apache service interruption
yrdesign
Apache always interrupts itself and then restarts itself.
This causes 1-2 second interruptions to access the customer's website.
Nov 20 14:53:01 hkda3 systemd: Started Session c225125 of user root.
Nov 20 14:53:01 hkda3 systemd: Started Session c225126 of user root.
Nov 20 14:53:01 hkda3 systemd: Stopping The Apache HTTP Server...
Nov 20 14:53:02 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=43.240.100.34 DST=43.240.15.184 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=59923 DF PROTO=TCP SPT=55896 DPT=8291 WINDOW=14600 RES=0x00 SYN URGP=0
Nov 20 14:53:04 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=103.51.44.110 DST=103.51.147.66 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=14204 DF PROTO=TCP SPT=43747 DPT=7547 WINDOW=14600 RES=0x00 SYN URGP=0
Nov 20 14:53:06 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=119.61.28.114 DST=123.254.106.25 LEN=44 TOS=0x00 PREC=0x00 TTL=231 ID=28178 PROTO=TCP SPT=41789 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:06 hkda3 systemd: httpd.service stop-sigterm timed out. Killing.
Nov 20 14:53:06 hkda3 systemd: httpd.service: main process exited, code=killed, status=9/KILL
Nov 20 14:53:07 hkda3 systemd: Stopped The Apache HTTP Server.
Nov 20 14:53:07 hkda3 systemd: Unit httpd.service entered failed state.
Nov 20 14:53:07 hkda3 systemd: httpd.service failed.
Nov 20 14:53:07 hkda3 systemd: Starting The Apache HTTP Server...
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/hkpang2cefhost/domains/sharedip] does not exist
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/pn47/domains/sharedip] does not exist
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/pn48cefhost/domains/sharedip] does not exist
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/pn48cefhost/domains/suspended/test] does not exist
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/admin/domains/suspended/m] does not exist
Nov 20 14:53:07 hkda3 httpd: AH00112: Warning: DocumentRoot [/home/pangnet3/domains/suspended/cloud] does not exist
Nov 20 14:53:08 hkda3 systemd: Started The Apache HTTP Server.
Nov 20 14:53:08 hkda3 kernel: Firewall: *ICMP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=54.255.219.22 DST=122.10.90.178 LEN=36 TOS=0x00 PREC=0x00 TTL=239 ID=28483 DF PROTO=ICMP TYPE=8 CODE=0 ID=17 SEQ=17128
Nov 20 14:53:08 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=89.248.167.136 DST=43.240.12.12 LEN=44 TOS=0x00 PREC=0x00 TTL=239 ID=27799 PROTO=TCP SPT=43427 DPT=59279 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:10 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=222.186.10.96 DST=103.39.111.77 LEN=80 TOS=0x00 PREC=0x00 TTL=44 ID=15808 DF PROTO=UDP SPT=56137 DPT=389 LEN=60
Nov 20 14:53:10 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=222.186.10.96 DST=103.39.111.72 LEN=80 TOS=0x00 PREC=0x00 TTL=44 ID=32128 DF PROTO=UDP SPT=56137 DPT=389 LEN=60
Nov 20 14:53:10 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=222.186.10.96 DST=103.39.111.66 LEN=80 TOS=0x00 PREC=0x00 TTL=44 ID=49919 DF PROTO=UDP SPT=56137 DPT=389 LEN=60
Nov 20 14:53:10 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=222.186.10.96 DST=103.39.111.64 LEN=80 TOS=0x00 PREC=0x00 TTL=44 ID=25451 DF PROTO=UDP SPT=56137 DPT=389 LEN=60
Nov 20 14:53:14 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=103.39.232.200 DST=103.39.111.190 LEN=44 TOS=0x00 PREC=0x00 TTL=237 ID=43566 PROTO=TCP SPT=52813 DPT=88 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:16 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=202.102.144.120 DST=103.51.147.67 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=43977 PROTO=TCP SPT=46459 DPT=52625 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:18 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=184.105.247.203 DST=122.10.90.176 LEN=30 TOS=0x00 PREC=0x00 TTL=55 ID=9526 DF PROTO=UDP SPT=32710 DPT=5351 LEN=10
Nov 20 14:53:18 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=202.102.144.120 DST=123.108.110.249 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=22085 PROTO=TCP SPT=46459 DPT=53249 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:20 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=89.248.167.136 DST=103.51.144.53 LEN=44 TOS=0x00 PREC=0x00 TTL=237 ID=27290 PROTO=TCP SPT=43427 DPT=59048 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:23 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=202.102.144.120 DST=103.51.144.53 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=24441 PROTO=TCP SPT=46459 DPT=52773 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:25 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=60.191.38.78 DST=123.254.107.197 LEN=44 TOS=0x00 PREC=0x00 TTL=109 ID=51771 PROTO=TCP SPT=51519 DPT=666 WINDOW=29200 RES=0x00 SYN URGP=0
Nov 20 14:53:27 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=80.82.70.187 DST=103.51.147.60 LEN=44 TOS=0x00 PREC=0x00 TTL=240 ID=52976 PROTO=TCP SPT=52719 DPT=8910 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:28 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=223.71.167.154 DST=103.51.147.65 LEN=28 TOS=0x04 PREC=0x00 TTL=115 ID=54094 PROTO=UDP SPT=55659 DPT=7 LEN=8
Nov 20 14:53:28 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=123.116.201.55 DST=123.254.108.57 LEN=44 TOS=0x00 PREC=0x00 TTL=51 ID=58652 PROTO=TCP SPT=17768 DPT=60001 WINDOW=7483 RES=0x00 SYN URGP=0
Nov 20 14:53:30 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=92.118.160.29 DST=123.108.110.255 LEN=44 TOS=0x00 PREC=0x00 TTL=242 ID=9401 PROTO=TCP SPT=64960 DPT=5903 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:33 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=89.248.168.62 DST=122.10.90.176 LEN=44 TOS=0x00 PREC=0x00 TTL=238 ID=56872 PROTO=TCP SPT=43419 DPT=60566 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:34 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=185.176.27.122 DST=103.51.147.72 LEN=44 TOS=0x00 PREC=0x00 TTL=238 ID=12876 PROTO=TCP SPT=8080 DPT=8657 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:53:36 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=202.102.144.120 DST=123.254.106.25 LEN=44 TOS=0x00 PREC=0x20 TTL=243 ID=14601 PROTO=TCP SPT=46459 DPT=51189 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:54:01 hkda3 systemd: Started Session c225127 of user root.
Nov 20 14:54:01 hkda3 systemd: Started Session c225128 of user root.
Nov 20 14:54:01 hkda3 systemd: Stopping The Apache HTTP Server...
Nov 20 14:54:01 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=62.210.10.244 DST=123.254.110.66 LEN=513 TOS=0x00 PREC=0x00 TTL=239 ID=10381 PROTO=UDP SPT=7707 DPT=5060 LEN=493
Nov 20 14:54:01 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=62.210.10.244 DST=123.254.110.65 LEN=513 TOS=0x00 PREC=0x00 TTL=239 ID=13316 PROTO=UDP SPT=7707 DPT=5060 LEN=493
Nov 20 14:54:03 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=81.22.45.225 DST=103.39.111.78 LEN=44 TOS=0x00 PREC=0x00 TTL=238 ID=1337 PROTO=TCP SPT=45627 DPT=2716 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:54:04 hkda3 kernel: Firewall: *TCP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=103.227.241.51 DST=123.254.108.56 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=13208 PROTO=TCP SPT=45284 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0
Nov 20 14:54:06 hkda3 systemd: httpd.service stop-sigterm timed out. Killing.
Nov 20 14:54:06 hkda3 systemd: httpd.service: main process exited, code=killed, status=9/KILL
Nov 20 14:54:06 hkda3 systemd: Stopped The Apache HTTP Server.
Nov 20 14:54:06 hkda3 systemd: Unit httpd.service entered failed state.
Nov 20 14:54:06 hkda3 systemd: httpd.service failed.
Nov 20 14:54:06 hkda3 systemd: Starting The Apache HTTP Server...
Nov 20 14:54:06 hkda3 kernel: Firewall: *UDP_IN Blocked* IN=enp4s0 OUT= MAC=00:24:ec:f0:00:e2:00:00:5e:00:01:04:08:00 SRC=216.218.206.101 DST=103.39.111.188 LEN=29 TOS=0x00 PREC=0x00 TTL=55 ID=1525 DF PROTO=UDP SPT=12318 DPT=1434 LEN=9
Here,:
What's the PHP mode used there? Any other 3rd party modules loaded in apache?
[root@hkda3 ~]# httpd -l
Compiled in modules:
  core.c
  mod_authn_file.c
  mod_authn_dbm.c
  mod_authn_anon.c
  mod_authn_dbd.c
  mod_authn_socache.c
  mod_authn_core.c
  mod_authz_host.c
  mod_authz_groupfile.c
  mod_authz_user.c
  mod_authz_dbm.c
  mod_authz_owner.c
  mod_authz_dbd.c
  mod_authz_core.c
  mod_access_compat.c
  mod_auth_basic.c
  mod_auth_form.c
  mod_auth_digest.c
  mod_allowmethods.c
  mod_file_cache.c
  mod_cache.c
  mod_cache_disk.c
  mod_cache_socache.c
  mod_socache_shmcb.c
  mod_socache_dbm.c
  mod_socache_memcache.c
  mod_socache_redis.c
  mod_so.c
  mod_watchdog.c
  mod_macro.c
  mod_dbd.c
  mod_dumpio.c
  mod_buffer.c
  mod_ratelimit.c
  mod_reqtimeout.c
  mod_ext_filter.c
  mod_request.c
  mod_include.c
  mod_filter.c
  mod_substitute.c
  mod_sed.c
  mod_deflate.c
  http_core.c
  mod_mime.c
  mod_log_config.c
  mod_log_debug.c
  mod_logio.c
  mod_env.c
  mod_expires.c
  mod_headers.c
  mod_unique_id.c
  mod_setenvif.c
  mod_version.c
  mod_remoteip.c
  mod_proxy.c
  mod_proxy_connect.c
  mod_proxy_ftp.c
  mod_proxy_http.c
  mod_proxy_fcgi.c
  mod_proxy_scgi.c
  mod_proxy_uwsgi.c
  mod_proxy_fdpass.c
  mod_proxy_wstunnel.c
  mod_proxy_ajp.c
  mod_proxy_balancer.c
  mod_proxy_express.c
  mod_proxy_hcheck.c
  mod_session.c
  mod_session_cookie.c
  mod_session_dbd.c
  mod_slotmem_shm.c
  mod_ssl.c
  mod_http2.c
  mod_lbmethod_byrequests.c
  mod_lbmethod_bytraffic.c
  mod_lbmethod_bybusyness.c
  mod_lbmethod_heartbeat.c
  mod_unixd.c
  mod_dav.c
  mod_status.c
  mod_autoindex.c
  mod_info.c
  mod_suexec.c
  mod_cgi.c
  mod_dav_fs.c
  mod_dav_lock.c
  mod_vhost_alias.c
  mod_negotiation.c
  mod_dir.c
  mod_actions.c
  mod_speling.c
  mod_userdir.c
  mod_alias.c
  mod_rewrite.c
[root@hkda3 ~]# httpd -M
Loaded Modules:
 core_module (static)
 authn_file_module (static)
 authn_dbm_module (static)
 authn_anon_module (static)
 authn_dbd_module (static)
 authn_socache_module (static)
 authn_core_module (static)
 authz_host_module (static)
 authz_groupfile_module (static)
 authz_user_module (static)
 authz_dbm_module (static)
 authz_owner_module (static)
 authz_dbd_module (static)
 authz_core_module (static)
 access_compat_module (static)
 auth_basic_module (static)
 auth_form_module (static)
 auth_digest_module (static)
 allowmethods_module (static)
 file_cache_module (static)
 cache_disk_module (static)
 cache_socache_module (static)
 socache_shmcb_module (static)
 socache_dbm_module (static)
 socache_memcache_module (static)
 socache_redis_module (static)
 so_module (static)
 watchdog_module (static)
 macro_module (static)
 dbd_module (static)
 dumpio_module (static)
 buffer_module (static)
 ratelimit_module (static)
 reqtimeout_module (static)
 ext_filter_module (static)
 request_module (static)
 include_module (static)
 substitute_module (static)
 sed_module (static)
 deflate_module (static)
 http_module (static)
 mime_module (static)
 log_config_module (static)
 log_debug_module (static)
 logio_module (static)
 env_module (static)
 expires_module (static)
 headers_module (static)
 unique_id_module (static)
 setenvif_module (static)
 version_module (static)
 remoteip_module (static)
 proxy_module (static)
 proxy_connect_module (static)
 proxy_ftp_module (static)
 proxy_http_module (static)
 proxy_fcgi_module (static)
 proxy_scgi_module (static)
 proxy_uwsgi_module (static)
 proxy_fdpass_module (static)
 proxy_wstunnel_module (static)
 proxy_ajp_module (static)
 proxy_balancer_module (static)
 proxy_express_module (static)
 proxy_hcheck_module (static)
 session_module (static)
 session_cookie_module (static)
 session_dbd_module (static)
 slotmem_shm_module (static)
 ssl_module (static)
 http2_module (static)
 lbmethod_byrequests_module (static)
 lbmethod_bytraffic_module (static)
 lbmethod_bybusyness_module (static)
 lbmethod_heartbeat_module (static)
 unixd_module (static)
 dav_module (static)
 status_module (static)
 autoindex_module (static)
 info_module (static)
 suexec_module (static)
 cgi_module (static)
 dav_fs_module (static)
 dav_lock_module (static)
 vhost_alias_module (static)
 negotiation_module (static)
 dir_module (static)
 actions_module (static)
 speling_module (static)
 userdir_module (static)
 rewrite_module (static)
 suphp_module (shared)
 systemd_module (shared)
 mpm_event_module (shared)
 proctitle_module (shared)
 hostinglimits_module (shared)
I have cloudlinux installed
[root@hkda3 ~]# httpd -V
Server version: Apache/2.4.41 (Unix)
Server built:   Oct 13 2019 14:27:55
Server's Module Magic Number: 20120211:88
Server loaded:  APR 1.6.5, APR-UTIL 1.6.1
Compiled using: APR 1.6.5, APR-UTIL 1.6.1
Architecture:   64-bit
Server MPM:     event
  threaded:     yes (fixed thread count)
    forked:     yes (variable process count)
Server compiled with....
 -D APR_HAS_SENDFILE
 -D APR_HAS_MMAP
 -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
 -D APR_USE_SYSVSEM_SERIALIZE
 -D APR_USE_PTHREAD_SERIALIZE
 -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
 -D APR_HAS_OTHER_CHILD
 -D AP_HAVE_RELIABLE_PIPED_LOGS
 -D DYNAMIC_MODULE_LIMIT=256
 -D HTTPD_ROOT="/etc/httpd"
 -D HAVE_SYSTEMD
 -D SUEXEC_BIN="/usr/sbin/suexec"
 -D DEFAULT_PIDLOG="/var/logs/httpd.pid"
 -D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
 -D DEFAULT_ERRORLOG="logs/error_log"
 -D AP_TYPES_CONFIG_FILE="conf/mime.types"
 -D SERVER_CONFIG_FILE="conf/httpd.conf"
