DirectAdmin 1.60.0 RC1
I submit this
redacted
But wen i go to the DirectAdmin panel is the same.
Server Version: 1.59.5
The pre-release binaries will always show the older version, so that once the newer version comes out, you can click to get it.
If the pre-release had 1.60.0, the updater would block the update as it would think it has the latest version.
Use the "compile time" to confirm the binary age.
Either way, 1.60.0 was just released, so you can go into your Licenses/Updates page to have DA do the update for you.
But next time you can use a build number diferent for release candidate like.
1.60.0 -Release Candidate 1
1.60.1 -Release / Stable
Version doesn’t change with pre-release :)
Hello Martynas, actually waiting this feature myself for better identification. It's small, but It takes away the doubt and we can see when the version has changed when we update prerelease binaries before the final release. Sometimes there are cache issues in DA and that eliminates that suspicion, so we know that the pre-release is installed 100%. Also naming the releases with Beta, RC and stable is great idea in general.
