insha Verified User Joined Nov 11, 2019 Messages 73 Feb 7, 2020 #1 Hello is there a plugin that can change PHP version different than main domain? Or remind me how to do it manually in SSH terminal? I forgot I use openlitespeed on centos 8
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,113 Location www.poralix.com Feb 7, 2020 #2 Hello, You should add your sub-domain as a domain with its own public/private_html directories. The existing plugins won't work under OpenLiteSpeed.
insha Verified User Joined Nov 11, 2019 Messages 73 Feb 9, 2020 #3 zEitEr said: Hello, You should add your sub-domain as a domain with its own public/private_html directories. The existing plugins won't work under OpenLiteSpeed. Click to expand... Ok can you post how to do that?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,113 Location www.poralix.com Feb 9, 2020 #4 1. connect to directadmin as user 2. remove added subdomain 3. click add domain Search official docs for more details on how to do any of these steps.
insha Verified User Joined Nov 11, 2019 Messages 73 Feb 9, 2020 #5 Ok, ill try Thank you @zEitEr for directions
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,113 Location www.poralix.com Feb 21, 2020 #6 See Version 1.60.4 | DirectAdmin Docs DirectAdmin Knowledge Base directadmin.com
insha Verified User Joined Nov 11, 2019 Messages 73 Feb 21, 2020 #7 zEitEr said: See Version 1.60.4 | DirectAdmin Docs DirectAdmin Knowledge Base directadmin.com Click to expand... Wow thanks ?
