Anormal disk usage on DA?
jdn1976
Hello, I have some accounts with anormal usage on DA.
See print attached. For example on this print for this user atilaexpresscom says that is using 27Mb disk usage. Yesterday was not like this it is increasing the quota usage for all accounts. But on the same use if I go to SSH and type for user atilaexpresscom:
[root@servidor atilaexpresscom]# du -sch *
0 backups
36K cache
5.0M domains
48K etc
3.7M imap
144K Maildir
0 public_ftp
0 public_html
0 tmp
8.9M total
it says a total of 8.9 Mb. Is this a bug of DA? Is there way to fix a set the correct quota usage?
And no, the client do not send any files to server.
Thank you.
check /home/tmp maybe there unfinished backup, also files owned by this user may be in another places (some forgotten backup),
and mysql database counted too, and check inodes.
