rspamd problem
santovito
Hello to all.
I'm trying to activate rspamd on my server (centos 8)
I type the following commands:
./build set eximconf yes
./build set eximconf_release 4.5
./build set blockcracking yes
./build set easy_spam_fighter yes
./build set spamd rspamd
./build set exim yes
./build exim
./build rspamd
./build exim_conf
all right, no error. The rspamd process exists and running corrctly
However, it does not seem to be enabled in exim. In the mail header I see: SpamTally: Final spam score: unset because ESF not run (SpamAssassin unset, whitelist, or skippped)
How can I fix?
Thank You
Vito
I did today updates exim , directadmin 1.601 and some more on CENTOS 8
BUT have problem: ( sorry don't have enough time now but there should be something wrong so i paste the error message)
Before updates it was running
Cannot find the script in /etc/systemd/system, /usr/lib/systemd/system, nor /lib/systemd/system​
Details
/lib/systemd/system/spamd.service​
Details
What did you click? I guess have "spamd" (not rspamd) listed in "service monitor" ?
U sorry ;) ( did forumsearch on spamd and didn't read very well ..)
Error restarting service spamd : uid 0 gid 0 : /usr/bin/systemctl restart spamd.service >/dev/null 2>/dev/null : returned 5
did updates with latest Custombuild GUI rev 2379 @smtalk
Is spamassassin installed?
Please check /etc/systemd/system/spamassassin.service, is Alias=spamd.service there? If yes, try:
systemctl enable spamassassin.service
U i didn't find it there but should? because worked before update.
only find /usr/locale/directadmin/custombuild/configure/systemd/spamassassin.service
in custombuild 2 gui however it is on ( spamassassin bleu)
Change this to no and then back to spammassassin didn't help
If i do:
./build set spamd spamassassin
./build spamassassin
then message changed spamd from spamassssin to spamassssin
but with build a lot of error not finding dependencies ( to much i have only printscreens saved )
i wil will first try updating centos 1905 to latest then come back if i have more time here.
I don't understand all was running before the 14 updates i did today in custombuild gui
now i get
I use rspamd and also get "ESF not run". When I try to enable spamassassin, it forced spamd to spamassassin. How can I use spamd as rspamd to get performance advantage while I need to enable spamassassin for ESF at the same time?
# ./build set spamassassin yes
Changed spamd option from rspamd to spamassassin
