- Feb 27, 2003
We're very pleased to announce the full release of DirectAdmin 1.60.0.
The full list of changes can be found in the versions system:
This is a major release with many new significant features and bug-fixes, most of which are listed below:
New Features:
Bug Fixes:
To update, go to:
New Features:
- Real-time Quotas for Users, enabled by default
- Sub-Locations for ALL hook scripts (Plugins, hooked folder name for multiple scripts on same hook)
- Background Restore tracking in GUI
- More extensive wildcards for SpamAssassin/RSpamd whitelists/blacklists
- More Admin Level files included in Admin account backup
- Can create FTP/EMAIL by passing pre-crypted password
- File Manager: "Compress and Download" to use relative backup in tar.gz/zip
- Master Login: User switcher while logged in as User
- Command Line Create Login URL: ability to specify landing page after login
- Database: download raw .sql from GUI
- Use pigz in more areas, when available
- Internal translation option for mail_settings.html template
- Option: PHP_INI_SCAN_DIR for crons to use that php version/ini
- Suspension API: Ability to add more info about the suspension
- Hotlink Protection in GUI
- CMD_API_SHOW_USERS to show any user.conf variable upon request for all Users in 1 call
- Default Change: restore_database_as_admin=1 for all Admin Level Restores for routines/functions: SUPER PRIVILEGE
- /etc/virtual/domainips to list both IPv4 and IPv6 outbound IPs
- Admin Restore: create User on selected partition
- Evolution: Add/remove widgets to all accounts
- SpamAssassin: user_prefs code safe area for custom code such as custom scores
- Option to include 2222 brute-force attacks in firewall, instead of just the ip_blacklist file.
- More "File Manager" bitwise flags for per-feature control
- Ability to control /etc/virtual/blacklist_usernames, blacklist_smtp_usernames, blacklist_script_usernames via GUI
- User exigrep option to span rotated exim mainlogs
- Create User: can select "random free IP"
- Evolution: "Show All Users", "List Users": Option to add any user.conf/user.usage column to tables
- FileManager: option to hide 4.0KB folder usage in File Manager to avoid confusion
Bug Fixes:
- Dovecot SNI: Optimize local_names into single blocks for faster reads
- "Linux Static 64-bit" DirectAdmin binaries to look for OS independent called binaries
- Rspamd: required_hits vs required_score
- Debian: named_rndc_addzone uses different .nzf file (DNS: instant reloads)
- CREATOR token in dns_*.conf files was missing in some cases
- LetsEncrypt: do not auto-renew if SSL if off
- /home/admin/domains/sharedip was missing for new Admin accounts
- Timeout change for parsing of very large uploaded files using MPFD
- Database: do not allow setting all DB User privileges to 'N'
- CageFS: awstats/webalizer /var/log/user_logs not to call cagefsctrl --remount username on each run
- Linux 64-bit static binaries: dynamic path checking
- JSON: Admin Stats: Empty stats for a language other than English
- PhpMyAdmin SSO: include access_hosts for one-click single sign-on
- Segfault on backup if ethernet_dev not loaded
- mail_partition not passed to domain filters
To update, go to:
Admin Level » Licenses/Updates » Update DirectAdmin
