OpenSSL two versions
LawsHosting
London UK
What is the best way to check if there's two versions installed?
PHP will not compile on a server due to OpenSSL errors, and I'm sure having 2 versions installed is the issue.
What's the output of:
ls /usr/local/lib | grep libssl
Okay, do you have anything in /usr/local/directadmin/custombuild/custom ? *configure* files.
only for apache, curl (both for this http/2 feature), and proftpd (for mod_sftp)
It's likely cURL conflicting with PHP loaded OpenSSL too. Try removing custom curl config, recompile and see if that helps.
Now, all I need is to work out why this is happening on another system..... Why looking for apache2 directory instead of httpd?
Installing php...
Installing PHP SAPI module:       apache2handler
/usr/share/apache2/build/instdso.sh SH_LIBTOOL='/var/www/build/libtool' libphp7.la /usr/lib/apache2/modules
/var/www/build/libtool --mode=install install libphp7.la /usr/lib/apache2/modules/
libtool: install: install .libs/libphp7.so /usr/lib/apache2/modules/libphp7.so
libtool: install: install .libs/libphp7.lai /usr/lib/apache2/modules/libphp7.la
libtool: warning: remember to run 'libtool --finish /usr/local/directadmin/custombuild/php-7.2.27/libs'
chmod 644 /usr/lib/apache2/modules/libphp7.so
apxs:Error: Config file /etc/apache2/mods-available not found.
Makefile:170: recipe for target 'install-sapi' failed
make: *** [install-sapi] Error 1
/etc/apache2/mods-available doesn't exist
Installing php...
Likely dpkg/rpm package of Apache installed there?
# dpkg --get-selections | grep apache
apache2-dev install
Can't really recall why I needed to install the dev package.
Back to this OpenSSL thing, I forgot, Exim also failed to compile mentioning SSL stuff
cc -DMACRO_PREDEF tls.c
cc -DMACRO_PREDEF transports/appendfile.c
tls.c:23:3: error: #error One of USE_OPENSSL or USE_GNUTLS must be defined for a TLS build
 # error One of USE_OPENSSL or USE_GNUTLS must be defined for a TLS build
cc -DMACRO_PREDEF transports/autoreply.c
Makefile:272: recipe for target 'macro-tls.o' failed
make[1]: *** [macro-tls.o] Error 1
Changing mirror then ./build clean and ./build update_data fixed it <shrug emoji>
Dodgy mirrors?! (was set to 'files-fr.' fwiw)
And removing (purge) apache2-dev then rebuilding fixed php compiles.
file-fr is always in sync, shouldn't have been the cause.
