dyndns script
spacecabbie
The Netherlands
Something useful i found online
Its indutch but essentially a script using the DA httpsocket php ( https://files.directadmin.com/services/all/httpsocket/ )
All credits go to the original poster: Jeroen S
PHP:
<?php
include 'httpsocket.php';
$server_login="username";
$server_pass="password";
$server_host="directadminserver"; //where the API connects to
$server_ssl="Y";
$server_port=2222;
$domains = ["domein1.nl", "domein2.nl", "domein3.nl", "domein4.nl", "domein5.nl", "domein6.nl"];
$url='http://ipecho.net/plain';
$ch=curl_init();
$timeout=5;
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
$publicip=curl_exec($ch);
echo ("Public IPV4=".$publicip."\n");
curl_close($ch);
$data = json_decode(file_get_contents("directadminddns.dat"), true);
if ($data["publicip"] != $publicip)
    echo ("Public IP has changed to $publicip, updating dns...\n");
    foreach ($domains as $domain)
    $sock = new HTTPSocket;
    if ($server_ssl == 'Y')
        $sock->connect("ssl://".$server_host, $server_port);
    else
        $sock->connect($server_host, $server_port);
    $sock->set_login($server_login,$server_pass);
    $sock->query('/CMD_API_DNS_CONTROL',
        array(
            'domain' => $domain,
    $result = $sock->fetch_parsed_body();
    var_dump ($result);
        array(
            'action' => 'select',
            'arecs0' => 'name='.$domain.'.',
    var_dump ($result);
        array(
            'action' => 'add',
            'type' => 'A',
            'name' => $domain.'.',
            'value'    => $publicip,
        $data = array();
    $data["publicip"] = $publicip;
    file_put_contents("directadminddns.dat", json_encode($data));
else
    echo ("Public IP not changed, no update needed\n");
But that would be only with domains with Vimexx?
There are more threads about this on the DA forums like this one:
As you can read there in post #12 and #14 I also found some from a Dutch guy. And Sellerone changed it to a working one.
So I'm curious if this is indeed from Jeroen S. or if created it from the thread I mentioned.
And wondering which one works best/easiest.
OH good point din't see that post even though i have searched for dyndns.
I have no clue who the origin is I just mentioned the source i got it from.
Although from first glance the original from DA Forum seems more adjusted for dyndns where as the one I linked runs standalone but require a web server running locally. I am working to change it to command line so i can run it in a cron job on my freenas.
The dyndns one is not relevant for me since that can easily be done with a cname.
How do you mean? I'm also Dutch and don't understand everything.
I would also like to use a domain of my own and then a subdomain like sub.richard.nl as dyndns. But it has to be changed easily. Like with a protected web interface like no-ip.org and dyndns.org have. What exactly is done via a cname as you mention?
Basicaly you create a dyndns and then link a cname subdomain to it.
See https://daniel.haxx.se/blog/2012/08/20/fixed-name-to-dynamic-ip-with-cname/
