metepec.online
ayyan
Hi, i am installing laraclassified theme on metepec. online with domain hosted on your hosting. it show this error "
ERROR: Please disable the open_basedir setting to continue" i tried it to fix but due to new setup of your hosting i am not able to fix it kindly help me.
thanks with regards
How did you try to fix it? Is the domain using a php version different from the default php version used on the server? If so, is open_basedir enabled in the default php version and does the test pass if you disable it there?
I with the same problema, and go to make an experience to resolve:
thanks with regards
First:
1a) Find in files the name open_basedir. I use the midnight commander mc, search all files *.* and the same i will to test is:
/usr/local/directadmin/mywebsiteopenbased.com.br.conf
Its here the line: open_basedir=OFF
safemode=ON i change to off to try
Do not work!!! :(
2a) I try a lot of sites with learn me to put inside the config file php.ini but no exitum!!! But i will work in it. And is today!!!!
Any sugestions?!?!?!?!
@Daniel Cesar
Admin Level > PHP Configuration > select domain > clicked "Dsiable Open BaseDir" button
after this step
./build rewrite_confs
ERROR: Please disable the open_basedir setting to continue.
Next I Try:
thanks with regards
I will fix, if you @ayyan discover first please talk-me!!!
I am the
thanks with regards
same problem, exactly, laraclassified. I finding the resolve way.
Regards,
Daniel Cesar
@Daniel Cesar
after this step
I try now but don´t work. With Safemod on and off the problem is the same....
