(Ask) How to Disable Local Value PHP.ini ?
aldhy
How to disable local value on directadmin?
I want to disable sendmail path for all user
thank you
"Local value" should be changed in /usr/local/directadmin/data/templates/custom/php-fpm.conf (copy it from /usr/local/directadmin/data/templates/php-fpm.conf) if you use PHP-FPM and in Apache's templates if you run PHP with a different mode.
Rewrite configs each time when you modify templates.
I use LSPHP, not php-fpm
