PostgreSQL for DirectAdmin
alex2k
Behind You!
Is there any simple way to add PostgreSQL feature for DirectAdmin?
Any how-to info to install it would be great.
Thank you...
Its great news, i even start to thinking about migrating to CPanel due lack of PostgreSQL support. So if you need more test enviroments PM me.
It is quite easy to install it and use it; however the integration with DirectAdmin will need coding. Congratulations to zEitEr if he is developing a plugin.
Sure its not a big problem to install it even with phpPgAdmin but without integration with DA for end user is useless ;)
Hello Alex,
We've developed a solution, and need testers. So if you are ready to test it please let me know.
Could you possibly send me the information how I can install postgres on my DA please?
