I have a VPS server, Debian 10 x64, after installing Direct Admin any of email accounts I have created don't work (got login failed message). I've tried so far:
1. Dropping da_roundcube database and rebuilding roundcube
2. Rebuilding dovecot
3. Checked MX records for domain (OK)
None of these fixed the problem. I even changed system to CentOS8 - no luck. I can add email account in user panel, but there are no records in da_roundcube.users table and I can't login using roundcube or desktop email client.
Here are logs after creating one email account on a fresh install of direct admin (followed by adding a domain, ofcrs) and one login try in roundcube:
/var/www/html/roundcube/logs/errors.log
/var/log/maillog
/var/log/exim/mainlog
root@serverdomain:~# host -t any mydomain.com
YES, I am sure I'm using a correct password
Direct Admin has a trial licence, but I don't think it matters.
regards,
Szymon
[05-Apr-2020 17:53:13 +0200]: <jpfj59tn> IMAP Error: Login failed for [email protected] against localhost from X.X.X.X. AUTHENTICATE PLAIN: in /var/www/html/roundcubemail-1.4.3/program/lib/Roundcube/rcube_imap.php on line 200 (POST /roundcube/?_task=login&_action=login)
/var/log/maillog
Apr 5 17:49:50 serverdomain dovecot[6993]: master: Dovecot v2.3.10 (0da0eff44) starting up for imap, pop3, lmtp (core dumps disabled)
Apr 5 17:53:13 serverdomain dovecot[7007]: auth: Error: plain([email protected],127.0.0.1,<NyLkJY2iBM1/AAAB>): user not found from any userdbs
Apr 5 17:53:13 serverdomain dovecot[7007]: imap: Error: auth-master: login: request [1264582657]: Login auth request failed: Authenticated user not found from userdb, auth lookup id=1264582657 (auth connected 7 msecs ago, request took 6 msecs, client-pid=7029 client-id=1)
Apr 5 17:53:13 serverdomain dovecot[7007]: imap-login: Internal login failure (pid=7029 id=1): user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=18926, secured, session=<NyLkJY2iBM1/AAAB>
2020-04-05 17:45:33 Warning: No server certificate defined; will use a selfsigned one.
Suggested action: either install a certificate or change tls_advertise_hosts option
2020-04-05 17:45:33 Warning: purging the environment.
Suggested action: use keep_environment.
2020-04-05 17:45:33 exim 4.93.0.4 daemon started: pid=16384, -q1h, listening for SMTP on port 25 (IPv6 and IPv4)
2020-04-05 17:45:33 Start queue run: pid=16389
2020-04-05 17:45:33 End queue run: pid=16389
2020-04-05 17:50:21 cwd=/ 3 args: /usr/sbin/exim -bd -q1h
2020-04-05 17:50:21 exim 4.93.0.4 daemon started: pid=13829, -q1h, listening for SMTP on port 25 (IPv4) port 587 (IPv4) and for SMTPS on port 465 (IPv4)
2020-04-05 17:50:21 cwd=/var/spool/exim 2 args: /usr/sbin/exim -qG
mydomain.com descriptive text "v=spf1 a mx ip4:X.X.X.X ~all"
mydomain.com mail is handled by 10 mail.mydomain.com.
mydomain.com has address X.X.X.X
mydomain.com has SOA record ns1.serverdomain.com. hostmaster.mydomain.com. 2020040500 14400 3600 1209600 86400
mydomain.com name server ns1.serverdomain.com.
mydomain.com name server ns2.serverdomain.com.
regards,
Szymon
