ZipperZapper
- Nov 30, 2015
I installed a fresh DirectAdmin on Ubuntu 18.04 (License set to the general Linux 64-bit) and after some troubleshooting in the Debian 10 beta subforum most of it works just fine now. But there's one big thing that doesn't work across the entire system: restarting services by DirectAdmin. I can't seem to find the right logs/places to look for the issue.
#1
So first of all the Services Monitor within DirectAdmin. Pressing restart results in the same error for every service that's listed there:
Doing it by hand through SSH (sudo service nginx restart) works perfectly fine.
#2
DirectAdmin is not able to restart itself. For example when I change something in Administrator Settings, it will say 'DirectAdmin will be restarted within 1 minute', but it will never do that.
There are no obvious errors shown, other then the fact changes I make won't take effect unless I SSH into the server and restart DirectAdmin with a 'sudo service directadmin restart'
#3
Restoring databases wasn't working at first, with both gunzip and MySQL throwing an error like this:
This I could fix with a symlink but seems to suggest again DirectAdmin is constantly looking in the wrong places.
#4
Today I found out that after a user on my site created a new domain, all the relevant folders, files and settings are there, but "./build rewrite_confs" isn't done, making the site unreachable for the user untill I perform a rewrite with the button under 'Custom HTTPD Configurations'. That works fine, but it seems like DirectAdmin is unable to perform it automaticly.
Summary
It seems to me something is fundamentaly wrong with the way DirectAdmin is trying to perform actions and find/use services on my system.
I can't find the right logs or setting to fix it.
#1
An error has occurred
/usr/bin/systemctl restart nginx.service 2>&1
/usr/bin/systemctl restart php-fpm73.service 2>&1
#2
#3
Unable to restore database xxxx to xx : sh: /usr/bin/mysql: No such file or directory
Unable to find /usr/bin/gunzip
ln -s /bin/gunzip /usr/bin/gunzip
#4
Summary
