Error {apache is functioning normally} When SSL disable (SSL is currently disable )
alemmsm
hi
when I disable SSL
The domain is not show ((( Error {apache is functioning normally} )))
I want redirect all https to http
I'm very curious as to why you want to redirect to http while https is better and have better browser support?
And your site runs good in https.
Anyway, if you want http to work you have to check 3 things.
1.) Automatic redirection from within Directadmin had to be disabled
2.) No .htaccess or virtualhost or nginx.conf redirection from http to https must be present
3.) There must not be https main site paths in your website.
Still..... I wouldn't do it if I were you.
Good. How to disable the current certificate And enable cloudflare.com certification on the domain ?
when I disable the current certificate And enable cloudflare.com certification (( Error {apache is functioning normally} )))
Have a look at this, you must not fully disable SSL.
and this
