I have some bigger wp-login.php brute force attacks from many different IPs, for many wordpress installations,
of course I have enabled "Directadmin's BFM compatible with CSF" from this topic:
forum.directadmin.com
but there is too many IP and even when they are blocked every minute there is more then 1000 new IPs and system is overloaded all the time.
Is there any others options to secure wp-login.php for wordpress?
I saw good solution on some websites: javascript cookie only for wp-login.php page, if You have javascript enabled in website browser, then You are allowed to see wp-login.php, if You don't have javascript, which most attacks doesn't use, You are blocked,
does anybody know where I can find that solution for server side?
How to block IPs with Brute Force Monitor in DirectAdmin using CSF
To make Directadmin's BFM compatible with CSF you should do the following: Auto-installation with the help of the script: cd ~ wget -O csf-bfm-install.sh https://raw.githubusercontent.com/poralix/directadmin-bfm-csf/master/install.sh chmod 700 csf-bfm-install.sh ./csf-bfm-install.sh Manual...
