reseller/create-user is very slow
youyoums
reseller/create-user is very slow,it has waste a long time
Unix User created successfully
User's System Quotas set
User's data directory created successfully
Domains directory created successfully
Domains directory created successfully in user's home
Domain Created Successfully
User added to ssh config file.
Check what you have under /usr/local/directadmin/scripts/custom/ and MultiServer page in directadmin.
If processes go slow, that might be caused by custom script trying to do an operation which slow down, or directadmin tries to connect to a remote inaccessible server under Multiserver function.
under /usr/local/directadmin/scripts/custom/ just README file
Thank you for your reply,i have no choice for multi-server on admin level
I'd suggest opening a support ticket, or starting DA in debug mode to see what is taking time there.
And multi-server on admin level?
Hi smtalk
I need to disallow subdomain php script to access outside of its folder to prevent hacker to access other subdomain if it is hacked in case. which is very important for security please help me in this to achieve
