Create user for DB mysql
jdn1976
Hello, I am trying to create a user to an existent mysql database but when I type name for the user wp660 says the error:
value is too long: Max=3
how do I increase this?
your mysql version compatible with longer names?
you must restart directadmin/mysql after modifications
Yes I restarted mySQL.
I have transfer this account from a cPanel server with mySQL 5.6 and I am using also mySQL 5.6 on DA server.
with this mysql version long names not allowed, use short names, replace in website configs dbname/dbuser with new.
Odd, now is given the error:
Cannot load from mysql.db. The table is probably corrupted
I already make a search on google but not solve the problem. Any ideas?
I am creating user and db using DA panel.
could help
max_username_length=10
Max length a username can be. Max is 30. It is limited to max of 14 with MySQL 5.5/5.6 and MariaDB 5.5 because of the 16 character mysql database name limit and the username naming prefix.
http://www.directadmin.com/features.php?id=189
https://www.directadmin.com/features.php?id=2294
Thanks, but I already set 20 when I setup the server.
I think this should solve the issue using 20 char for username. but not.
You set what to 20?
You have 30 total.
and only 16 total for mysql.
You have 18 in the Screenshot which won't work. You need 2 fewer characters from somewhere.
You set what to 20?
You have 30 total.
Thanks for your reply. I solve the problem another way.
I deleted the database and user.
I created again the database and user with same password of wordpress configuration and then upload the SQL file.
It was given error on DB on cpanel full backup.
