Migdiradmin
- Jan 5, 2020
DirectAdmin is a fight to install things
CPanel you can install everything without errors to resolve, here....
After try to install SpamAssansin from costum build show this errors:
After try to install some dependencies
Yum install cpan re2c
Tried again to install by costumbuild
So the Solution is run
And now you can go to the custombuild to build without errors...
If needed, use cpan to install the missing modules, eg:
cpan -i Archive::Tar Digest::SHA Mail::SPF IP::Country Net::Ident IO::Socket::INET6 Compress::Zlib Mail::DKIM LWP::UserAgent HTTP::Date Encode::Detect ExtUtils::MakeMaker NetAddr::IP Mail::SpamAssassin::Plugin::Razor2 Razor2::Client::Agent IO::Socket::SSL DBI
Press enter to answer [yes] if it asks you to install dependencies (it will prepend them to the queue)
Answer no if it asks: Are you ready for manual configuration? [yes] no
Trying to make SpamAssassin...
make: *** No targets specified and no makefile found. Stop.
cpan -i
Archive::Tar
Digest::SHA
Mail::SPF
IP::Country
Net::Ident
IO::Socket::INET6
Compress::Zlib
Mail::DKIM
LWP::UserAgent
yum install spamassassin -y && yum erase spamassassin -y
