missing dependencies libmodsecurity 3.0.4
vancanneyt
Custombuild notified me from an update LibModSecurity 3.0.3 to 3.0.4 update is available. But when updating it was failing because of missing dependencies (Centos 7 with Nginx). Following this link: https://github.com/SpiderLabs/ModSecurity/wiki/Compilation-recipes-for-v3.x the following packages where missing:
yum install yajl yajl-devel GeoIP-devel lmdb lmdb-devel ssdeep ssdeep-devel lua lua-devel
After installing missing dependencies, the update went successfully. Don't know if it's a bug but I thought it was worth mentioning it :-)
As it was installed before I wouldn't expect an issue with dependencies so it was a bit odd.
Here is the log:
Found /usr/local/directadmin/custombuild/modsecurity-v3.0.4.tar.gz
Extracting /usr/local/directadmin/custombuild/modsecurity-v3.0.4.tar.gz...
Configuring modsecurity-v3.0.4...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for ar... ar
checking the archiver (ar) interface... ar
checking whether make sets $(MAKE)... (cached) yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
configure: Nothing about GeoIP was informed during the configure phase. Trying to detect it on the platform...
configure: YAJL library was not found
configure: GeoIP library was not found
configure: Nothing about MaxMind was informed during the configure phase. Trying to detect it on the platform...
configure: using MaxMind v1.4.2
configure: Nothing about LMDB was informed during the configure phase. Trying to detect it on the platform...
*** LOOKING AT PATH:  /usr/lib
*** LOOKING AT PATH:  /usr/local/lib
*** LOOKING AT PATH:  /usr/local/liblmdb
*** LOOKING AT PATH:  /usr/local/lmdb
*** LOOKING AT PATH:  /opt/liblmdb
*** LOOKING AT PATH:  /opt/lmdb
*** LOOKING AT PATH:  /usr/lib64
*** LOOKING AT PATH:  /opt/local
configure: LMDB library was not found
*** LOOKING AT PATH:  /usr/local/fuzzy
*** LOOKING AT PATH:  /usr/local/libfuzzy
configure: SSDEEP library was not found
configure: LUA support was marked as mandatory by the utilization of --with-lua=yes
*** LOOKING AT PATH:  /usr/local/lib64
*** LOOKING AT PATH:  /usr/local/lua
*** LOOKING AT PATH:  /usr/local/liblua
configure: LUA library found at: /usr/lib64//liblua-5.1.so
configure: error: LUA was explicitly referenced but it was not found
*** There was an error while trying to configure LibModSecurity
I install this dependencies with yum and do build lua and build luajit... nothing works. I'm trying to setup nginx_apache (with modsecurity)
Errors:
make[2]: Entering directory `/usr/local/directadmin/custombuild/modsecurity-v3.0.4/tools/rules-check'
g++ -DHAVE_CONFIG_H -I. -I../../src  -std=c++11 -I../../headers  -I/usr/local/include -DPCRE_HAVE_JIT  -DWITH_MAXMIND -I/usr/local/include   -I/usr/local/include/libxml2 -DWITH_LIBXML2   -g -O2 -MT modsec_rules_check-rules-check.o -MD -MP -MF .deps/modsec_rules_check-rules-check.Tpo -c -o modsec_rules_check-rules-check.o `test -f 'rules-check.cc' || echo './'`rules-check.cc
mv -f .deps/modsec_rules_check-rules-check.Tpo .deps/modsec_rules_check-rules-check.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -g -O2  -L/usr/local/lib   -L/usr/local/lib -lpcre  -L/usr/local/lib/ -L/usr/lib64/  -L/usr/local/lib -lpcre -o modsec-rules-check modsec_rules_check-rules-check.o ../../src/.libs/libmodsecurity.la -L/usr/local/lib -lcurl -lGeoIP   -lmaxminddb   -lrt   -L/usr/local/lib -lxml2 -L/usr/lib -lz -liconv -lm -ldl -llmdb   -lluajit-5.1 -L/usr/local/lib -lpcre -lpcre -lfuzzy -lyajl
libtool: link: g++ -g -O2 -o .libs/modsec-rules-check modsec_rules_check-rules-check.o  -L/usr/local/lib -L/usr/local/lib/ -L/usr/lib64/ ../../src/.libs/libmodsecurity.so -L/usr/lib /usr/local/lib/libcurl.so /usr/local/lib/libnghttp2.so -lssl -lcrypto -lGeoIP /usr/local/lib/libmaxminddb.so -lrt /usr/local/lib/libxml2.so -lz /usr/local/lib/libiconv.so -lm -ldl -llmdb -lluajit-5.1 /usr/local/lib/libpcre.so -lfuzzy -lyajl -pthread -Wl,-rpath -Wl,/usr/local/modsecurity/lib
../../src/.libs/libmodsecurity.so: undefined reference to `lua_pcallk'
../../src/.libs/libmodsecurity.so: undefined reference to `lua_getglobal'
../../src/.libs/libmodsecurity.so: undefined reference to `lua_setglobal'
../../src/.libs/libmodsecurity.so: undefined reference to `luaL_setfuncs'
../../src/.libs/libmodsecurity.so: undefined reference to `lua_rawlen'
collect2: error: ld returned 1 exit status
make[2]: *** [modsec-rules-check] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/modsecurity-v3.0.4/tools/rules-check'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/modsecurity-v3.0.4/tools'
make: *** [all-recursive] Error 1
Errors:
solved:
modsecurity compilation check for luajit-5.1 and it'll use this library if found. This is an error, it must use lua-5.3.
Remove (or move to another directory) /usr/local/lib/libluajit* and repeat ./build nginx_apache
