DA support for Nginx vs Apache
CanadaGuy
Was DA designed around Apache from the start? I see a number of Apache options peppered throughout the configuration. Is there equal support and capability for both servers in DA?
Note: I'm not concerned about which is better for a certain task, just DA support or integration with the server itself.
If not to take difference between Nginx and Apache into consideration, DirectAdmin supports the both good enough, as well as LiteSpeed and OpenLiteSpeed. I mean all features offered in DirectAdmin web-interface for a web-site can be used with any of supported web-servers.
Thanks, I didn't intentionally leave *Litespeed out, but thanks for mentioning it. Do any of the web servers have built in support for Python?
cPanel seems the same way for Python regarding the need for CloudLinux. Is there a technical reason for this?
