LiteSpeed - htaccess,httpd configurations
ShinJii
I read that LiteSpeed has Apache compatibility - if I have .htaccess files in domains and CUSTOM HTTPD configurations in DA - will it work with litespeed? or not? or it will be deleted?
I have to be 100% sure :D
LiteSpeed for me is LiteSpeed - paid version ;p I don't care about OpenLiteSpeed - I guess there's few differences between them? ;)
Main question for me is about CUSTOM HTTPD CONFIGURATION... without that my portal will broke up.
@smtalk probably you should know the answer? :D because option with LiteSpeed in CustomBuild is for paid version, right?
Well, i googled a bit and found this thread:
And based on this I would say you can use custom httpd.
yes, but I want to know if DirectAdmin don't delete it after upgrade from apache to litespeed :)
It won’t delete your customizations. They wil still be used in LiteSpeed.
