 09:28:41 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=jones)
2019-10-28 09:32:22 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2019-10-28 09:32:22 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0Rq-0002hM-R4
2019-10-28 09:32:22 1iP0Rq-0002hM-R4 User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:32:22 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0Rq-0002hP-TL
2019-10-28 09:32:22 1iP0Rq-0002hP-TL User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:32:23 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2019-10-28 09:32:23 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0Rq-0002hT-VM
2019-10-28 09:32:23 1iP0Rq-0002hT-VM User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:32:23 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0Rr-0002hX-10
2019-10-28 09:32:23 1iP0Rr-0002hX-10 User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:32:23 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0Rr-0002hb-3U
2019-10-28 09:32:23 1iP0Rr-0002hb-3U User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:33:15 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=apache)
2019-10-28 09:33:54 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=password)
2019-10-28 09:35:16 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=compaq)
2019-10-28 09:39:08 TLS error on connection from [********HIDDEN********] (SSL_accept): error:00000000:lib(0):func(0):reason(0)
2019-10-28 09:39:26 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=copier)
2019-10-28 09:40:18 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=postfix)
2019-10-28 09:40:26 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=acer)
2019-10-28 09:42:57 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=admin1)
2019-10-28 09:43:49 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=black)
2019-10-28 09:46:40 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=access)
2019-10-28 09:49:13 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=andrew)
2019-10-28 09:51:21 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0kB-0002qk-4d
2019-10-28 09:51:22 1iP0kB-0002qk-4d Completed
2019-10-28 09:51:25 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2019-10-28 09:51:25 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0kH-0002r6-Lp
2019-10-28 09:51:25 1iP0kH-0002r6-Lp User 0 set for local_delivery transport is on the never_users list
2019-10-28 09:52:19 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=charlie)
2019-10-28 09:52:30 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=webtest)
2019-10-28 09:53:05 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=reception)
2019-10-28 09:53:35 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=maryland)
2019-10-28 09:53:45 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=asdf)
2019-10-28 09:53:50 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=alex)
2019-10-28 09:53:58 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=summer)
2019-10-28 09:55:41 ReverseDNS: No reverse DNS for mailserver at 37.17.178.74, +100 Spam score
2019-10-28 09:55:41 unexpected disconnection while reading SMTP command from ([********HIDDEN********] D=1s
2019-10-28 09:56:24 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=root)
2019-10-28 09:56:26 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=webmaster)
2019-10-28 09:58:31 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2019-10-28 09:58:31 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1iP0r9-0002vT-Rv
2019-10-28 09:58:31 1iP0r9-0002vT-Rv User 0 set for local_delivery transport is on the never_users list
2019-10-28 10:00:01 cwd=/root 9 args: /usr/sbin/sendmail -FCronDaemon -i -odi -oem -oi -t -f root
2019-10-28 10:00:01 cwd=/var/spool/exim 4 args: /usr/sbin/exim -odi -Mc 1iP0sb-0002wv-Ju
2019-10-28 10:00:01 1iP0sb-0002wv-Ju User 0 set for local_delivery transport is on the never_users list
2019-10-28 10:02:04 login authenticator failed for (User) [********HIDDEN********]: 535 Incorrect authentication data (set_id=baseball)
2019-10-28 10:02:05 SMTP connection from smtp-coi-g18-051.aweber.com [********HIDDEN********] closed after SIGTERM
and exim.conf:
# SpamBlockerTechnology* powered exim.conf, Version 4.5.18
# August 15, 2018
# Exim configuration file for DirectAdmin
# Requires exim.pl as distributed by DirectAdmin here:
# http://files.directadmin.com/services/exim.pl version 21 or higher
# ClamAV optional
# SpamAssassin optional
# Dovecot/IMAP Mandatory
# *SpamBlockerTechnology is a Trademark of NoBaloney Internet Services:
# http://www.nobaloney.net
# WARNING! Do NOT use this exim.conf Exim configuration file unless you
# make the required modifications to your Exim configuration
# following the instructions in the README file included in this
# distribution:
# README-SpamBlockerVersion4exim.conf.txt
# The original exim.conf file distributed with Exim 4, includes the
# following copyright notice:
# Copyright (C) 2002 University of Cambridge, Cambridge, UK
# Portions of the file are taken from the exim.conf file as
# distributed with DirectAdmin (http://www.directadmin.com/)
# Copyright (C) 2003-2011 JBMC Software, St Albert, AB, Canada
# Portions of this file are written by NoBaloney Internet Services
# and are copyright as follows:
# Copyright (C) 2004-2011 NoBaloney Internet Services, Riverside, Calif., USA
# The entire Exim 4 distribution, including the exim.conf file, is
# distributed under the GNU GENERAL PUBLIC LICENSE, Version 2,
# June 1991. If you do not have a copy of the GNU GENERAL PUBLIC LICENSE
# you may download it, in it's entirety, from the website at:
# http://www.nobaloney.net/exim/gnu-gpl-v2.txt
# Thanks to all the members of the DirectAdmin community and of the exim
# community who have given their # much needed and appreciated help.
# The most recent version of this file may always downloaded from the website
# at: http://www.nobaloney.net/downloads/spamblocker
# MODIFICATION INSTRUCTIONS
# YOU MUST MAKE THE CHANGES TO THIS
# SpamBlockerTechnology* powered exim.conf, Version 4.0
# file as documented in the README file.
# The README file for this version is named:
# CONFIGURATION STARTS HERE
#EDIT#1:
# primary_hostname =
smtp_active_hostname = ${if exists{/etc/virtual/helo_data}{${lookup{$interface_address}iplsearch{/etc/virtual/helo_data}{$value}{$primary_hostname}}}{$primary_hostname}}
#EDIT#2-CLAMAV:
# av_scanner = clamd:/var/run/clamav/clamd
#.include_if_exists /etc/exim.clamav.load.conf
#Block Cracking variables
.include_if_exists /etc/exim.blockcracking/variables.conf
#Easy Spam Figher variables
.include_if_exists /etc/exim.easy_spam_fighter/variables.conf
#SRS
.include_if_exists /etc/exim.srs.conf
#EDIT#3:
# qualify_domain =
#EDIT#4:
perl_startup = do '/etc/exim.pl'
#EDIT#5:
system_filter = /etc/system_filter.exim
#EDIT#6:
untrusted_set_sender = *
#EDIT#7:
#daemon_smtp_ports=25 : 587 : 465 moved to exim.variables.conf
#tls_on_connect_ports = 465 moved to exim.variables.conf
#EDIT#8:
local_from_check = false
RBL_DNS_LIST=\
       cbl.abuseat.org : \
       bl.spamcop.net : \
       b.barracudacentral.org : \
       zen.spamhaus.org
.include /etc/exim.variables.conf
.include /etc/exim.strings.conf
.include_if_exists /etc/exim.strings.conf.custom
#EDIT#10:
helo_allow_chars = _
#EDIT#11:
log_selector = \
  +delivery_size \
  +sender_on_delivery \
  +received_recipients \
  +received_sender \
  +smtp_confirmation \
  +subject \
  +smtp_incomplete_transaction \
  -dnslist_defer \
  -host_lookup_failed \
  -queue_run \
  -rejected_header \
  -retry_defer \
  -skip_delivery \
  +arguments
#EDIT#12:
syslog_duplication = false
#EDIT#13:
acl_not_smtp = acl_script
acl_smtp_auth = acl_check_auth
acl_smtp_connect = acl_connect
acl_smtp_helo = acl_check_helo
acl_smtp_mail = ${if ={$interface_port}{587} {accept} {${if ={$interface_port}{10025} {acl_smtp_mail_proxy}{acl_check_mail}}}}
acl_smtp_mailauth = smtp_mailauth
acl_smtp_rcpt = acl_check_recipient
acl_smtp_dkim = ${if ={$interface_port}{587} {accept}{acl_check_dkim}}
acl_smtp_data = acl_check_message
acl_smtp_mime = acl_check_mime
#EDIT#14:
addresslist whitelist_senders = nwildlsearch;/etc/virtual/whitelist_senders
addresslist blacklist_senders = nwildlsearch;/etc/virtual/blacklist_senders
domainlist blacklist_domains = nwildlsearch;/etc/virtual/blacklist_domains
domainlist whitelist_domains = nwildlsearch;/etc/virtual/whitelist_domains
domainlist local_domains = lsearch;/etc/virtual/domains
domainlist relay_domains = lsearch;/etc/virtual/domains
domainlist use_rbl_domains = lsearch;/etc/virtual/use_rbl_domains
domainlist skip_rbl_domains = nwildlsearch;/etc/virtual/skip_rbl_domains
hostlist skip_rbl_hosts = ${if exists{/etc/virtual/skip_rbl_hosts}{wildlsearch;/etc/virtual/skip_rbl_hosts}}
hostlist skip_rbl_hosts_ip = ${if exists{/etc/virtual/skip_rbl_hosts_ip}{/etc/virtual/skip_rbl_hosts_ip}}
hostlist auth_relay_hosts = *
hostlist bad_sender_hosts = nwildlsearch;/etc/virtual/bad_sender_hosts
hostlist bad_sender_hosts_ip = /etc/virtual/bad_sender_hosts_ip
hostlist whitelist_hosts = nwildlsearch;/etc/virtual/whitelist_hosts
hostlist whitelist_hosts_ip = /etc/virtual/whitelist_hosts_ip
hostlist proxy_hosts_ip = ${if exists{/etc/virtual/proxy_hosts_ip}{/etc/virtual/proxy_hosts_ip}}
BLACKLIST_USERNAMES = /etc/virtual/blacklist_usernames
BLACKLIST_SMTP_USERNAMES = /etc/virtual/blacklist_smtp_usernames
BLACKLIST_SCRIPT_USERNAMES = /etc/virtual/blacklist_script_usernames
#EDIT#15:
#domainlist skip_av_domains = nwildlsearch;/etc/virtual/skip_av_domains
#EDIT#16:
#relay_hosts/pophosts moved to variables.conf
#EDIT#17:
never_users = root
#EDIT#18:
host_lookup = *
#EDIT#19:
rfc1413_hosts = *
rfc1413_query_timeout = 0s
#EDIT#20:
#exim.variables.conf
#EDIT#21:
#EDIT#22:
#EDIT#23:
tls_advertise_hosts = *
#auth_over_tls_hosts = *
.include_if_exists /etc/exim.variables.conf.post
# Access Control Lists
begin acl
# ACL CONNECT
#EDIT#24:
acl_connect:
  warn set acl_c_spam_assassin_has_run = 0
  warn set acl_m_is_whitelisted = 0
  .include_if_exists /etc/exim.easy_spam_fighter/connect.conf
  accept hosts = *
# ACL CHECK MAIL
acl_check_mail:
  accept  condition = ${if eq{$acl_m_is_whitelisted}{1}{1}{0}}
#EDIT#31:
  accept  sender_domains = +whitelist_domains
          logwrite = $sender_host_address whitelisted in local domains whitelist
          set acl_m_is_whitelisted = 1
  accept  hosts = +whitelist_hosts
          logwrite = $sender_host_address whitelisted in local hosts whitelist
  accept  hosts = +whitelist_hosts_ip
          logwrite = $sender_host_address whitelisted in local hosts IP whitelist
  # accept if envelope sender is in whitelist
  accept  senders = +whitelist_senders
          logwrite = $sender_host_address whitelisted in local sender whitelist
  .include_if_exists /etc/exim.easy_spam_fighter/check_mail.conf
  accept
# ACL CHECK AUTH
smtp_mailauth:
 accept
   hosts          = <; 127.0.0.1 ; ::1
   condition      = ${if eq{$interface_port}{10025}}
   log_message    = Will accept MAIL AUTH parameter for $authenticated_sender
 deny
acl_smtp_mail_proxy:
 deny
   condition      = ${if eq{$authenticated_sender}{}}
   message        = All connections on port $interface_port need MAIL AUTH sender
# ACL CHECK AUTH
#EDIT#24.5#
acl_check_auth:
  drop  set acl_m_authcount = ${eval10:0$acl_m_authcount+1}
        condition = ${if >{$acl_m_authcount}{2}}
        delay = 10s
        message = ONLY_ONE_AUTH_PER_CONN
  accept
# ACL CHECK HELO
#EDIT#25:
acl_check_helo:
  .include_if_exists /etc/exim.acl_check_helo.pre.conf
  # accept mail originating on this server unconditionally
  accept  hosts = <; @[]; 127.0.0.0/8 ; ::1 ; @
  # deny if the HELO pretends to be this host
    deny message = HELO_HOST_IMPERSANATION
      condition = ${if or { \
                            {eq{$sender_helo_name}{$smtp_active_hostname}} \
                            {eq{$sender_helo_name}{[$interface_address]}} \
                          } {true}{false} }
  # deny if the HELO is an IP address
    deny message = HELO_IS_IP
         condition   = ${if eq{$interface_port}{25}}
         condition   = ${if isip{$sender_helo_name}}
  # deny if hostname if ylmf-pc, which accounts for a HUGE percentage of BF attacks
    deny message = HELO_BLOCKED_FOR_ABUSE
         condition   = ${if eq{$sender_helo_name}{ylmf-pc}}
  # deny if the HELO pretends to be one of the domains hosted on the server
    deny message = HELO_IS_LOCAL_DOMAIN
        condition = ${if match_domain{$sender_helo_name}{+local_domains}{true}{false}}
        hosts = ! +relay_hosts
  .include_if_exists /etc/exim.acl_check_helo.post.conf
  accept
# ACL SCRIPT
acl_script:
  .include_if_exists /etc/exim.acl_script.pre.conf
  discard set acl_m_uid = ${perl{find_uid}}
          set acl_m_username = ${perl{get_username}{$acl_m_uid}}
          condition = ${if !eq {$acl_m_uid}{-1}{yes}{no}}
          condition = ${if >{${perl{hit_limit_user}{$acl_m_username}}}{1}}
          message = USER_TOO_MANY
  discard condition = ${if !eq{$originator_uid}{$exim_uid}}
          condition = ${if exists{BLACKLIST_USERNAMES}}
          condition = ${lookup{$acl_m_username}lsearch{BLACKLIST_USERNAMES}{1}{0}}
          message = USER_ON_BLACKLIST_SCRIPT BLACKLIST_USERNAMES
          condition = ${if exists{BLACKLIST_SCRIPT_USERNAMES}}
          condition = ${lookup{$acl_m_username}lsearch{BLACKLIST_SCRIPT_USERNAMES}{1}{0}}
          message = USER_ON_BLACKLIST_SCRIPT BLACKLIST_SCRIPT_USERNAMES
  .include_if_exists /etc/exim.blockcracking/script.conf
  accept
  .include_if_exists /etc/exim.blockcracking/script.recipients.conf
# ACL CHECK RECIPIENT
#EDIT#26:
acl_check_recipient:
  .include_if_exists /etc/exim.acl_check_recipient.pre.conf
  # block certain well-known exploits, Deny for local domains if
  # local parts begin with a dot or contain @ % ! / |
  deny  domains       = +local_domains
        message = Invalid characters in local_part
        local_parts   = ^[.] : ^.*[@%!|]
  # If you've hit the limit, you can't send anymore. Requires exim.pl 17+
  drop  message = AUTH_TOO_MANY
        condition = ${perl{auth_hit_limit_acl}}
        authenticated = *
  drop  message = MULTIPLE_BOUNCE_RECIPIENTS
        senders = : postmaster@*
        condition = ${if >{$recipients_count}{0}{true}{false}}
  drop  message = TOO_MANY_FAILED_RECIPIENTS
        log_message = REJECTED - Too many failed recipients - count = $rcpt_fail_count
        condition = ${if > {${eval:$rcpt_fail_count}}{3}{yes}{no}}
        !verify = recipient/callout=2m,defer_ok,use_sender
  defer  message = DOMAIN_SUSPENDED
        condition = ${if exists{/etc/virtual/${domain}_off}{yes}{no}}
  drop  authenticated = *
        set acl_m_uid = ${perl{find_uid_auth_id}{$authenticated_id}}
        message = USER_ON_BLACKLIST_SMTP
        logwrite = User account $acl_m_username is blocked via BLACKLIST_USERNAMES
        condition = ${if exists{BLACKLIST_SMTP_USERNAMES}}
        condition = ${lookup{$acl_m_username}lsearch{BLACKLIST_SMTP_USERNAMES}{1}{0}}
        logwrite = User account $acl_m_username is blocked via BLACKLIST_SMTP_USERNAMES
  .include_if_exists /etc/exim.easy_spam_fighter/check_rcpt.mid.conf
  .include_if_exists /etc/exim.acl_check_recipient.mid.conf
  #Block Cracking - https://github.com/Exim/exim/wiki/BlockCracking
  .include_if_exists /etc/exim.blockcracking/auth.conf
  # restrict port 587 to authenticated users only
  # see also daemon_smtp_ports above
  accept  hosts = +auth_relay_hosts
	  condition = ${if eq {$interface_port}{587} {yes}{no}}
	  endpass
	  message = RELAY_NOT_PERMITTED_AUTH
	  authenticated = *
  # Deny all Mailer-Daemon messages not for us:
  deny message = We didn't send the message
       senders = :
       domains = !+relay_domains
	   !authenticated = *
  # Deny if the recipient doesn't exist:
    deny message = NO_SUCH_RECIPIENT
	 !verify = recipient
  # Remaining Mailer-Daemon messages must be for us
    accept senders = :
	   domains = +relay_domains
#EDIT#27:
  # 1st deny checks if it's a hostname or IPV4 address with dots or IPV6 address
    deny message = R1: HELO_SHOULD_BE_FQDN
         !authenticated = *
         condition   = ${if match{$sender_helo_name}{\N^\[\N}{no}{yes}}
         condition   = ${if match{$sender_helo_name}{\N\.\N}{no}{yes}}
  ## 2nd deny makes sure the hostname doesn't end with a dot (invalid)
  #  deny message = R2: HELO_SHOULD_BE_FQDN
  #       !authenticated = *
  #       condition   = ${if match{$sender_helo_name}{\N\.$\N}}
  # 3rd deny makes sure the hostname has no double-dots (invalid)
    deny message = R3: HELO_SHOULD_BE_FQDN
         !authenticated = *
         condition   = ${if match{$sender_helo_name}{\N\.\.\N}}
  ## 4th deny make sure the hostname doesn't end in .home (invalid domain)
  #  deny message = R4: HELO_SHOULD_BE_FQDN
  #       condition  = ${if match{$sender_helo_name}{\N\.home$\N}}
#EDIT#28:
  # warn domains = +skip_av_domains
  # set acl_m0 = $tod_epoch
#EDIT#29:
  deny  domains       = !+local_domains
        local_parts   = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
#EDIT#30:
  accept  hosts = :
          logwrite = Whitelisted as having local origination
#EDIT#32:
    deny message = 554 denied. 5.7.1 BLOCKED_DUE_TO_SPAM_SENDER
    domains = +use_rbl_domains
    domains = !+skip_rbl_domains
    hosts = !+skip_rbl_hosts : !+skip_rbl_hosts_ip
    senders = +blacklist_senders
#EDIT#33:
    deny message = 554 denied. 5.7.1 BLOCKED_DUE_TO_SPAM_HOST
       # only for domains that do want to be tested against RBLs
       hosts = +bad_sender_hosts
#EDIT#34:
    deny message = 554 denied. 5.7.1 BLOCKED_DUE_TO_SPAM_IP
       hosts = +bad_sender_hosts_ip
#EDIT#35:
  accept domains = +local_domains
         sender_domains = !+blacklist_domains
         hosts = !+bad_sender_hosts
         hosts = !+bad_sender_hosts_ip
         dnslists = list.dnswl.org&0.0.0.2
         dnslists = list.dnswl.org!=127.0.0.255
         logwrite = $sender_host_address whitelisted in list.dnswl.org
#EDIT#36:
  # accept domains = +local_domains
  #        dnslists = hostkarma.junkemailfilter.com=127.0.0.1
  #        logwrite = $sender_host_address whitelisted in hostkarma.junkemailfilter.com
#EDIT#37:
  # accept  local_parts = whitelist
  #         domains     = example.com
#EDIT#38:
  require verify = sender
#EDIT#39:
    deny message = 554 denied. 5.7.1 BLOCKED_DUE_TO_SPAM_DOMAIN
       sender_domains = +blacklist_domains
#EDIT#40:
#    deny message = 554 denied. 5.7.1 Forged Paypal Mail, not sent from PayPal.
#         senders = *@paypal.com
#         condition = ${if match {$sender_host_name}{\Npaypal.com$\N}{no}{yes}}
#EDIT#41:
  warn hosts = +skip_rbl_hosts
       logwrite = $sender_host_address RBL whitelisted in skip_rbl_hosts
  warn hosts = +skip_rbl_hosts_ip
       logwrite = $sender_host_address RBL whitelisted in skip_rbl_hosts_ip
  warn domains = +skip_rbl_domains
       logwrite = $sender_host_address RBL whitelisted $domain in skip_rbl_domains
  deny message = RBL_BLOCKED_BY_LIST
       hosts    = !+relay_hosts
       !authenticated = *
       dnslists = RBL_DNS_LIST
  .include_if_exists /etc/exim.easy_spam_fighter/check_rcpt.conf
  .include_if_exists /etc/exim.greylist.conf
#COMMENT#43:
# ACCEPT EMAIL BEGINNING HERE
  # accept if address is in a local domain as long as recipient can be verified
          endpass
	  message = UNKNOWN_USER
          verify = recipient
#COMMENT#44
  # accept if address is in a domain for which we relay as long as recipient
  # can be verified
  accept  domains = +relay_domains
          endpass
          verify = recipient
#EDIT#45:
  accept  hosts = +relay_hosts
          add_header = X-Relay-Host: $sender_host_address
          endpass
          message = AUTH_REQUIRED
          authenticated = *
  .include_if_exists /etc/exim.acl_check_recipient.post.conf
# FINAL DENY EMAIL BEFORE DATA BEGINS HERE
  # default at end of acl causes a "deny", but line below will give
  # an explicit error message:
  deny    message = RELAY_NOT_PERMITTED
# ACL CHECK DKIM
acl_check_dkim:
  .include_if_exists /etc/exim.easy_spam_fighter/check_dkim.conf
  accept
# ACL CHECK MESSAGE
# ACL that is used after the DATA command (ClamAV)
acl_check_message:
  warn
  .include_if_exists /etc/exim.acl_check_message.pre.conf
#EDIT#46.1#T9653
  warn    condition       = ${if !def:h_Message-ID: {yes}{no}}
          message         = Adding Message-ID header because it is missing!
          add_header      = Message-ID: <GENERATED-WASMISSING-$message_exim_id@$primary_hostname>
  .include_if_exists /etc/exim.easy_spam_fighter/check_message.conf
#EDIT#46:
#.include_if_exists /etc/exim.clamav.conf
  .include_if_exists /etc/exim.acl_check_message.post.conf
  accept
# ACL that is used for each MIME attachment in the email.
acl_check_mime:
  .include_if_exists /etc/exim.check_mime.conf.custom
  .include_if_exists /etc/exim.easy_spam_fighter/check_mime.conf
  accept
# AUTHENTICATION CONFIGURATION
begin authenticators
plain:
    driver = plaintext
    public_name = PLAIN
    server_prompts = :
    server_condition = "${perl{smtpauth}{0}}"
    server_set_id = $2
login:
    driver = plaintext
    public_name = LOGIN
    server_prompts = "Username:: : Password::"
    server_set_id = $1
#EDIT#47:
# REWRITE CONFIGURATION
# There is no rewriting specification in this exim.conf file. If your
# configuration requires one, it would go here
.include_if_exists /etc/exim.authenticators.post.conf
# ROUTERS CONFIGURATION
begin routers
#EDIT#48:
.include_if_exists /etc/exim.routers.pre.conf
lookuphost:
  driver = dnslookup
  domains = ! +local_domains
  ignore_target_hosts = 127.0.0.0/8
  condition = "${perl{check_limits}}"
  transport = remote_smtp
  no_more
# RELATED: http://help.directadmin.com/item.php?id=153
# smart_route:
#   driver = manualroute
#   domains = ! +local_domains
#   ignore_target_hosts = 127.0.0.0/8
#   condition = "${perl{check_limits}}"
#   route_list = !+local_domains HOSTNAME-or-IP#
#   transport = remote_smtp
#COMMENT#49:
#DIRECTORS CONFIGURATION
.include_if_exists /etc/exim.spamassassin.conf
#EDIT#50:
# Spam Assassin
#spamcheck_director removed. Use the exim.spamassassin.conf
majordomo_aliases:
  driver = redirect
  allow_defer
  allow_fail
  data = ${if exists{/etc/virtual/${domain}/majordomo/list.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/list.aliases}}}}
  domains = lsearch;/etc/virtual/domainowners
  file_transport = address_file
  group = daemon
  pipe_transport = majordomo_pipe
  retry_use_local_part
  no_rewrite
  user = majordomo
majordomo_private:
  driver = redirect
  allow_defer
  allow_fail
  #condition = "${if eq {$received_protocol} {local} {true} {false} }"
  condition = "${if or { {eq {$received_protocol} {local}} \
                         {eq {$received_protocol} {spam-scanned}} } {true} {false} }"
  data = ${if exists{/etc/virtual/${domain}/majordomo/private.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/private.aliases}}}}
  group = daemon
  user = majordomo
domain_filter:
  driver = redirect
  allow_filter
  no_check_local_user
  condition = "${if exists{/etc/virtual/${domain}/filter}{yes}{no}}"
  user = "${lookup{$domain}lsearch{/etc/virtual/domainowners}{$value}}"
  group = "mail"
  file = /etc/virtual/${domain}/filter
  directory_transport = address_file
  pipe_transport = virtual_address_pipe
  no_verify
uservacation:
  # uservacation reply to all except errors, bounces, lists
  driver = accept
  condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/vacation.conf}{yes}{no}}
  condition = ${if match{$h_X-Spam-Status:}{\N^Yes\N}{no}{yes}}
  require_files = /etc/virtual/${domain}/reply/${local_part}.msg
  # do not reply to errors and bounces or lists
  senders = " ! ^.*-request@.*:\
              ! ^owner-.*@.*:\
              ! ^postmaster@.*:\
              ! ^listmaster@.*:\
              ! ^mailer-daemon@.*\
              ! ^root@.*"
  transport = uservacation
  unseen
userautoreply:
  driver = accept
  condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/autoresponder.conf}{yes}{no}}
              ! ^owner-.*@.*:\
              ! ^postmaster@.*:\
              ! ^listmaster@.*:\
              ! ^root@.*"
  transport = userautoreply
  unseen
#any callbacks doing sender verify checks to this server accept SRS0 encoded emails if they exist, else the verify will fail.
#until we figure out how to extract the original forwarder name in exim, we'll accept and drop all SRS0 encoded emails.
#the srs_recipient is the original remote sender, so we dont want to forwarder there, else it will generated untraced backscatter (no data=srs_recipient)
#I had found srs_orig_recipient variable, but wasn't able to use it to check for local fordwarders.
#so any email to [email protected] will be accepted and dropped into the :blackhole:, which should be sufficient to satisfy the sender verify, and prevent any spam since it's always dropped.
#if the final recipient hits "reply", it should already go to the orignal remote sender, not to the SRS name.
srs_router:
  driver =	redirect
  condition = ${if exists{/etc/exim.srs.forward.conf}}
  srs =		reverse
  data = :blackhole:
#forwarder exists
#user exists
virtual_user_unseen:
  driver = accept
  condition = ${if exists{/etc/virtual/${domain}/passwd}{1}{0}}
  condition = ${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}{1}{0}}
  condition = ${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}{${if eq{$value}{$local_part}{0}{1}}}{0}}
  condition = ${perl{save_virtual_user}}
  group = mail
  .include_if_exists /etc/exim/local_part_suffix.conf
  transport = dovecot_lmtp_udp
  unseen
#forwarder exists
#user does not exist
virtual_aliases_nouser_nostar:
  driver = redirect
  .include_if_exists /etc/exim.srs.forward.conf
  allow_defer
  allow_fail
  condition = ${lookup{$local_part}lsearch{/etc/virtual/${domain}/passwd}{0}{1}}
  data = ${lookup{$local_part}lsearch{/etc/virtual/$domain/aliases}}
  group = mail
#forwarder does not exist
#user exists
virtual_user:
  driver = accept
  condition = ${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}{0}{1}}
  group = mail
#wildcard forwarder
#user should have already been caught above
virtual_aliases:
  #only the wildcard will be used here
  driver = redirect
  allow_defer
  allow_fail
  data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch*{/etc/virtual/$domain/aliases}}}}
  group = mail
#COMMENT#51:
drop_solo_alias:
  driver = redirect
  allow_defer
  allow_fail
  data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch{/etc/virtual/$domain/aliases}}}}
  file_transport = devnull
  group = mail
  pipe_transport = devnull
  #include_domain = true
#COMMENT#52:
userforward:
  driver = redirect
  allow_filter
  check_ancestor
  check_local_user
  no_expn
  file = $home/.forward
  pipe_transport = address_pipe
  reply_transport = address_reply
  directory_transport = address_directory
  no_verify
system_aliases:
  driver = redirect
  allow_defer
  allow_fail
  data = ${lookup{$local_part}lsearch{/etc/aliases}}
  # user = exim
localuser:
  driver = accept
  check_local_user
  condition = "${if eq {$domain} {$primary_hostname} {yes} {no}}"
  transport = local_delivery
#COMMENT#53:
# TRANSPORTS CONFIGURATION
begin transports
.include_if_exists /etc/exim.transports.pre.conf
#COMMENT#54:
spamcheck:
  driver = pipe
  batch_max = 100
  command = /usr/sbin/exim -oMr spam-scanned -bS
  current_directory = "/tmp"
  group = mail
  home_directory = "/tmp"
  log_output
  message_prefix =
  message_suffix =
  return_fail_output
  no_return_path_add
  transport_filter = /usr/bin/spamc -u ${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}
  use_bsmtp
  user = mail
#COMMENT#55:
majordomo_pipe:
  driver = pipe
  group = daemon
  return_fail_output
  user = majordomo
#COMMENT#56:
local_delivery:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/passwd}{$value}}}}/Maildir/"
  directory_mode = 770
  create_directory = true
  maildir_format
  group = mail
  mode = 0660
  return_path_add
  user = ${local_part}
#COMMENT#57:
virtual_localdelivery:
  driver = appendfile
  create_directory
  delivery_date_add
  envelope_to_add
  directory = "${extract{5}{:}{${lookup{${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}}lsearch{/etc/passwd}{$value}}}}/imap/${domain}/${local_part}/Maildir"
  maildir_format
  group = mail
  mode = 660
  return_path_add
  user = "${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}"
  quota = ${if exists{/etc/virtual/${domain}/quota}{${lookup{$local_part}lsearch*{/etc/virtual/${domain}/quota}{$value}{0}}}{0}}
  .include_if_exists /etc/exim/virtual_localdelivery.conf.post
#EDIT#58:
uservacation:
  driver = autoreply
  file = /etc/virtual/${domain}/reply/${local_part}.msg
  from = "${local_part}@${domain}"
  log = /etc/virtual/${domain}/reply/${local_part}.log
  no_return_message
  headers = ${if exists{/etc/virtual/${domain}/reply/${local_part}.headers}{${readfile{/etc/virtual/${domain}/reply/${local_part}.headers}}}}
  subject = ${if def:h_Subject: {\
                ${if exists{/etc/virtual/${domain}/reply/${local_part}.subject}\
                    {${readfile{/etc/virtual/${domain}/reply/${local_part}.subject}{}}}\
                    {Autoreply}\
                }: ${quote:${escape:${length_60:$h_Subject:}}}}\
                {I am on vacation}}
  to = "${reply_address}"
  user = mail
  once = /etc/virtual/${domain}/reply/${local_part}.once
  once_file_size = 100K
  once_repeat = ${if exists{/etc/virtual/${domain}/reply/${local_part}.once_time}{${readfile{/etc/virtual/${domain}/reply/${local_part}.once_time}{}}}{2d}}
#COMMENT#59:
userautoreply:
  driver = autoreply
  bcc = ${lookup{${local_part}} lsearch {/etc/virtual/${domain}/autoresponder.conf}{$value}}
  no_return_message
                    {Autoreply}\
                {Autoreply Message}}
  user = mail
#COMMENT#60:
devnull:
  driver = appendfile
  file = /dev/null
#COMMENT#61:
remote_smtp:
  driver = smtp
  headers_add = "${if def:authenticated_id{X-Authenticated-Id: ${authenticated_id}}}"
  interface = <; ${if exists{/etc/virtual/domainips}{${lookup{$sender_address_domain}lsearch*{/etc/virtual/domainips}}}}
  helo_data = ${if exists{/etc/virtual/helo_data}{${lookup{$sending_ip_address}iplsearch{/etc/virtual/helo_data}{$value}{$primary_hostname}}}{$primary_hostname}}
  hosts_try_chunking =
.include_if_exists /etc/exim.dkim.conf
#EDIT#62:
address_pipe:
  driver = pipe
  return_output
virtual_address_pipe:
  driver = pipe
  group = nobody
  return_output
  user = "${lookup{$domain}lsearch* {/etc/virtual/domainowners}{$value}}"
.include_if_exists /etc/exim.cagefs.pipe.conf
#COMMENT#63:
address_file:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  return_path_add
#COMMENT#64:
address_reply:
  driver = autoreply
dovecot_lmtp_udp:
  driver = lmtp
  socket = /var/run/dovecot/lmtp
  #maximum number of deliveries per batch, default 1
  batch_max = 200
  delivery_date_add
  envelope_to_add
  return_path_add
  user = mail
address_directory:
  driver = appendfile
  maildir_format
  maildir_use_size_file
  delivery_date_add
  envelope_to_add
  return_path_add
# RETRY CONFIGURATION
#EDIT#65:
# Domain               Error       Retries
begin retry
*                      quota
*                      *           F,2h,15m; G,16h,1h,1.5; F,4d,8h
# End of Exim 4 configuration
If you can help please do so.
I've carried on by trying to get SpamAsssasin working as its the only thing I can think of that would be different to my other setups.
Thanks all.
Thanks all.
Recompilation did not work.
 exim.service - Exim Mail Transport Agent
   Loaded: loaded (/etc/systemd/system/exim.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Thu 2019-10-31 09:37:06 CET; 27s ago
  Process: 5600 ExecStart=/usr/sbin/exim -bd -q${QUEUE} (code=exited, status=127)
 Main PID: 5600 (code=exited, status=127)
Above is output of service exit status
service exim status outputs:
Oct 31 13:08:06 server1.london.gethosted.online exim[20773]: /usr/sbin/exim: error while loading shared libraries: libsrs_alt.so.1: cannot open shared object file: No such file or directory
Problem was with libsrs_alt, it needed to be compiled via CustomBuild. My apologies!
For anybody struggling with the same problem:
 /usr/local/directadmin/custombuild/build libsrs_alt
