Enable Letsencrypt to a domain fail - /.well-known alias need to setup in WWW server.
tomwin
Hi, sorry for many questions but there is lots of new things for me. When I trying to enable lestencrypt to my added domain it failed and give this error below.
Cannot execute your request
Error: http://mydomain.com/.well-known/acme-challenge/letsencrypt_1587637366 is not reachable. Aborting the script.
dig output for mydomain.com:
2606:4700:3035::681b:b8ba
2606:4700:3034::681b:b9ba
Please make sure /.well-known alias is setup in WWW server.
I have tried to locate this www map in my server so I can add these .well-known map I guess they want me to add there but I can’t find the location for it?
Please, anyone can help me out on this difficult problem?
Hi, they want me to check to ensure that you have letsencrypt=1 in your directadmin.conf.
The directadmin.conf lives here:
/usr/local/directadmin/conf/directadmin.conf
But when I look in my files in ROOT I can find that location. Do I need to use SSH to open this file? It that so, not sure how to. Are there a command to open that file?
It looks I have added it
[root@server-test ~]# cd /usr/local/directadmin
[root@server-test directadmin]# ./directadmin c | grep ^letsencrypt=
letsencrypt=1
Hi, I’m hoping for some help.
when I open up
i can see that
letsencrypt=1
are in this file. Look at the picture please.
Next, we'll want to confirm the Alias /.well-known has been added to the file
/etc/httpd/conf/extra/httpd-alias.conf
so I run this command
./build rewrite_confs
But after when I check the same file
There is no Alias /.well-known has not been added to the file
Please look at the picture.
What am I doing wrong? Please help me!
it looks like Directadmin is way to complicated. I tried to install letsencrypt but I get this error when I run this command
./letsencrypt.sh request_single your.hostname.com 4096
[root@server-test ~]# cd /usr/local/directadmin/scripts
[root@server-test scripts]# ./letsencrypt.sh request_single server-test.com 4096
Setting up certificate for a hostname: server-test.com
Error: http://server-test.com/.well-known/acme-challenge/letsencrypt_1587644324 is not reachable. Aborting the script.
dig output for server-test.com:
Unbelievable, now my directadmin won’t work. I think the system had enough of me.
[root@server-test ~]# service directadmin restart
Redirecting to /bin/systemctl restart directadmin.service
Job for directadmin.service failed because a configured resource limit was exceeded. See "systemctl status directadmin.service" and "journalctl -xe" for details.
I think You set DA to use hostname based on non existing domain, that's why all broken now.
Domain must be registered/delegated and pointed by DNS to server where You run LetsEncrypt script
If I was the creator of directadmin, I had these setting installed by default. Why make it like these?
Ok, is there a way to start directadmin again? Or do I need to reinstall everything?
