Richard G
I know them, seen the series here and I like it.Just in case... get acquainted!
I want to report I just try Let's Encrypt 1.1.33, but still same problem, I think I better to keep 1.1.25 for using
ACME v2 - Scheduled deprecation of unauthenticated resource GETs
Let's Encrypt certificates auto-renew themselves. Are you going to re-add these DNS records manually every 60 days? I wouldn't call this auto-renewal though, as it'd require manual action
Thanks, but your link is not working...Hi,
This is my first default/basic DA server setup, using the default setup and getting a lot of issues to make things working.
I am troubleshooting in the last 7 days, already post in other forum categories and I did not get any help.
Some time ago I use DA and DirectAdmin forum was very active and helpful.
I really hope that somebody could help me with this DA issue with Let's Encrypt wildcard limitation.
I tried to install Let's Encrypt wildcard but I get an error because DA script do not allow me to add the LE activation record on my external DNS.
This seem to be a DA limitation because PLESK allow users to set the LE activation record for wildcard on external DNS server.
Plesk guide
https://docs.plesk.com/en-US/obsidia...encrypt.79603/
"Whether the Let’s Encrypt extension adds the DNS record automatically or you do it manually, it can take some time before it propagates. We recommend that you check that the DNS record was added before going to the next step. Here is how you can do it:"
So how can DA users know which TXT record should we add for complete certificate validation ?
This feature exist so when will it be fixed to allow users to add the record in the external DNS server ?
I think so, my domain have some MX, A type and CNAME 's and value to external ip(out of my server, like google suite's server), so I think that is the problem why we can't finish and get ssl certHi Martynas,
Plesk is doing why DirectAdmin do not allow Lets Encrypt wildcard certificates when using external DNS servers ?
This seems not good because the way DA is doing it I can not get LE wildcard certificates into DirectAdmin.
It should be available, just change the script and allow the user to see the activation record that he need to add in external DNS with a confirmation button to continue the script.
Do not seem very complicated and will allow to work with both local DNS and external DNS.
Seems logical, I did not expect to see this limitation on DirectAdmin because DA is very active in implementing new features.
Doing this way will limit the use of LE wildcard certificates for local DNS that is a no sense because awe all now that its better to get a external DNS service.
P.S: Let's Encrypt 1.1.25 is not work anymore(I think something changed and it not work anymore =_=!) , even 1.1.38
@glio
Are you sure it's not only a matter of deleting the _acme-challenge record? Because I had the same problem in some previous versions.
@crenet
This thread was initiated by my ISP and virtually marked as solved by me because some versions ago DA actually started to works with LE wildcard on external DNS. Read some pages back on this thread.
