- Feb 27, 2003
We're very pleased to announce a major new release:
DirectAdmin 1.61.0 RC1
This is a test version of 1.61.0 to be released in a few weeks.
All changes can be found here:
https://www.directadmin.com/versions.php?version=1.610000
Just some of the New Features:
Please try and report issues in this thread to avoid duplicate support issue.
As usual, you can update to the pre-release binaries with this guide:
If you're doing a fresh install of DA, you can install with these binaries using:
- Plugins can be package items
- Global IP type for sharing over multiple Resellers
- Direct CSF Integration (no more custom scripts required)
- Trash can for File Manager
- Subdomain php selector and DocumentRoot override
- Live pureftpd.pdb updates
- rejectlog now included in per-email User visible exim logs
- Packages: rename and copy
- Bubblewrap: JAIL
- json files now gzip encoded for zippier loads
- Feature Sets: control sets of CMDs for things like a proper E-Mail only or DNS only package
- Admin Level >> Licenses Updates: "Update License Auto" for new license, even if LID is different.
- Rspamd Controller WebUI: spam filterings metrics
- NetData Metrics
- Goodbye AllowUsers in sshd_config!
- Per-User mail_partition user.conf override
- 2222/robots.txt
- Option: domain.com/logs to be saved as "nobody" so Users cannot delete them
- Info: All directadmin/dataskq binaries are now static
- mail_partition=1 with system_user_to_virtual_passwd=1 needed ~/Maildir symlink
- User History was not showing last day of month
- CMD_MASTER_LOGIN show max 500 Users
- IMG files were being unintentionally gzipped
- Backup/Restore skin customizations
- Forwarder lock not removed
- Using JSON with CMD_API calls
- hostname.sh now also sets directadmin.conf
- login_keys_notify_on_creation was not being respected
- CMD_JSON_LANG option to touch+extend session (eg: large file uploads)
- Allow unknown `TOKENS` to be swapped with |TOKEN| for future processing (TEMPLATES)
- swap da_sso definers for db procedures/functions
- Domain Pointers & named_rndc_addzone=1: write order swap
- Block access host "domain" if my.cnf has skip_name_resolve=ON
- Restore system account to /etc/virtual/domain.com/passwd when enabled
- Office 365 (now Microsoft 365): extra spaces in zone
./setup.sh beta
