- Feb 27, 2003
We're pleased to announce the production release of DirectAdmin 1.60.4.
This is primarily a bug-fix release, with a few small new features.
All changes are listed here:
DirectAdmin Web Control Panel Version History
Features/Changes:
Let us know if you have any issues.
Features/Changes:
- Default Change: MySQL: New var: default_mysqldump_options=--single-transaction
- Default Change: pointers_own_virtualhost=1, system_user_to_virtual_passwd=1 on new installs
- Sub-domain php version selection
- Create User: option to create User with crypted password
- Allow per-reseller user_limit.txt
- User limit check locking
- Better User deletion accountability logging
- phpMyAdmin User SSO: use per-db format
- Custom hook filtering (SECURITY)
- PMA_SSO: remote mysql server caused blank page
- CUSTOM token not setting tokens for other CUSTOM tokens
- subdomain documentroot override: path enforcement and backup/restore
- DNS: Allow reading/viewing of $GENERATE records
- DNS: SPF: change User IP to do a surgical swap
Admin Level -> Support & Help -> Licensing / Updates -> Update DirectAdminLet us know if you have any issues.
